查看: 4488|回復: 1
MSP430F5529 MCU驅動LCD1602源碼
程序
  1. #include <msp430.h>
  2. #include <string.h>
  3. #include <LCD1602.h>
  4. #define CPU_F ((double)8000000)
  5. #define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
  6. #define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
  7. #define DataDir     P3DIR
  8. #define DataPort    P3OUT
  9. #define Busy        0x80
  10. #define CtrlDir     P1DIR
  11. #define CLR_RS P1OUT&=~BIT3;    //RS = P1.3
  12. #define SET_RS P1OUT|=BIT3;
  13. #define CLR_RW P1OUT&=~BIT4;    //RW = P1.4
  14. #define SET_RW P1OUT|=BIT4;
  15. #define CLR_EN P1OUT&=~BIT5;    //EN = P1.5
  16. #define SET_EN P1OUT|=BIT5;
  17. void Disp1Char(unsigned char data)
  18. {
  19.     LCD1602_WriteDATA(data);
  20. }
  21. void DispStr(unsigned char *ptr)
  22. {
  23.     unsigned char i,n;
  24.     n=strlen(ptr);
  25.     for (i=0;i<n;i++)
  26.     {
  27.         Disp1Char(ptr[i]);
  28.     }
  29. }
  30. void LCD1602_WriteCMD(unsigned char cmd)
  31. {
  32.         CLR_EN;
  33.         CLR_RS;     //指令
  34.         CLR_RW;     //寫
  35.         DataPort=cmd;   //指令數據傳到P0口待發送給LCD1602
  36.         delay_ms(1);
  37.         SET_EN;     //LCD1602使能口
  38.         delay_ms(10);
  39.         CLR_EN;     //產生下降沿
  40.         delay_ms(10);
  41. }
  42. void LCD1602_WriteDATA(unsigned char Data)
  43.     {
  44.         DataPort=Data;
  45.         SET_RS;
  46.         CLR_RW;
  47.         SET_EN;
  48.         CLR_EN;
  49.         delay_ms(10);
  50.     }
  51. void LCD1602_Initi()
  52.     {
  53.         CtrlDir |= 0x38;        //控制線端口設為輸出狀態
  54.         DataDir  = 0xff;
  55.         LCD1602_WriteCMD(0x38); //  置功能,8位總線,雙行顯示,顯示5X7的點陣字符
  56.         LCD1602_WriteCMD(0x0f); //  顯示開關控制,開顯示, 有光標,閃爍
  57.         LCD1602_WriteCMD(0x06); //  光標和顯示位置設置,  光標移動方向右移,屏幕上所有文字不動
  58.         LCD1602_WriteCMD(0x01); //  清顯示,指令碼01H,光標復位到地址00H位置
  59.         delay_ms(10);
  60.     }
workspace.zip (65.3 KB, 下載次數: 41)
ID:535188 發表于 2019-7-19 15:30 | 只看該作者
/LCD1602.c", line 24: warning #169-D: argument of type "unsigned char *" is incompatible with parameter of type "const char *"怎么處理
