查看: 4895|回復: 2
arduino+U8glib控制0.96 OLED屏源程序
ID:423234 發表于 2019-3-18 20:18 | 顯示全部樓層 |閱讀模式
Arduino源程序如下:
  1. #include "U8glib.h"
  2. #define RIGHT 0
  3. #define UP    1
  4. #define LEFT  2
  5. #define DOWN  3
  6. /*
  7. * OLED
  8.       arduino       OLED
  9.       D9        >     MOSI
  10.       D10      >     SCK
  11.       D11      >     DC
  12.       D12      >     CS
  13.       D13      >     RES
  14. SW SPI COM:
  15. SCK = 10, MOSI = 9 , CS = 12, A0 = 11, RES = 13
  16. */
  17. U8GLIB_SSD1306_128X64 u8g(10, 9, 12, 11, 13);
  18. int score = 0;
  19. int level = 1;
  20. int gamespeed = 100;
  21. int i;
  22. //組成單位,4X4像素點的方塊。
  23. const uint8_t ele[] PROGMEM = {
  24.   0xf0, //B1111000
  25.   0xb0, //B1011000
  26.   0xd0, //B1101000
  27.   0xf0, //B1111000
  28. };
  29. //蛇
  30. void element(int x, int y) {
  31.   u8g.drawBitmapP(x,y, 1,4, ele);
  32. }
  33. struct FOOD {
  34.   int x;
  35.   int y;
  36.   int yes;
  37. };
  38. FOOD food = {25, 30, 1};
  39. struct SNAKE {
  40.   int x[200];
  41.   int y[200];
  42.   int node;
  43.   int dir;
  44.   int lefe;
  45. };
  46. SNAKE snake = {{9,5}, {30,30}, 2, RIGHT, 0};
  47. //游戲基本界面
  48. void UI() {
  49.   u8g.drawFrame(0,1, 102,62);   //內邊界
  50.   u8g.drawFrame(0,0, 102,64);   //外邊界
  51.   u8g.setFont(u8g_font_5x7);    //設置字體
  52.   u8g.drawStr(104,12, "LEVEL"); //等級提示
  53.   u8g.drawStr(104,40, "SCORE"); //分數提示
  54. }
  55. void printScore(int x, int y, int s) {
  56.   u8g.setFont(u8g_font_6x10);
  57.   u8g.setPrintPos(x, y);
  58.   u8g.print(s);
  59. }
  60. void key() {
  61.   if(LOW == digitalRead(2)) {
  62.     snake.dir = DOWN;
  63.   }
  64.   if(LOW == digitalRead(3)) {
  65.     snake.dir = RIGHT;
  66.   }
  67.   if(LOW == digitalRead(4)) {
  68.     snake.dir = LEFT;
  69.   }
  70.   if(LOW == digitalRead(5)) {
  71.     snake.dir = UP;
  72.   }
  73. }
  74. void snakeGame() {
  75.   switch(snake.dir) {
  76.     case RIGHT:
  77.           snake.x[0] += 4;
  78.           if(snake.x[0]>=101) {
  79.             snake.x[0] = 1;
  80.           } break;
  81.     case UP:
  82.           snake.y[0] -= 4;
  83.           if(snake.y[0]<=1) {
  84.             snake.y[0] = 58;
  85.           } break;
  86.     case LEFT:
  87.           snake.x[0] -= 4;
  88.           if(snake.x[0]<=0) {
  89.             snake.x[0] = 97;
  90.           } break;
  91.     case DOWN:
  92.           snake.y[0] += 4;
  93.           if(snake.y[0]>=62) {
  94.             snake.y[0] = 2;
  95.           } break;
  96.   }
  97.
  98.   if((snake.x[0] == food.x) && (snake.y[0] == food.y)) {
  99.     snake.x[0] = food.x;
  100.     snake.y[0] = food.y;
  101.
  102.     snake.node++;
  103.     food.yes = 1;
  104.     score += 2;
  105.     level = score/10+1;
  106.   }
  107.   for(i=snake.node-1;i>0;i--) {
  108.     snake.x[i] = snake.x[i-1];
  109.     snake.y[i] = snake.y[i-1];
  110.   }
  111. }
  112. void setup() {
  113.   pinMode(2, INPUT);
  114.   pinMode(3, INPUT);
  115.   pinMode(4, INPUT);
  116.   pinMode(5, INPUT);
  117.
  118.   digitalWrite(2, HIGH);
  119.   digitalWrite(3, HIGH);
  120.   digitalWrite(4, HIGH);
  121.   digitalWrite(5, HIGH);
  122. }
  123. void loop() {
  124.   u8g.firstPage();
  125.   do {
  126.     UI();
  127. ……………………
  128. …………限于本文篇幅 余下代碼請從51黑下載附件…………
7Pin0.96 SPIsnake_arduino.rar (453.49 KB, 下載次數: 32)
ID:525651 發表于 2019-5-1 17:25 | 顯示全部樓層
不錯哦,學習一下
ID:471632 發表于 2019-5-1 22:10 | 顯示全部樓層
我手上的是iic通訊的oled 0.96
