可以實現萬年歷的基本功能,基于八位數碼管的程序,可切屏,內含功能鍵。C語言小白,多有不成熟之處,望諒解。
以下是電路圖:
1
2019-3-23 20:25 上傳
3
2019-3-23 20:25 上傳
以下是所需元器件:
2019-3-23 20:31 上傳
2019-3-23 20:31 上傳
單片機源程序:
#include<reg52.h>
void delay(uint);
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
sbit s4=P3^3;
sbit beep=P3^7;
uint nian;
uchar count=0;
uchar zhou,yue,ri,shi,fen,miao,anao,bnao,cnao;
uchar s1num=0;
uchar s2num=1;
uchar nian1,nian2,nian3,nian4,yue1,yue2,ri1,ri2;
uchar nao1,nao2,nao3,nao4,nao5,nao6;
uchar shi1,shi2,fen1,fen2,miao1,miao2;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f};
void delay(uint xms)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void di()
beep=0;
delay(1);
beep=1;
void rili() //顯示日歷
nian1=nian/1000;
nian2=nian%1000/100;
nian3=nian%100/10;
nian4=nian%10;
yue1=yue/10;
yue2=yue%10;
ri1=ri/10;
ri2=ri%10;
P2=0x1c;
P0=table[nian1];
delay(1);
P2=0x18;
P0=table[nian2];
delay(1);
P2=0x14;
P0=table[nian3];
delay(1);
P2=0x10;
P0=table[nian4];
delay(1);
P2=0x0c;
P0=table[yue1];
delay(1);
P2=0x08;
P0=table[yue2];
delay(1);
P2=0x04;
P0=table[ri1];
delay(1);
P2=0x00;
P0=table[ri2];
delay(1);
void shijian() //顯示時間
shi1=shi/10;
shi2=shi%10;
fen1=fen/10;
fen2=fen%10;
miao1=miao/10;
miao2=miao%10;
P2=0x1c;
P0=table[shi1];
delay(1);
P2=0x18;
P0=table[shi2];
delay(1);
P2=0x14;
P0=0x80;
delay(1);
P2=0x10;
P0=table[fen1];
delay(1);
P2=0x0c;
P0=table[fen2];
delay(1);
P2=0x08;
P0=0x80;
delay(1);
P2=0x04;
P0=table[miao1];
delay(1);
P2=0x00;
P0=table[miao2];
delay(1);
void nao() //顯示鬧鐘
nao1=anao/10;
nao2=anao%10;
nao3=bnao/10;
nao4=bnao%10;
nao5=cnao/10;
nao6=cnao%10;
P2=0x1c;
P0=table[nao1];
delay(1);
P2=0x18;
P0=table[nao2];
delay(1);
P2=0x14;
P0=0x80;
delay(1);
P2=0x10;
P0=table[nao3];
delay(1);
P2=0x0c;
P0=table[nao4];
delay(1);
P2=0x08;
P0=0x80;
delay(1);
P2=0x04;
P0=table[nao5];
delay(1);
P2=0x00;
P0=table[nao6];
delay(1);
void xingqi() //顯示星期
P2=0x1c;
P0=table[zhou];
void run()
if(nian%400==0||nian%100!=0&&nian%4==0)
if(yue==2)
ri++;
if(ri==30)
ri=1;
yue++;
void zhoubian()
uint yue1,nian1; /星期數隨著年月日的變化自行改變
yue1=yue;
nian1=nian;
if(yue==1||yue==2)
yue1=yue+12;
nian1=nian-1;
zhou=(ri+2*yue1+3*(yue1+1)/5+nian1+nian1/4-nian1/100+nian1/400)%7+1;
void timer0()interrupt 1 //中斷
TH0=(65534-50000)/256;
TL0=(65534-50000)%256;
count++;
if(count==20)
count=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
zhou++;
if(zhou==8)
zhou=1;
if(yue==4||yue==6||yue==9||yue==11) //在小月的前提
ri++;
if(ri==31)
ri=1;
yue++;
if(yue==1||yue==3||yue==5||yue==7||yue==8||yue==10||yue==12) //在大月的前提
ri++;
if(ri==32)
ri=1;
yue++;
run();
if(nian%4!=0||nian%400==0)
if(yue==2)
ri++;
if(ri==29)
ri=1;
yue++;
if(yue==13)
yue=1;
nian++;
if(zhou==7)
zhou=0;
if(shi==anao&&fen==bnao&&miao>=cnao)
di();
void init()
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)/256;
EA=1;
ET0=1;
TR0=1; //開啟定時器
nian=2019;
yue=11;
ri=27;
shi=0;
fen=0;
miao=0;
anao=0;
bnao=0;
cnao=0;
void tiaobnao()
if(s3==0)
delay(5);
if(s3==0)
bnao++;
while(!s3);
if(bnao==60)
bnao=0;
if(s4==0)
delay(5);
if(s4==0)
bnao--;
while(!s4);
if(bnao==-1)
bnao=59;
void tiaoanao()
if(s3==0)
delay(5);
if(s3==0)
anao++;
while(!s3);
if(anao==24)
anao=0;
if(s4==0)
delay(5);
if(s4==0)
anao--;
while(!s4);
if(anao==-1)
anao=23;
void tiaofen()
if(s3==0)
delay(5);
if(s3==0)
fen++;
while(!s3);
if(fen==60)
fen=0;
if(s4==0)
delay(5);
if(s4==0)
fen--;
while(!s4);
if(fen==-1)
fen=59;
void tiaoshi()
if(s3==0)
delay(5);
if(s3==0)
shi++;
while(!s3);
if(shi==24)
shi=0;
if(s4==0)
delay(5);
if(s4==0)
shi--;
while(!s4);
if(shi==-1)
shi=23;
void dzhx() //大月轉小月
if(ri==31)
ri=30;
void dxtpr() //大小月調平潤 月
if(ri==30||ri==31)
if(yue==2)
ri=28;
ri=29;
void rzhp() //特殊年份調整
if(ri==29)
if(yue==2)
if(nian%4!=0||nian%400==0) //當是平年時
ri=28;
void tiaori()
if(s3==0)
delay(5);
if(s3==0)
ri++;
while(!s3);
if(ri==31)
ri=1;
ri++;
while(!s3);
if(ri==32)
ri=1;
if(nian%400==0||nian%100!=0&&nian%4==0) //當是閏年時二月運行
if(yue==2)
ri++;
while(!s3);
if(ri==30)
ri=1;
if(yue==2) //當是平年時二月運行
ri++;
while(!s3);
if(ri==29)
ri=1;
if(s4==0)
delay(5);
if(s4==0)
ri--;
while(!s4);
if(ri==-1)
ri=30;
ri--;
while(!s4);
if(ri==-1)
ri=31;
if(yue==2)
ri--;
while(!s4);
if(ri==-1)
ri=29;
ri--;
while(!s4);
if(ri==-1)
ri=28;
void tiaozhou()
zhoubian();
if(s3==0)
delay(5);
if(s3==0)
zhou++;
if(zhou==8)
zhou=1;
while(!s3);
if(s4==0)
delay(5);
if(s4==0)
zhou--;
if(zhou==0)
zhou=7;
while(!s4);
void tiaoyue()
if(s3==0)
delay(5);
if(s3==0)
yue++;
if(yue==13)
yue=1;
while(!s3);
if(s4==0)
delay(5);
if(s4==0)
yue--;
if(yue==0)
yue=12;
while(!s4);
dxtpr();
dzhx();
void tiaonian()
if(s3==0)
delay(5);
if(s3==0)
nian++;
while(!s3);
if(s4==0)
delay(5);
if(s4==0)
nian--;
while(!s4);
rzhp();
void keyscan() //按鍵
if(s1==0)
delay(5);
if(s1==0)
s1num++;
while(!s1);
switch(s1num)
case 0:
shijian();
break;
case 1:
rili();
break;
case 2:
xingqi();
break;
case 3:
nao();
break;
case 4:
s1num=0;
break;
void qie()
if(s2==0)
delay(5);
if(s2==0)
s2num++;
while(!s2);
if(s1num==0)
switch(s2num)
case 1:
tiaofen();
break;
case 2:
tiaoshi();
break;
case 3:
s2num=0;
break;
if(s1num==1)
switch(s2num)
case 1:
tiaori();
break;
case 2:
tiaoyue();
break;
case 3:
tiaonian();
break;
case 4:
s2num=0;
break;
if(s1num==2)
tiaozhou();
if(s1num==3)
switch(s2num)
case 1:
tiaoanao();
break;
case 2:
tiaobnao();
break;
case 3:
s2num=0;
break;
void main() //新作
init();
keyscan();
qie();
