查看: 2693|回復: 1
循跡蔽障定點停車Arduino程序
ID:490217 發表于 2019-3-13 20:46 | 顯示全部樓層 |閱讀模式
#include <Servo.h>  //servo library
Servo myservo;      // create servo object to control servo
int Echo = A4;
int Trig = A5;
#define LT_R !digitalRead(10)
#define LT_M !digitalRead(4)
#define LT_L !digitalRead(2)
#define ENA 5
#define ENB 6
#define IN1 7
#define IN2 8
#define IN3 9
#define IN4 11
#define carSpeed 150
int rightDistance = 0, leftDistance = 0, middleDistance = 0;
void forward(){
  analogWrite(ENA, 150);
  analogWrite(ENB, 150);
  digitalWrite(IN1, HIGH);
  digitalWrite(IN2, LOW);
  digitalWrite(IN3, LOW);
  digitalWrite(IN4, HIGH);
  Serial.println("Forward");
void back() {
  analogWrite(ENA, carSpeed);
  analogWrite(ENB, carSpeed);
  digitalWrite(IN1, LOW);
  digitalWrite(IN2, HIGH);
  digitalWrite(IN3, HIGH);
  digitalWrite(IN4, LOW);
  Serial.println("Back");
void left() {
  digitalWrite(ENA,HIGH);
  digitalWrite(ENB,HIGH);
  //analogWrite(ENA, 300);
  //analogWrite(ENB, 300);
  Serial.println("Left");
void right() {
// analogWrite(ENB, 300);
  digitalWrite(IN1,HIGH);
  digitalWrite(IN2,LOW);
  digitalWrite(IN3,HIGH);
  digitalWrite(IN4,LOW);
  Serial.println("Right");
void stop() {
  digitalWrite(ENA, LOW);
  digitalWrite(ENB, LOW);
  Serial.println("Stop!");
void sright(){
  analogWrite(ENA, 250);
  analogWrite(ENB, 250);
  Serial.println("go right!");
void sleft(){
//Ultrasonic distance measurement Sub function
int Distance_test() {
  digitalWrite(Trig, LOW);
  delayMicroseconds(2);
  digitalWrite(Trig, HIGH);
  delayMicroseconds(20);
  float Fdistance = pulseIn(Echo, HIGH);
  Fdistance= Fdistance / 58;
  return (int)Fdistance;
void longtracking()
            for(int i=0;i<125;i++)
    forward();
    delay(5);
    if(LT_L)
      sleft();
      while(LT_L);
    else if(LT_R)
       sright();
      while(LT_R);
    if(LT_L&<_R&<_M)
      forward();
      delay(40);
      break;
void turnleft()
void longtracking2()
            for(int i=0;i<130;i++)
    forward();
    delay(5);
    if(LT_L)
      sleft();
      while(LT_L);
    else if(LT_R)
       sright();
      while(LT_R);
    if(LT_L&<_R&<_M)
      forward();
      delay(40);
      break;
void shorttracking()
  for(int i=0;i<83;i++)
    forward();
    delay(5);
    if(LT_L)
      sleft();
      while(LT_L);
    else if(LT_R)
       sright();
      while(LT_R);
    if(LT_R&<_L&<_M)
      forward();
      delay(40);
      break;
void setup() {
  myservo.attach(3);  // attach servo on pin 3 to servo object
  Serial.begin(9600);
  pinMode(Echo, INPUT);
  pinMode(Trig, OUTPUT);
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  pinMode(IN3, OUTPUT);
  pinMode(IN4, OUTPUT);
  pinMode(ENA, OUTPUT);
  pinMode(ENB, OUTPUT);
  stop();
int x=2;
int y=0;
int dx=1;
int dy=3;
int fuck=0;
void loop()
  if(fuck==0)
        forward();
        while(!LT_L||!LT_R||!LT_M)
          if(LT_R&<_L&<_M)
            break;
        delay(60);
        stop();
        fuck++;
  if(x==1&&y!=3)                      //中間點
    delay(100);
    middleDistance = Distance_test();
    if(middleDistance<25)
          stop();
          delay(300);
          right();
          delay(100);
          while(!LT_R);
          stop();
          delay(300);
          if(y==0)
shorttracking();
             stop();
          delay(300);
          left();
          delay(100);
          while(!LT_L);
          stop();
          delay(300);
          x++;
    delay(100);
              left();
                        delay(100);
          while(!LT_L);
          stop();
          delay(300);
              stop();
              delay(200);
shorttracking();
              stop();
              delay(200);
shorttracking();
              stop();
              delay(200);
          right();
          delay(100);
          while(!LT_R);
          stop();
          delay(300);
              x--;
              x--;
        /*  else
            stop();
            delay(200);
            longtracking();
            stop();
            delay(200);
            shorttracking();            //此處短途迅即
             stop();
             delay(300);
             left();
             delay(100);
          while(!LT_L);
          stop();
          delay(300);
             x++;
    delay(100);
              left();
              delay(100);
              while(!LT_L);
              stop();
              delay(200);
              shorttracking();
              stop();
              delay(200);
              shorttracking();
              stop();
              delay(200);
              x--;
              x--;
                        right();
          delay(100);
          while(!LT_R);
          stop();
          delay(300);
      stop();
      delay(200);
      longtracking2();
      stop();
      delay(300);
      y++;
  else if(x==0&&y!=3)
    delay(100);
          stop();
          delay(300);
          right();
          delay(100);
          while(!LT_R);
          stop();
          delay(300);
          if(y==0)
            forward();
            delay(520);
             stop();
          delay(300);
          left();
          delay(100);
          while(!LT_L);
          stop();
          delay(300);
          x++;
             stop();
             delay(300);
          left();
          delay(100);
          while(!LT_L);
          stop();
          delay(300);
             stop();
             delay(300);
             x++;
      stop();
      delay(200);
      longtracking();                  //zhongjianxunji
      stop();
      delay(300);
      y++;
  else if(x==2&&y!=3)
                delay(300);
              stop();
              delay(300);
              if(y==0)
              left();
              delay(100);
              while(!LT_L);
              stop();
              delay(300);
              forward();
              delay(520);
              right();
              delay(100);
              while(!LT_R);
              stop();
              delay(300);
              x--;
                              left();
              delay(100);
              while(!LT_L);
              stop();
              delay(300);
              shorttracking();
              right();
              delay(100);
              while(!LT_R);
              stop();
              delay(300);
              x--;
      stop();
      delay(200);
      longtracking();
      stop();
      delay(300);
      y++;
        if(y==3)
        int d;
        d=dx-x;
        if(d==0)
          stop();
          delay(300);
          forward();
          delay(400);
                    stop();
          delay(1000000);
        else if(d<0)
           stop();
          delay(300);
          left();
          delay(350);
          forward();
          delay(600);
           stop();
            delay(300);
           if(d==-2)
          forward();
          delay(600);
           stop();
          delay(300);
          right();
          delay(350);
          forward();
          delay(400);
          stop();
          delay(100000);
        else if(d>0)
           stop();
          delay(300);
          right();
          delay(353);
          forward();
          delay(600);
           stop();
          delay(300);
          if(d==2)
                     forward();
          delay(600);
          stop();
          delay(300);
          left();
          delay(350);
          stop();
          delay(300);
          forward();
          delay(400);
          stop();
          delay(10000000);
ID:1 發表于 2019-3-13 21:13 | 顯示全部樓層
樓主能分享下原理圖嗎?
