            查看: 1819|回復(fù): 1
            為什么這個單片機(jī)數(shù)碼管程序出現(xiàn)個位頻閃?
            ID:490966 發(fā)表于 2019-3-14 19:04 | 顯示全部樓層 |閱讀模式
            1. #include <reg52.h>
            2. #include <intrins.h>
            4. #define uint unsigned int
            5. uint a,b,c,d,e,f,g;
            6. uchar temp,ge,shi;
            7. sbit wei = P2^7;
            8. sbit duang=P2^6;
            9. uchar code leddata[]={
            10.                 0x3F,  //"0"
            11.                 0x06,  //"1"
            12.                 0x5B,  //"2"
            13.                 0x4F,  //"3"
            14.                 0x66,  //"4"
            15.                 0x6D,  //"5"
            16.                 0x7D,  //"6"
            17.                 0x07,  //"7"
            18.                 0x7F,  //"8"
            19.                 0x6F,  //"9"
            20.                 0x77,  //"A"
            21.                 0x7C,  //"B"
            22.                 0x39,  //"C"
            23.                 0x5E,  //"D"
            24.                 0x79,  //"E"
            25.                 0x71,  //"F"
            26.                 0x76,  //"H"
            27.                 0x38,  //"L"
            28.                 0x37,  //"n"
            29.                 0x3E,  //"u"
            30.                 0x73,  //"P"
            31.                 0x5C,  //"o"
            32.                 0x40,  //"-"
            33.                 0x00,  //熄滅
            34.                 0x00  //自定義
            35.                          };
            36. void delay();
            37. void delay(uint z)
            38. {
            39.   for(a = z;a > 0;a--)
            40.     for(b = 114;b > 0;b--);
            41. }
            42. void dishzhdu()
            43. {
            44.          TMOD=0x10;
            45.          TH1 =0x4b;
            46.          TL1 =0xfd;
            47.          TR1 = 1;        //50MS
            48.          EA  = 1;
            49.          ET1 = 1;
            50.
            51. }
            52. void wabuzhdu()
            53. {
            54.         EX0 = 1;
            55.         IT0 = 0;
            56.         EA  = 1;
            57.         TMOD=0x01;
            58.         TH0 =0x4b;
            59.         TL0 =0xfd; //50ms
            60.         TR0 = 1;
            61. }
            62. void display(uint f )
            63. {  ge = f%10;
            64.    shi= f/10;
            65.    P0 = 0xff;
            66.    wei= 1;
            67.    P0 = 0xfd;
            68.    wei= 0;
            69.    duang= 1;
            70.    P0 = leddata[ge];
            71.    duang= 0;
            72.    delay(1);
            73.    P0 = 0xff;
            74.    wei= 1;
            75.    P0 = 0xfe;
            76.    wei= 0;
            77.    duang= 1;
            78.    P0 = leddata[shi];
            79.    duang= 0;
            80.    delay(1);
            81. }
            82. void main()
            83. {
            84.     temp = 0xfe;
            85.         P1 = temp;
            86.         dishzhdu();
            87.         wabuzhdu();
            88.   while (1)
            89.    {  TR0 = 1;
            90.              if(TF0 == 1)
            91.           {         TH0 =0x4b;
            92.              TL0 =0xfd;
            93.                    TF0 = 0;
            94.                  c++;
            95.                 if(c == 20)
            96.            {
            97.                       c = 0;
            98.                         d++;
            99.                         if(d >= 90)
            100.                         {
            101.                            d = 0;
            102.                         }
            103.                         display(d);
            104.             }
            105.       }
            106.
            107.
            108. }
            109. }
            110. void dszd0() interrupt 3
            111. {
            112.                    TH1 =0x4b;
            113.             TL1 =0x7d;
            114.                 e++;
            115.
            116.                  if(e == 10)
            117.                  {
            118.                          e = 0;
            119.                         temp = _cror_(temp,1);
            120.                          P1 = temp;
            121.                  }
            122. }
            123. void wbzd() interrupt 0
            124. {
            125.         TR0 = 0;
            126.         delay(1);
            127. }
            ID:96682 發(fā)表于 2019-3-14 21:52 | 顯示全部樓層
            顯示沒處理好就這結(jié)果
