查看: 3400|回復: 0
FPGA:利用ch451驅動數碼管,實現按鍵控制顯示數字
ID:449230 發表于 2019-3-7 20:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//Code to transfer serial command to CH451, for EDA students in 7-Segments experiments
//3-line serial command:LDA,LCLK,LOAD,from CH451
//By you,2017.0922
//steps of transfer serial command:
// 1.recevie the parrel command from SEDLED_COMMAND
// 2.transfer the command via serial command
module CH451SPI_MODULE(rst,clk,command,command_idle,command_start,LDA,LCLK,LOAD);
parameter command_length=12;
input rst,clk; //system
input[command_length-1:0] command;
input command_start; //inidcate if the command start
//output
output LDA,LCLK,LOAD;
output command_idle;
//command
// state machine
reg[3:0] state;
parameter state_idle=4'h0;
parameter state_start=4'h1;// command start
parameter state_tran=4'h2;// transfer command
parameter state_judge=4'h3;// see if all command complete
parameter state_end=4'h4;
parameter state_rdy=4'h5;//load command
reg[7:0] count;// count number of commands
reg[command_length-1:0] current_command;
reg reg_LDA;
reg reg_LOAD;
always@(negedge clk) // use negedge to avoid competion risk,
if(~rst)
   begin
        state<=state_idle;
        count<=0;
        reg_LDA<=1;
   end
   case(state)
   state_idle: if(command_start) // if SPI module not busy,idle
                 state<=state_rdy;
                 state<=state_idle;
   state_rdy: begin
                   current_command<=command;
                   state<=state_tran;
              end// transfer the current command, one command only
   state_tran:begin
                   if(count<command_length)
                      begin
                            reg_LDA<=current_command[0];
                            current_command<=(current_command>>1);
                            count<=count+1'b1;
                      end
                      begin
                          state<=state_end;
                          count<=0;
                          reg_LDA<=1;
                      end
              end
   state_end:  state<=state_idle; // stop to here
   default: state<=state_idle;
   endcase
assign LDA=reg_LDA;
assign LCLK=clk;
always@(posedge clk)
if(~rst)
   reg_LOAD<=1'b1;
   begin
        if(count==(command_length))
           reg_LOAD<=1'b0;
            reg_LOAD<=1'b1;
   end
//assign LOAD=(count==(command_length-1))?1'b0:1'b1;
assign LOAD=reg_LOAD;// assign
assign command_idle=(state==state_idle)?1'b1:1'b0;
endmodule
