查看: 1687|回復: 1
MDA通道的ADC采集穩壓程序
ID:293438 發表于 2019-3-15 11:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "adc.h"
#include "delay.h"
#define ADC1_DR_Address((u32) 0x40012400 + 0x4c) __IO uint16_t ADC_ConvertedValue[202][4];
void ADC1_GPIO_Config(void) {
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
    GPIO_Init(GPIOA, & GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
void ADC1_Mode_Config(void) {
    DMA_InitTypeDef DMA_InitStructure;
    ADC_InitTypeDef ADC_InitStructure;
    RCC_ADCCLKConfig(RCC_PCLK2_Div6);
    DMA_DeInit(DMA1_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32) & ADC_ConvertedValue;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_BufferSize = 4 * 200;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel1, & DMA_InitStructure);
    DMA_Cmd(DMA1_Channel1, ENABLE);
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_InitStructure.ADC_ScanConvMode = ENABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfChannel = 4;
    ADC_Init(ADC1, & ADC_InitStructure);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 2, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 3, ADC_SampleTime_239Cycles5);
    ADC_DMACmd(ADC1, ENABLE);
    ADC_Cmd(ADC1, ENABLE);
    ADC_ResetCalibration(ADC1);
    while (ADC_GetResetCalibrationStatus(ADC1));
    ADC_StartCalibration(ADC1);
    while (ADC_GetCalibrationStatus(ADC1));
    ADC_SoftwareStartConvCmd(ADC1, ENABLE)
void ADC1_Init() {
    ADC1_GPIO_Config();
    ADC1_Mode_Config()
#include "PWM.h"
static void TIM3_GPIO_Config(void) {
    GPIO_InitTypeDef GPIO_Initstructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
    GPIO_Initstructure.GPIO_Pin = GPIO_Pin_6;
    GPIO_Initstructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Initstructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOA, & GPIO_Initstructure)
static void TIM3_Mode_Config(void) {
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
    TIM_OCInitTypeDef TIM_OCInitStructure;
    TIM_TimeBaseStructure.TIM_Period = 2879;
    TIM_TimeBaseStructure.TIM_Prescaler = 0;
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM3, & TIM_TimeBaseStructure);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_Pulse = 0;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OC1Init(TIM3, & TIM_OCInitStructure);
    TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
    TIM_ARRPreloadConfig(TIM3, ENABLE);
    TIM_Cmd(TIM3, ENABLE)
void TIM3_PWM_Init(void) {
    TIM3_GPIO_Config();
    TIM3_Mode_Config()
include "delay.h"#
include "sys.h"#
include "usart.h"#
include "led.h"#
include "key.h"#
include "adc.h"#
include "PWM.h"#
include "oled.h"#
include "keyboard.h"#
include "Pid.h"
int main(void) {
    PID PID_InitStructure;
    double rOut;
    double rIn;
    delay_init();
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    uart_init(115200);
    LED_Init();
    ADC1_Init();
    TIM3_PWM_Init();
    OLED_Init();
    OLED_Clear();
    Key_GPIO_Configuration();
    PIDInit( & PID_InitStructure);
    PID_InitStructure.SetPoint = S;
    PID_InitStructure.Proportion = P;
    PID_InitStructure.Integral = I;
    PID_InitStructure.Derivative = D;
    TIM3 - > CCR1 = 1440;
    OLED_ShowString(110, 0, "mV", 16);
    while (1) {
        Key_Deal_With();
        angler_mV();
        PID_InitStructure.Proportion = Set_P;
        PID_InitStructure.SetPoint = sss_num * 1000;
        rIn = get_mV[1];
        rOut = PIDCalc( & PID_InitStructure, rIn);
        PWM_Out(rOut);
        OLED_ShowNum(0, 4, D * 1000, 4, 16);
        OLED_ShowNum(40, 6, TIM3 - > CCR1, 4, 16)
ID:1 發表于 2019-3-16 01:10 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
