查看: 908|回復: 1
為什么Keil只有1個提醒,硬件無法顯示?求助
ID:496863 發表于 2019-3-23 20:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
typedef unsigned char INT8U;
typedef unsigned char uchar;
typedef unsigned int INT16U;
typedef unsigned int uint;
sbit DS = P3^6;
//sbit DU = P1;
//sbit WE = P2;
uchar code table[]={
//0  1  2     3     4     5     6     7     8
0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80,
//9     A     B    C  D    E  F  -  .   關顯示
0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E, 0xBF, 0x7F, 0xFF};
uchar code T_COM[] = {0xfe, 0xfd, 0xfb, 0xf7,};//數碼管位碼
/*us延時函數,執行一次US--所需6.5us進入一次函數需要11.95us*/
void Delay_us(uchar us)
while(us--);
函數 : delay(uint z)
參數 :z 延時毫秒設定,取值范圍0-65535
返回值 :無
描述 :12T/Fosc11.0592M毫秒級延時
void delay(uint z)
uint x,y;
for(x = z; x > 0; x--)
  for(y = 114; y > 0 ; y--);
void Display(INT16U Value)
  P1 = 0XFF;
  P2 = T_COM[1];
  P1 = table[Value/100];
  delay(5);
  P1 = 0XFF;
  P1 = 0XFF;
  P2 = T_COM[2];
  P1 = table[Value%100/10]&0x7f;
  delay(5);
  P1 = 0XFF;
  P1 = 0XFF;
  P2 = T_COM[3];
  P1 = table[Value%10];
  delay(5);
  P1 = 0XFF;
bit ds_init()
  bit i;
  DS = 1;
  _nop_();
  DS = 0;
  Delay_us(75);
  DS = 1;
  Delay_us(4);
  i = DS;
  Delay_us(20);
  DS = 1;
  _nop_();
  return(i);
void write_byte(uchar dat)
  uchar i;
  for(i=0;i<8;i++)
    DS = 0;
    _nop_();
    DS = 1;
    DS = dat & 0x01;
    Delay_us(10);
    DS = 1; //釋放總線準備下一次數據寫入
    _nop_();
    dat >>= 1;
uchar read_byte()
  uchar i, j, dat;
  for(i=0;i<8;i++)
    DS = 0;
    _nop_();
    DS = 1;
    _nop_();
    j = DS;
    Delay_us(10);
    DS = 1;
    _nop_();
    dat = (j<<7)|(dat>>1);
  return (dat);
  uint i=0;
  uchar L, M;
/*  ds_init();
  write_byte(0xcc);
  write_byte(0x4e);
  write_byte(0x7f);
  write_byte(0xf7);
  write_byte(0x1f);
  ds_init();
  write_byte(0xcc);
  write_byte(0x48);*/
    ds_init();
    write_byte(0xcc);
    write_byte(0x44);
    ds_init();//初始化DS18B20
    write_byte(0xcc);
    write_byte(0xbe);
    L = read_byte();
    M = read_byte();
    i = M;
    i <<=8;
    i |= L;
    i = i * 0.0625 * 10 + 0.5;
        Display(i);   delay(10);
linking...
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?PR?_DISPLAY?WHENG
Program Size: data=11.1 xdata=0 code=1193
creating hex file from "1"...
"1" - 0 Error(s), 1 Warning(s).
ID:1 發表于 2019-3-24 02:10 | 只看該作者
您這個問題給的信息不全,估計是沒人能回答得了的,先轉移到冷門區了,自行點擊編輯按鈕補充一下吧,審核員會幫你重新轉到熱門問答區的
