查看: 804|回復: 0
明遠智睿R16 android4.4 常見問題參考手冊
ID:295355 發(fā)表于 2019-3-18 16:44 | 顯示全部樓層 |閱讀模式
本帖最后由 明遠智睿 于 2019-3-18 16:46 編輯
1  R16 android4.4 常見問題
1.1  在內(nèi)核中添加spi驅(qū)動
$cd lichee/linux-3.4 $make ARCH=arm menuconfig $lunch astar_parrot-tina
$make kernel_menuconfig
Device Drivers ---> SPI support ---> <*> User mode SPI device driver support
修改
lichee/tools/pack/chips/sun8iw5p1/configs/evb-30/sys_config.fex
[spi_board0]
modalias      = "at25df641"
sflash_size   = 32
max_speed_hz  = 50000000
bus_num       = 0
chip_select   = 0
mode          = 0
修改成
[spi_board0]
modalias      = "spidev"
sflash_size   = 32
bus_num       = 0
chip_select   = 0
mode          = 0
1.2  以太網(wǎng)不能用
在內(nèi)核增加驅(qū)動
Device Drivers --->
   Network device support --->
       USB Network Adapters --->
              <*> Multi-purpose USB Networking Frameworksuch as cable modems)
              <*> SMSC LAN95XX based USB 2.0 10/100 ethernet devices
1.3  默認勾選使用以太網(wǎng)
1)在frameworks\base\packages\SettingsProvider\res\values\default.xml
  <bool name="def_ethernet_on">true</bool>  改成true
  <bool name="def_ethernet_mode">true</bool> 添加以下這兩句
     <bool name="def_ethernet_conf">true</bool>
      <string name="def_ethernet_ifname" translatable="false">eth0</string>
2)在frameworks\base\packages\SettingsProvider\src\com\android\providers\settings\DatabaseHelper.java 添加
       loadBooleanSetting(stmt, Settings.Global.ETHERNET_CONF, R.bool.def_ethernet_conf)
       loadStringSetting(stmt, Settings.Global.ETHERNET_IFNAME, R.string.def_ethernet_ifname)
