只需一步,快速開(kāi)始
查看: 4830|回復(fù): 1
51單片機(jī)模擬驅(qū)動(dòng)IIC顯示OLED
ID:486575 發(fā)表于 2019-3-7 21:44 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
主要核心代碼如下:
#include"oled.h"
#include"codetable.h"
/*********************OLED寫(xiě)數(shù)據(jù)************************************/
void delay(unsigned int z)
        unsigned int x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
//IIC Start
void IIC_Start()
   SCL = high;
   SDA = high;
   _nop_();
   SDA = low;
   _nop_();_nop_();
   SCL = low;
//IIC Stop
void IIC_Stop()
   SDA = low;
   _nop_();
   SCL = high;
   _nop_();_nop_();
   SDA = high;
// IIC Write byte
bit Write_IIC_Byte(unsigned char IIC_Byte)
        unsigned char i;
        bit Ack_Bit;
        for(i=0;i<8;i++)
                if(IIC_Byte & 0x80)
                SDA=high;
                SDA=low;
                //Delay_us(1);
                SCL=high;
                _nop_();_nop_();
                SCL=low;
                //Delay_us(1);
                IIC_Byte<<=1;
         SDA = high;
        _nop_();_nop_();
        SCL = high;
        _nop_();_nop_();
        Ack_Bit = SDA;
        SCL = low;
        return Ack_Bit;
// IIC Write Command
void LCD_WrCmd(unsigned char IIC_Command)
   IIC_Start();
   Write_IIC_Byte(0x78);            //Slave address,SA0=0
   Write_IIC_Byte(0x00);                        //write command
   Write_IIC_Byte(IIC_Command);
   IIC_Stop();
// IIC Write Data
void LCD_WrDat(unsigned char IIC_Data)
   IIC_Start();
   Write_IIC_Byte(0x40);                        //write data
   Write_IIC_Byte(IIC_Data);
   IIC_Stop();
/*********************OLED 設(shè)置坐標(biāo)************************************/
void LCD_Set_Pos(unsigned char x, unsigned char y)
        LCD_WrCmd(0xb2+y);
        LCD_WrCmd(((x&0xf0)>>4)|0x10);
        LCD_WrCmd((x&0x0f)|0x01);
/*********************OLED全屏************************************/
void LCD_Fill(unsigned char bmp_dat)
        unsigned char y,x;
        for(y=0;y<8;y++)
                LCD_WrCmd(0xb0+y);
                LCD_WrCmd(0x01);
                LCD_WrCmd(0x10);
                for(x=0;x<X_WIDTH;x++)
                LCD_WrDat(bmp_dat);
/*********************復(fù)位************************************/
void LCD_CLS(void)
        unsigned char y,x;
        for(y=0;y<8;y++)
                LCD_WrCmd(0xb0+y);
                LCD_WrCmd(0x01);
                LCD_WrCmd(0x10);
                LCD_WrDat(0);
/*********************LCD初始化************************************/
void LCD_Init(void)
        delay(500);//這里的延時(shí)很重要,一般50ms即可,保險(xiǎn)起見(jiàn),可以長(zhǎng)一些
        LCD_WrCmd(0xae);//--turn off oled panel
        LCD_WrCmd(0x00);//---set low column address
        LCD_WrCmd(0x10);//---set high column address
        LCD_WrCmd(0x40);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)
        LCD_WrCmd(0x81);//--set contrast control register
        LCD_WrCmd(0xcf); // Set SEG Output Current Brightness
        LCD_WrCmd(0xa1);//--Set SEG/Column Mapping     0xa0左右反置 0xa1正常
        LCD_WrCmd(0xc8);//Set COM/Row Scan Direction   0xc0上下反置 0xc8正常
        LCD_WrCmd(0xa6);//--set normal display
        LCD_WrCmd(0xa8);//--set multiplex ratio(1 to 64)
        LCD_WrCmd(0x3f);//--1/64 duty
        LCD_WrCmd(0xd3);//-set display offset        Shift Mapping RAM Counter (0x00~0x3F)
        LCD_WrCmd(0x00);//-not offset
        LCD_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency
        LCD_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec
        LCD_WrCmd(0xd9);//--set pre-charge period
        LCD_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
        LCD_WrCmd(0xda);//--set com pins hardware configuration
        LCD_WrCmd(0x12);
        LCD_WrCmd(0xdb);//--set vcomh
        LCD_WrCmd(0x40);//Set VCOM Deselect Level
        LCD_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)
        LCD_WrCmd(0x02);//
        LCD_WrCmd(0x8d);//--set Charge Pump enable/disable
        LCD_WrCmd(0x14);//--set(0x10) disable
        LCD_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5)
        LCD_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7)
        LCD_WrCmd(0xaf);//--turn on oled panel
        LCD_Fill(0x00);  //初始清屏
        LCD_Set_Pos(0,0);
/***************功能描述:顯示6*8一組標(biāo)準(zhǔn)ASCII字符串        顯示的坐標(biāo)(x,y),y為頁(yè)范圍0~7****************/
void LCD_P6X8Str(unsigned char x, y,unsigned char ch[])
        unsigned char c=0,i=0,j=0;
        while (ch[j]!='\0')
                c =ch[j]-32;
                if(x>126){x=0;y++;}
                LCD_Set_Pos(x,y);
                for(i=0;i<6;i++)
                LCD_WrDat(F6x8[c][i]);
                x+=6;
                j++;
/*******************功能描述:顯示8*16一組標(biāo)準(zhǔn)ASCII字符串         顯示的坐標(biāo)(x,y),y為頁(yè)范圍0~7****************/
void LCD_P8X16Str(unsigned char x, y,unsigned char ch[])
        while (ch[j]!='\0')
                c =ch[j]-32;
                if(x>120){x=0;y++;}
                LCD_Set_Pos(x,y);
                for(i=0;i<8;i++)
                LCD_WrDat(F8X16[c*16+i]);
                LCD_Set_Pos(x,y+1);
                for(i=0;i<8;i++)
                LCD_WrDat(F8X16[c*16+i+8]);
                x+=8;
                j++;
/******************功能描述:顯示16*24一組標(biāo)準(zhǔn)ASCII字符顯示的坐標(biāo)(x,y),y為頁(yè)范圍**************************************************/
  void LCD_P16X16Str(unsigned char x, y,unsigned char ch[])
        while (ch[j]!='\0')
                c =ch[j]-32;
                if(x>120){x=0;y++;}
                LCD_Set_Pos(x,y);
                for(i=0;i<16;i++)
                LCD_WrDat(F16X16[c*32+i]);
                LCD_Set_Pos(x,y+1);
                for(i=0;i<16;i++)
                LCD_WrDat(F16X16[c*32+i+16]);
                x+=16;
                j++;
  void LCD_P16X24Str(unsigned char x, y,unsigned char ch[])
        while (ch[j]!='\0')
                c =ch[j]-32;
                if(x>112){x=0;y++;}
                LCD_Set_Pos(x,y);
                for(i=0;i<16;i++)
                LCD_WrDat(F16X24[c*48+i]);
                LCD_Set_Pos(x,y+1);
                for(i=0;i<16;i++)
                LCD_WrDat(F16X24[c*48+i+16]);
                LCD_Set_Pos(x,y+2);
                for(i=0;i<16;i++)
                LCD_WrDat(F16X24[c*48+i+16*2]);
                x+=16;
                j++;
void Oled_write_data_3(unsigned char x, y,unsigned int data1)
    unsigned char translateData[6];
    translateData[0] = data1 % 10000 / 1000 + '0';
    translateData[1] = data1 % 1000 / 100 + '0';
          translateData[2] = '.';
          translateData[3] = data1 % 100 / 10 + '0';
    translateData[4] = data1 % 10 + '0';
    translateData[5] = '\0';
   LCD_P8X16Str(x,y,translateData) ;
//LCD_P16X24Str(x,y,translateData) ;
void Oled_write_data_4(unsigned char x, y,unsigned int data1)
    unsigned char translateData0[6];
         translateData0[0] = data1 % 100000/ 10000 + '0' ;
    translateData0[1] = data1 % 10000 / 1000 + '0';
    translateData0[2] = data1 % 1000 / 100 + '0';
          translateData0[3] = '.';
          translateData0[4] = data1 % 100 / 10 + '0';
   // translateData0[5] = data1 % 10 + '0';
    translateData0[5] = '\0';
   // LCD_P8X16Str(x,y,translateData0) ;
         LCD_P16X24Str(x,y,translateData0) ;
/*****************功能描述:顯示16*16點(diǎn)陣  顯示的坐標(biāo)(x,y),y為頁(yè)范圍0~7****************************/
//void LCD_P16x16Ch(unsigned char x, y, N)
//        unsigned char wm=0;
//        unsigned int adder=32*N;
//        LCD_Set_Pos(x , y);
//        for(wm = 0;wm < 16;wm++)
//                LCD_WrDat(F16x16[adder]);
//                adder += 1;
//        LCD_Set_Pos(x,y + 1);
//                adder += 1;
/***********功能描述:顯示顯示BMP圖片128×64起始點(diǎn)坐標(biāo)(x,y),x的范圍0~127,y為頁(yè)的范圍0~7*****************/
//void Draw_BMP(unsigned char x0, y0,x1, y1,unsigned char BMP[])
// unsigned int j=0;
// unsigned char x,y;
//  if(y1%8==0) y=y1/8;
//  else y=y1/8+1;
//        for(y=y0;y<y1;y++)
//                LCD_Set_Pos(x0,y);
//    for(x=x0;x<x1;x++)
//                    LCD_WrDat(BMP[j++]);
ID:1 發(fā)表于 2019-3-8 02:11 | 只看該作者
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說(shuō)明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
