#include<reg52.h>
//#define S1 3 ; //S1 開關(guān)返回的數(shù)值
//#define Request 1; //請(qǐng)求開關(guān)返回的值
sfr P5=0xc8; //#define Over 2; //結(jié)束開關(guān)返回的值
#define table P1
sbit gewei=P2^6; //數(shù)碼管個(gè)位
sbit shiwei=P0^0; //P5^5; 數(shù)碼管十位
sbit LED1=P2^7;
sbit LED2=P2^5;
sbit Bell=P0^1; //P5^4;
sbit OutCrtl=P3^7; //繼電器開關(guān)
sbit PowerCrtl=P3^2;
sbit S1_K=P2^4;
sbit Request_K = P3^3;
sbit Over_K=P3^4;
unsigned int min=30; //秒
unsigned int gw ;
unsigned int sw ;
unsigned int num;
unsigned char Code[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
int Key_Press(); //按鍵掃描
void Delay_Ms(unsigned int ); //延時(shí)1MS
void LED_BELL()
int i=0;
for(i;i<5;i++)
{ LED1=0;
LED2=0;
Bell=1;
Delay_Ms(10);
LED1=1;
LED2=1;
Bell=0;
void Display()
gw=min%10;
sw=min/10;
gewei=0;
P1=Code[gw];
Delay_Ms(2);
shiwei=0;
P1=Code[sw];
if(min==0)
EA=1;
int Key_Press()
if(S1_K==0)
Delay_Ms(2);
if(S1_K==0)
return 3;
if(Request_K==0)
Delay_Ms(2);
if(Request_K==0)
return 1;
if(Over_K==0)
Delay_Ms(2);
if(Over_K==0)
return 2;
//組要計(jì)數(shù)的個(gè)數(shù)N=t/T(機(jī)器周期)
//機(jī)器周期=12*(時(shí)鐘周期)1/晶振頻率
void Delay_1Ms(unsigned int n)
unsigned int i,j;
for(j=n;j>0;j--)
for(i=112;i>0;i--);
// 晶振按12MHZ計(jì)算
void T1_Init()
TMOD=0x10;
TL1= (65536-50000)%256; //50000*10^-6=0.5s
TH1= (65536-50000)/256; //1MHZ=10^6HZ ; 1/f=1us
ET1= 1;
TR1= 1;
EA= 1;
int main()
int K_Date;
T1_Init();
K_Date=Key_Press();
if(K_Date=1)
Display();
LED_BELL();
if(K_Date==3)
OutCrtl=1;
if(Over_K==2)
gewei=0;
shiwei=0;
LED1=1;
LED2=1;
Bell=0;
OutCrtl=0;
void TimerCounter_1(void) interrupt 3
num++;
if(num==20)
num=0
min--;
