這個是我程序代碼,圖上R11最后要換成光敏電阻,意思是我無光的時候,分壓很低,P1口能判斷為低電平即可。
#include<AT89X52.h>
#define KeyPort P1
unsigned char High,Low; //定時器預裝高低八位
sbit SPK=P3^7; //蜂鳴器
sbit ps=P0^0; //蜂鳴器
sbit RS=P2^0; //暫時無用
sbit RW=P2^1; //暫時無用
unsigned char code freq[][2]={ //音階頻率
0xD8,0XF7,
0xBD,0XF8,
0x87,0xF9,
0xE4,0xF9,
0x90,0xFA,
0x29,0xFB,
0xB1,0xFB,
0xEF,0xFB,
unsigned char Time;
unsigned char code YINFU[9][1]={{'0'},{'1'},{'2'},{'3'},{'4'},{'5'},{'6'},{'7'},{'8'}};
unsigned char MUSIC[]={6,2,3, 5,2,1, 3,2,2 , 5,2,2, 1,3,2, 6,2,1, 5,2,1,
6,2,4, 3,2,2, 5,2,1, 6,2,1, 5,2,2, 3,2,2, 1,2,1,
6,1,1, 5,2,1, 3,2,1, 2,2,4, 2,2,3, 3,2,1, 5,2,2,
5,2,1, 6,2,1, 3,2,2, 2,2,2, 1,2,4, 5,2,3, 3,2,1,
2,2,1, 1,2,1, 6,1,1, 1,2,1, 5,1,6, 0,0,0};
unsigned char code FREQH[ ]={0xF2,0xF3,0xF5,0xF5,0xF6,0xF7,0xF8,
0xF9,0xF9,0xFA,0xFA,0xFB,0xFB,0xFC,0xFC,
0xFC,0xFD,0xFD,0xFD,0xFD,0xFD,0xFE,
0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,
unsigned char code FREQL[ ]={0x42,0xC1,0x17,0xB6,0xD0,0xD1,0xB6,
0x21,0xE1,0x8C,0xD8,0x68,0xE9,0x5B,0x8F,
0xEE,0x44,0x6B,0xB4,0xF4,0x2D,
0x47,0x77,0xA2,0xB6,0xDA,0xFA,0x16,
void Init_timer0(void); //定時器初始化
void delay2xus(unsigned char z) //延時
while(z--);
void delayms(unsigned char x) //延時
while(x--)
delay2xus(245);
delay2xus(245);
void delaytips(unsigned char t) //延時
unsigned char i;
for(i=0;i<t;i++)
delayms(250);
TR0=0;
void PlaySong()
TH0=High;
TL0=Low;
TR0=1;
delaytips(Time);
void Init_Timer0(void) //定時器初始化
TMOD |=0x01;
EA=1;
ET0=1;
void Timer0_isr(void)interrupt 1 //定時中斷
TH0=High;
TL0=Low;
SPK=!SPK;
int main(void) //主函數
unsigned char num,k,i;
Init_Timer0();
SPK=0;
switch(KeyPort) //P1口判斷,是否有低電平
case 0xfe:num=1;break;
case 0xfd:num=2;break;
case 0xfb:num=3;break;
case 0xf7:num=4;break;
case 0xef:num=5;break;
case 0xdf:num=6;break;
case 0xbf:num=7;break;
case 0x7f:num=8;break;
default:num=0;break;
P2=KeyPort; //暫時無用
if(num==0)
TR0=0;
SPK=0;
High=freq[num-1][1];
Low=freq[num-1][0];
TR0=1;
if(ps==0)
delayms(10);
if(ps==0)
i=0;
while(i<100)
k=MUSIC[i]+7*MUSIC[i+1]-1;
High=FREQH[k];
Low=FREQL[k];
Time=MUSIC[i+2];
i=i+3;
if(P1!=0xff)
delayms(10);
if(P1!=0xff)
i=101;
PlaySong();
TR0=0;
