查看: 2192|回復: 1
51智能小車超聲波測距lcd顯示源碼
ID:330146 發表于 2019-3-20 09:15 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
51智能小車超聲波測距lcd顯示源碼
#include <reg52.h>
#include <intrins.h>
#include "lcd.h"
sbit ENA = P1^6; //定義ENA為P1^1端口
sbit ENB = P1^7;
sbit IN1 = P1^2;
sbit IN2 = P1^3;
sbit IN3 = P1^4;
sbit IN4 = P1^5;
sbit Trig = P2^1;
sbit Echo = P2^0;
sbit left_1_led = P3^4; //宏定義左避障模塊為p3^6口
sbit right_1_led = P3^5;//宏定義右避障模塊為p3^7口
sbit left_x = P3^7;
sbit right_x = P3^6;
unsigned char pwm_t = 0; //定義周期
unsigned char Disp[]="  4:XU:TIAN:ZAN   ";
unsigned char code ASCII[15] = {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
unsigned char left_pwm_val = 100,right_pwm_val = 100; //左右電機占空比值
static unsigned char DisNum = 0; //顯示用指針
       unsigned int  time=0;
    unsigned long S=0;
    bit      flag =0;
    unsigned char disbuff[4]    ={ 0,0,0,0,};
void Conut(void)
  time=TH1*256+TL1;
  TH1=0;
  TL1=0;
  S=(time*1.7)/100;     //算出來是CM
  if((S>=700)||flag==1) //超出測量范圍顯示“-”
   flag=0;
   DisplayOneChar(0, 1, ASCII[11]);
   DisplayOneChar(1, 1, ASCII[10]); //顯示點
   DisplayOneChar(2, 1, ASCII[11]);
   DisplayOneChar(3, 1, ASCII[11]);
   DisplayOneChar(4, 1, ASCII[12]); //顯示M
   disbuff[0]=S%1000/100;
   disbuff[1]=S%1000%100/10;
   disbuff[2]=S%1000%10 %10;
   DisplayOneChar(0, 1, ASCII[disbuff[0]]);
   DisplayOneChar(2, 1, ASCII[disbuff[1]]);
   DisplayOneChar(3, 1, ASCII[disbuff[2]]);
void zd0() interrupt 3    //T0中斷用來計數器溢出,超過測距范圍
    flag=1;        //中斷溢出標志
void  StartModule()            //啟動模塊
   Trig=1;                        //啟動一次模塊
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   Trig=0;
void delayms(unsigned int ms)
unsigned char i=100,j;
for(;ms;ms--)
  while(--i)
   j=10;
   while(--j);
void run() //小車前進函數
IN1 = 1; //左電機前進
IN2 = 0;
IN3 = 1; //右電機前進
IN4 = 0;
//左轉
     void  leftrun(void)
     IN1 = 0;
    IN2 = 0;
    IN3 = 1;
    IN4 = 0;
//右轉
     void  rightrun(void)
    IN1 = 1;
    IN2 = 0;
    IN3 = 0;
    IN4 = 0;
//停止
     void  stop(void)
     IN1 = 0;
    IN2 = 0;
    IN3 = 0;
    IN4 = 0;
void bi(void)  //小車避障函數
//有信號為0 無信號為1
if(left_1_led == 1 && right_1_led == 1)
  run();
if(left_1_led == 1 && right_1_led == 0)
  stop();
if(left_1_led == 0 && right_1_led == 1)
  stop();
if(left_1_led == 0 && right_1_led == 0)
  stop();
void timer0(void) interrupt 1 //定時器中斷服務程序
pwm_t++;
if(pwm_t == 255) //周期最大值時 清零
  pwm_t = ENA = ENB = 0;
if(left_pwm_val == pwm_t) //左電機占空比等于周期時
  ENA = 1;                //使能ENA
if(right_pwm_val == pwm_t) //右電機占空比等于周期時
  ENB = 1;                //使能ENB
void Time0Config()
TMOD|= 0x02;   //八位自動重裝模式
TH0= 220;    //1ms定時
  TL0= 220;
ET0 = 1;    //允許定時器0中斷
EA = 1;     //開啟總中斷
TR0 = 1;   //開啟定時器0
void Time1Config()
  TMOD=0x10;     //設T0為方式1,GATE=1;
  TH1=0;
  TL1=0;
  ET1=1;             //允許T1中斷
  EA=1;      //開啟總中斷
void main(void)
LcdInit();
LcdShowStr(0,0,Disp);
Time1Config();
Time0Config(); //定時器函數
while(1) //無限循環
     StartModule();
      while(!Echo);  //當RX為零時等待
      TR1=1;       //開啟計數
    while(Echo);   //當RX為1計數并等待
    TR1=0;    //關閉計數
    Conut();   //計算
     delayms(10);
  if((left_x!=1)||(right_x!=1))
   if((left_x==1)&&(right_x==0))
    bi();
    leftrun();
   if((left_x==0)&&(right_x==1))
    bi();
        rightrun();
   if((left_x==0)&&(right_x==0))
    bi();
    run();
  if((left_x==1)&&(right_x==1))
   stop();
lcd顯示
#include "lcd.h"
* 函 數 名         : Lcd1602_Delay1ms
* 函數功能     : 延時函數,延時1ms
* 輸    入         : c
* 輸    出         : 無
* 說    名         : 該函數是在12MHZ晶振下,12分頻單片機的延時。
void Lcd1602_Delay1ms(uint c)   //誤差 0us
    uchar a,b;
for (; c>0; c--)
   for (b=199;b>0;b--)
     for(a=1;a>0;a--);
* 函 數 名         : LcdWriteCom
* 函數功能     : 向LCD寫入一個字節的命令
* 輸    入         : com
* 輸    出         : 無
#ifndef  LCD1602_4PINS  //當沒有定義這個LCD1602_4PINS時
void LcdWriteCom(uchar com)   //寫入命令
LCD1602_E = 0;     //使能
LCD1602_RS = 0;    //選擇發送命令
LCD1602_RW = 0;    //選擇寫入
LCD1602_DATAPINS = com;     //放入命令
Lcd1602_Delay1ms(1);  //等待數據穩定
LCD1602_E = 1;           //寫入時序
Lcd1602_Delay1ms(5);   //保持時間
LCD1602_E = 0;
#else
LCD1602_E = 0;  //使能清零
LCD1602_RS = 0;  //選擇寫入命令
LCD1602_DATAPINS = com; //由于4位的接線是接到P0口的高四位,所以傳送高四位不用改
LCD1602_E = 0;
LCD1602_DATAPINS = com << 4; //發送低四位
LCD1602_E = 0;
#endif
* 函 數 名         : LcdWriteData
* 函數功能     : 向LCD寫入一個字節的數據
* 輸    入         : dat
* 輸    出         : 無
void LcdWriteData(uchar dat)   //寫入數據
LCD1602_RS = 1; //選擇輸入數據
LCD1602_DATAPINS = dat; //寫入數據
LCD1602_E = 0;
#else
LCD1602_RS = 1;   //選擇寫入數據
LCD1602_DATAPINS = dat; //由于4位的接線是接到P0口的高四位,所以傳送高四位不用改
LCD1602_E = 0;
LCD1602_DATAPINS = dat << 4; //寫入低四位
LCD1602_E = 0;
#endif
* 函 數 名       : LcdInit()
* 函數功能   : 初始化LCD屏
* 輸    入       : 無
* 輸    出       : 無
void LcdInit()        //LCD初始化子程序
  LcdWriteCom(0x38);  //開顯示
LcdWriteCom(0x0c);  //開顯示不顯示光標
LcdWriteCom(0x06);  //寫一個指針加1
LcdWriteCom(0x01);  //清屏
LcdWriteCom(0x80);  //設置數據指針起點
#else
LcdWriteCom(0x32);  //將8位總線轉為4位總線
LcdWriteCom(0x28);  //在四位線下的初始化
#endif
void LcdSetCursor(unsigned char x,unsigned char y)  //坐標顯示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    LcdWriteCom(addr|0x80);
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str)     //顯示字符串
    LcdSetCursor(x,y);      //當前字符的坐標
    while(*str != '\0')
        LcdWriteData(*str++);
//按指定位置顯示一個字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
X |= 0x80; //算出指令碼
LcdWriteCom(X); //發命令字
LcdWriteData(DData); //發數據
ID:1 發表于 2019-3-20 18:23 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
