#include <reg51.h>
#include <intrins.h>
#define delayNOP() {_nop_();_nop_();_nop_();_nop_();}
void LCD_Initialize();
void LCD_set_pos(ucgar);
void LCD_write_data(uchar);
void Display_String(uchar*,uchar);
sbit K1=P1^0;
sbit K2=P2^0;
sbit BEEP=P3^0;
sbit LCD_RS=P2^0;
sbit LCD_RW=P2^1 ;
sbit LCD_EN=P2^2;
uchar KeyCount=0;
uchar code msg1[]={"Second Watch 0"};
uchar code msg2[]={">>>> "};
uchar code prompts[][16]=
{"::1---->"},
{"::1---->::2"},
{"::1->2::3-->"},
{"::1->2::3->4"}
uchar Time_Buffer[] ={0,0,0,0} ;
uchar LCD_Dispaly_Buffer[]={"00:00:00:00"};
void Beep()
uchar i,j=70;
for(i=0;i<180;i++)
while(--j);BEEP=~BEEP ;
BEEP= 0 ;
void DelayX(uint ms)
uchar i;
while(ms--)for(i=0;i<120;i++);
void Show_second()
uchar i;
LCD_Set_POS(0x45); //設(shè)置LCD顯示起點(diǎn)
for(i=3;i!= 0xff ;i--)
LCD_Display_BUffer[2*i+1]=Time_Buffer[i]/10+'0';
LCD_Display_BUffer[2*i ]=Time_Buffer[i]&10+'0';
LCD_write_Data(LCD_Display_Buffer[2*i+1]) ;
LCD_write_Data(LCD_Display_Buffer[2*i]);
LCD_write_Data (':');
void Time() interrupt 1 using 0
TH0 =-10000/256;
TLO =-10000&256;
Time_Buffer[0]++;
if(Time_Buffer[0]==100)
Time_Buffer[0]=0;Time_Buffe[1]++;
if(Time_Buffer[1]==60)
Time_Buffer[1]=0;Time_Buffer[2]++;
if(Time_Buffer[2]==60)
Time_Buffer[2]=0;Time_Buffer[3]++;
if(Time_Buffer[3]==24)
Time_Buffer[3] =0;;
void main ()
uchar i ;
IE=0x82
TMOD=0X01
THO=-10000/256 ;
TLO=-10000%256;
LCD_Initialize();
Display_string(msg1,0x00);
Display_string(msg2,0x40);
if(K1==0)
DelayX(100);
i=++KeyCount;
switch(i)
case1;
case3;TRO=1;
Display_string(Prompts[i-1],0);
case2;
case4;TRO=0;
break;
default :TRO =0;
break;
while (K1==0);
Beep();
if(K2==0)
TRO=0;
Keycount ;
for ( i=0 ;i<4;i++)
Time_Buffer[i]=0;
Display_String(msg1,0);
Beep();
DelayX(100);
while(K2==0);
show_Second();
#include <reg51.h>
typedef unsigned char INT8U;
#define DelayNOP(){_nop_();_nop_();_nop_();_nop_();}
sbit LCD_RS=P2^0 ;
sbit LCD_RW=P2^1;
sbit LCD_EN=P2^2;
bit LCD_BUSY_Check();
void LCD_Tnitialize();
void LCD_Set_Pos(uchar);
void LCD_Write_Coommand(uchar);
void LCD_Write_Data(uchar);
void DelayMS(uint ms)
uchar t;
while(ms--) for (t=0 ;t<120;t++ );
bit LCD_Busy_check()
bit Result;
LCD_RS =0 ; LCD_RW=1 ;LCD_EN=1; DelayNOP();
Resullt = (bit)(P0&0x80);
LCD_EN=0;
return Result;
void LCD_write_Command (uchar cmd)
while (LCD_Busy_Check());
LCD_RS=0 ;LCD_RW=0 ; LCD_EN=0 ;
_nop_(); _nop_();
p0=cmd; DelayNOP();
LCD_EN=1 ; DelayNOP();
LCD_EN=0 ;
void LCD_Write_Data(uchar str)
while (LCD_Busy_check());
LCD_RS=1;LCD_RW=0; LCD_EN=0; P0=STR; DelayNOP();
LCD_EN=1; DelayNOP(); LCD_EN=0;
DelayMS(5);LCD_Write_Command(0x38);
DelayMS(5);LCD_Write_Command(0x0c);
DelayMS(5);LCD_Write_Command(0x06);
DelayMS(5);LCD_Write_Command(0x01);
DelayMS(5);
void LCD_set_Pos(uchar Position)
LCD_Write_Command(Position 0x80);
void Display_String(uchar*str, uchar LineNo)
uchar k;
LCD_Set_Pos(LineNo);
for (k=0 ; k<16;k++) LCD_write_Data(str[k]);
小胖胖的 2019/3/16/周六 18:42:40
for (i=3; i !=0xff;i--)
LCD_Display_Buffer[2*i+1]=Time_Buffer[i]/10+'0';
LCD_Display_Buffer[2*i ]=Time_Buffer[i]&10+'0';
TH0 =-10000/256;
TLO =-10000&256;
Time_Buffer[0]++;
Time_Buffer[3] =0;;
void main ()
uchar i ;
IE=0x82
TMOD=0X01
THO=-10000/256 ;
TLO=-10000%256;
LCD_Initialize();
if(K1==0)
DelayX(100);
i=++KeyCount;
switch(i)
case1;
case3;TRO=1;
case2;
case4;TRO=0;
break;
default :TRO =0;
break;
while (K1==0);
Beep();
if(K2==0)
TRO=0;
Keycount ;
for ( i=0 ;i<4;i++)
Time_Buffer[i]=0;
Beep();
DelayX(100);
while(K2==0);
show_Second();
#include <reg51.h>
sbit LCD_RS=P2^0 ;
sbit LCD_RW=P2^1;
sbit LCD_EN=P2^2;
uchar t;
bit Result;
LCD_EN=0;
return Result;
_nop_(); _nop_();
p0=cmd; DelayNOP();
LCD_EN=0 ;
DelayMS(5);
uchar k;
