查看: 2951|回復: 0
STM8L051F3寄存器版EEPROM源程序
ID:46381 發表于 2019-3-10 18:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "Config.h"
u8      Eeprom_text     =       0;
void EEPROM_write(unsigned char addr, unsigned char dat)
   u8 *Ptr_SegAddr; //Segment pointer
   Ptr_SegAddr = (u8 *)(EP_HEADER_ADDR+addr);  //Initialize  pointer
   FLASH_DUKR=0xAE;
   FLASH_DUKR=0x56;
   while(!FLASH_IAPSR_DUL);//如果DUL沒有置位,說明解鎖不成功,最好加入超時判斷
   asm("sim");//關閉中斷
   *Ptr_SegAddr=dat; //指定地址,寫1 字節
   while(!FLASH_IAPSR_EOP);//等待寫操作完成,最好加入超時判斷
   asm("rim");//打開中斷
   FLASH_IAPSR_DUL=0;//上鎖,對DATA EEPROM寫保護
//EEPROM指定地址讀出一個數據 addr:相對地址
unsigned char EEPROM_read(unsigned char addr)
   uint16_t Data=0;
   uint8_t *Ptr_SegAddr;
   Ptr_SegAddr = (uint8_t *)(EP_HEADER_ADDR+addr);  //Initialize  pointer
   Data=*Ptr_SegAddr;
   return Data;
