#include <reg52.h>
#include <..\CONFIG\QXA51.h>
unsigned char pwm_left_val = 210;//左電機(jī)占空比值 取值范圍0-170,0最快
unsigned char pwm_right_val = 210;//右電機(jī)占空比值取值范圍0-170 ,0最快
unsigned char pwm_t;//周期
/*小車(chē)前進(jìn)*/
void forward()
left_motor_go; //左電機(jī)前進(jìn)
right_motor_go; //右電機(jī)前進(jìn)
//定時(shí)器0中斷
void timer0() interrupt 1
pwm_t++;
if(pwm_t == 255)
pwm_t = EN1 = EN2 = 0;
if(pwm_left_val == pwm_t)
EN1 = 1;
if(pwm_right_val == pwm_t)
EN2 = 1;
TMOD |= 0x02;//8位自動(dòng)重裝模塊
TH0 = 220;
TL0 = 220;//11.0592M晶振下占空比最大比值是256,輸出100HZ
TR0 = 1;//啟動(dòng)定時(shí)器0
ET0 = 1;//允許定時(shí)器0中斷
EA = 1;//總中斷允許
forward();//前進(jìn)
