T0方式2實(shí)現(xiàn)簡(jiǎn)單電子時(shí)鐘仿真試驗(yàn),keil+protues實(shí)現(xiàn)
單片機(jī)源程序如下:
- //按4X4鍵盤的F鍵 進(jìn)入設(shè)定狀態(tài)
- //E D 鍵是前后移動(dòng)鍵
- //C按鍵是調(diào)整數(shù)值按鍵
- #include "reg52.h"
- #define uchar unsigned char
- sbit key_h=P1^0;
- sbit key_m=P1^1;
- sbit key_s=P1^2;
- unsigned char Tab[ ]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; //段碼表
- unsigned int h,m,s,counter;
- void delay1ms(unsigned int i)
- unsigned char j;
- while(i--)
- for(j=0;j<125;j++) //1ms基準(zhǔn)延時(shí)程序
- void Display_h(unsigned char x)
- P2=0xfb; //P2.6引腳輸出低電平,DS6點(diǎn)亮
- P0=Tab[x/10]; //顯示十位
- delay1ms(5);
- P2=0xff;
- P2=0xf7; //P2.7引腳輸出低電平,DS7點(diǎn)亮
- P0=Tab[x%10]; //顯示個(gè)位
- delay1ms(5);
- P2=0xff;
- void Display_m(unsigned char x)
- P2=0xef; //P2.6引腳輸出低電平,DS6點(diǎn)亮
- delay1ms(5);
- P2=0xff;
- P2=0xdf; //P2.7引腳輸出低電平,DS7點(diǎn)亮
- delay1ms(5);
- P2=0xff;
- void Display_s(unsigned char x)
- P2=0xbf; //P2.6引腳輸出低電平,DS6點(diǎn)亮
- delay1ms(5);
- P2=0xff;
- P2=0x7f; //P2.7引腳輸出低電平,DS7點(diǎn)亮
- delay1ms(5);
- P2=0xff;
- /*********************初始化子程序**********************/
- void init()
- TMOD=0x01;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- EA=1;
- ET0=1;
- TR0=1;
- counter=0;
- h=12;m=0;s=0;
- /***************************按鍵調(diào)時(shí)間************************/
- void TZ_h()
- h++;
- if(h>24)
- h=0;
- while(key_h!=1);
- TR0=1;
- void TZ_m()
- m++;
- if(m>60)
- m=0;
- while(key_m!=1);
- TR0=1;
- void TZ_s()
- s++;
- if(s>60)
- s=0;
- while(key_s!=1);
- TR0=1;
- /***************************主程序************************/
- void main(void)
- init();
- while(1)
- Display_h(h);
- Display_m(m);
- Display_s(s);
- if(key_h==0)
- delay1ms(20);
- if(key_h==0)
- TR0=0;
- TZ_h();
- if(key_m==0)
- delay1ms(20);
- if(key_m==0)
- TR0=0;
- TZ_m();
- if(key_s==0)
- delay1ms(20);
- if(key_s==0)
- TR0=0;
- TZ_s();
- /*************************定時(shí)器0的中斷**********************/
- void Time0() interrupt 1 using 2 //再次強(qiáng)調(diào)中斷子程序執(zhí)行時(shí)間越短越好
- counter++;
- if(counter==20)
- s++;
- counter=0;
- if(s==60)
- m++;
- s=0;
- if(m==60)
- h++;
- m=0;
- if(h==24)
- h=0;
簡(jiǎn)單時(shí)鐘顯示實(shí)驗(yàn).rar
(51.09 KB, 下載次數(shù): 40)
2019-3-23 11:31 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
