查看: 6621|回復: 4
單片機如何實現循環依次點亮LED,現在只能依次點亮,而且其它按鍵不能使用
單片機源程序:
  1. #include<reg52.h>      //52系列單片機頭文件
  2. #define uchar unsigned char     //宏定義
  3. #define uint unsigned int
  4. sbit led1=P2^0;sbit led2=P2^1;
  5. sbit led3=P2^2;sbit led4=P2^3;
  6. sbit led5=P2^4;sbit led6=P2^5;
  7. sbit led7=P2^6;sbit led8=P2^7;
  8. sbit led9=P0^7;
  9. sbit key1=P3^1;sbit key2=P3^2;
  10. sbit key3=P3^3;sbit key4=P3^4;
  11. uchar flag;
  12. /*************************延時函數*****************************/
  13. void delay1ms(uint y)
  14. {
  15.                 uint j;
  16.                 while(y--)for(j=0;j<120;j++);
  17. }
  18. /*************************子函數******************************/
  19. void keyscan()
  20. {
  21.                                 if(key1==0)                                //確認按鍵是否被按下
  22.                                 {
  23.                                                 delay1ms(5);    //延時消抖動
  24.                                                 if(key1==0)     //消抖后在判斷按鍵是否按下
  25.                                                 {
  26.        if(flag<10)
  27.        flag++;
  28.        switch(flag)
  29.        {
  30.        case 1:led1=0;break;
  31.        case 2:led2=0;break;
  32.        case 3:led3=0;break;
  33.        case 4:led4=0;break;
  34.        case 5:led5=0;break;
  35.        case 6:led6=0;break;
  36.        case 7:led7=0;break;
  37.        case 8:led8=0;break;
  38.        case 9:led9=0;break;
  39.        }
  40.        while(!key1);   //等待按鍵釋放
  41.                                                 }
  42.                                 }
  43.
  44.                                 if(key2==0)                                //確認按鍵是否被按下
  45.                                 {
  46.                                                 delay1ms(5);    //延時消抖動
  47.                                                 if(key2==0)     //消抖后在判斷按鍵是否按下
  48.                                                 {
  49.        if(flag>0)
  50.        flag--;
  51.        switch(flag)
  52.        {
  53.        case 0:led1=1;break;
  54.        case 1:led2=1;break;
  55.        case 2:led3=1;break;
  56.        case 3:led4=1;break;
  57.        case 4:led5=1;break;
  58.        case 5:led6=1;break;
  59.        case 6:led7=1;break;
  60.        case 7:led8=1;break;
  61.        case 8:led9=1;break;
  62.        }
  63.        while(!key2);   //等待按鍵釋放
  64.                                                 }
  65.                                 }
  66.
  67.                                 if(key4==0)
  68.                                 {
  69.                                                 delay1ms(5);
  70.                                                 if(key4==0)
  71.                                                 {
  72.                                                         P2=~P2;
  73.                                                         P0=~P0;
  74.                                                         while(key4==0);
  75.                                                 }
  76.                                 }
  77.                                 if(key3==0)
  78.                                 {
  79.                                                 delay1ms(5);
  80.                                                 if(key3==0)
  81.                                                 {
  82.        while(1)
  83.        {
  84.        led1=0;
  85.        delay1ms(500);
  86.        led2=0;
  87.        delay1ms(500);
  88.        led3=0;
  89.        delay1ms(500);
  90.        led4=0;
  91.        delay1ms(500);
  92.        led5=0;
  93.        delay1ms(500);
  94.        led6=0;
  95.        delay1ms(500);
  96.        led7=0;
  97.        delay1ms(500);
  98.        led8=0;
  99.        delay1ms(500);
  100.        led9=0;
  101.        delay1ms(500);
  102.
  103.        }
  104.        while(key3==0);
  105.                                                 }
  106.                                 }
  107.
  108.
  109. }
  110. /*************************主函數******************************/
  111. void main()
  112. {
  113.                 while(1)
  114.                 {
  115.                                 keyscan();
  116.                 }
  117. }
ID:346616 發表于 2019-3-5 18:42 | 只看該作者
本帖最后由 菜鳥來了 于 2019-3-5 19:06 編輯
flag要復位,如果從1開始算,加燈的時候大于9了要等于1,
減燈的時候小于1了要等于9。
你上下兩個switch的flag起始位都不一致。
admin + 50 回帖助人的獎勵!
ID:213173 發表于 2019-3-5 22:09 | 只看該作者
給你寫好了
  1. //在任何工作狀態下都可以任意按鍵切換
  2. #include<reg52.h>      //52系列單片機頭文件
  3. #define uchar unsigned char     //宏定義
  4. #define uint unsigned int
  5. sbit led1=P2^0;
  6. sbit led2=P2^1;
  7. sbit led3=P2^2;
  8. sbit led4=P2^3;
  9. sbit led5=P2^4;
  10. sbit led6=P2^5;
  11. sbit led7=P2^6;
  12. sbit led8=P2^7;
  13. sbit led9=P0^7;
  14. sbit key1=P3^1;
  15. sbit key2=P3^2;
  16. sbit key3=P3^3;
  17. sbit key4=P3^4;
  18. uchar flag;
  19. uchar KeySec=0;//鍵值
  20. uint flag1=0;
  21. bit flag2=0;
  22. /*************************延時函數*****************************/
  23. /*
  24. void delay1ms(uint y)
  25. {
  26.         uint j;
  27.         while(y--)
  28.         for(j=0;j<120;j++);
  29. }*/
  30. /***********按鍵掃描程序**************/
  31. void keyscan()
  32. {
  33.         uchar num;
  34.         static uchar count;        //消抖計數變量
  35.         static bit sign=0;//按鍵自鎖標志
  36.         num=P3&0x1e;
  37.         if(num!=0x1e)
  38.         {
  39.                 if((++count>=250)&&(sign==0))//檢測按鍵如果為0
  40.                 {
  41.                         sign=1;                //按鍵自鎖標志置1,防止重復響應
  42.                         switch(num)
  43.                         {
  44.                                 case 0x1c:KeySec=1;break;
  45.                                 case 0x1a:KeySec=2;break;
  46.                                 case 0x16:KeySec=3;break;
  47.                                 case 0x0e:KeySec=4;break;
  48.                         }
  49.                 }
  50.         }
  51.         else
  52.         {
  53.                 count=0;                                //計數變量清0
  54.                 sign=0;                                //按鍵自鎖標志清0
  55.         }
  56. }
  57. /***********按鍵服務程序**************/
  58. void key_service()
  59. {
  60.         switch(KeySec)                                //按鍵服務狀態切換
  61.         {
  62.                 case 1:                                        //事例1號鍵觸發
  63.                         if(flag<9)
  64.                         flag++;
  65.                         switch(flag)
  66.                         {
  67.                                 case 1:led1=0;break;
  68.                                 case 2:led2=0;break;
  69.                                 case 3:led3=0;break;
  70.                                 case 4:led4=0;break;
  71.                                 case 5:led5=0;break;
  72.                                 case 6:led6=0;break;
  73.                                 case 7:led7=0;break;
  74.                                 case 8:led8=0;break;
  75.                                 case 9:led9=0;break;
  76.                         }
  77.                         KeySec=0;                //鍵值清0
  78.                 break;                        //跳出當前程序
  79.                 case 2:                                        //事例2號鍵觸發
  80.                         if(flag>0)
  81.                         flag--;
  82.                         switch(flag)
  83.                         {
  84.                                 case 0:led1=1;break;
  85.                                 case 1:led2=1;break;
  86.                                 case 2:led3=1;break;
  87.                                 case 3:led4=1;break;
  88.                                 case 4:led5=1;break;
  89.                                 case 5:led6=1;break;
  90.                                 case 6:led7=1;break;
  91.                                 case 7:led8=1;break;
  92.                                 case 8:led9=1;break;
  93.          }
  94.                         KeySec=0;                //鍵值清0
  95.                 break;                        //跳出當前程序
  96.                 case 3:                                        //事例3號鍵觸發
  97.                         if(++flag1>=5000)
  98.                         {
  99.                                 flag1=0;
  100.                                 if(++flag>=10)
  101.                                 {
  102.                                         P2=0xff;
  103.                                         led9=1;
  104.                                         flag=0;
  105.                                 }
  106.                                 switch(flag)
  107.                                 {
  108.                                         case 1:led1=0;break;
  109.                                         case 2:led2=0;break;
  110.                                         case 3:led3=0;break;
  111.                                         case 4:led4=0;break;
  112.                                         case 5:led5=0;break;
  113.                                         case 6:led6=0;break;
  114.                                         case 7:led7=0;break;
  115.                                         case 8:led8=0;break;
  116.                                         case 9:led9=0;break;
  117.                                 }
  118.                         }
  119. //                        KeySec=3;                //鍵值保持
  120.                 break;                         //跳出當前程序
  121.                 case 4:                                //事例4號鍵觸發
  122.                         flag2=~flag2;
  123.                         if(flag2)
  124.                         {
  125.                                 P2=0x00;
  126.                                 led9=0;
  127.                         }
  128.                         else
  129.                         {
  130.                                 P2=0xff;
  131.                                 led9=1;
  132.                         }
  133.                         KeySec=0;                //鍵值清0
  134.                 break;                         //跳出當前程序
  135.         }
  136. }
  137. /*************************主函數******************************/
  138. void main()
  139. {
  140.         while(1)
  141.         {
  142.                 keyscan();
  143.                 key_service();
  144.         }
  145. }
參與人數 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:404797 發表于 2019-3-5 22:12 | 只看該作者
     你的程序我幫你仿真檢查了一下,發現K1,K2,K4的模塊編得很好,沒有問題,點擊K1能依次點亮LED,點擊K2依次熄滅LED,點擊K4能整體點亮熄滅LED,只有K3模塊有點小問題,點擊K3,LED能依次點亮,但全部點亮LED后就死在這個全亮狀態。
      主要問題是你用了while(1){...}while(k3==0);這是個死循環,雖然K3釋放能跳出while(k==0),但while(1)跳不出,所以死在這,將\\while(1)注釋掉就可解決死循環的問題,但是還存在LED全亮后沒辦法通過K2依次熄滅的問題,原因是點擊k3后,LED依次點亮,這時雖然LED全亮,但這時flag值為0,所以無法通過k2減值flag來依次熄滅LED,所以要對flag=9賦值,就能通過k2依次息滅LED。
下面是修改后的程序:
sbit led1=P2^0;
sbit led2=P2^1;
sbit led3=P2^2;
sbit led4=P2^3;
sbit led5=P2^4;
sbit led6=P2^5;
sbit led7=P2^6;
sbit led8=P2^7;
sbit led9=P0^7;
sbit key1=P3^1;
sbit key2=P3^2;
sbit key3=P3^3;
sbit key4=P3^4;
uchar flag;
void delay1ms(uint y){uint j;while(y--)for(j=0;j<120;j++);}
void keyscan()
{if(key1==0)//確認按鍵是否被按下
   {delay1ms(5);//延時消抖動
    if(key1==0)//消抖后在判斷按鍵是否按下
     {if(flag<10)flag++;
      switch(flag)
       {case 1:led1=0;break;
        }while(!key1); //等待按鍵釋放
   if(key2==0)//確認按鍵是否被按下
      if(key2==0)//消抖后在判斷按鍵是否按下
        {if(flag>0)flag--;
         switch(flag){case 0:led1=1;break;
                      }while(!key2);//等待按鍵釋放
   if(key4==0){delay1ms(5);
                if(key4==0){P2=~P2;
                            P0=~P0;
                            while(key4==0);
  if(key3==0){delay1ms(5);
              if(key3==0)
     {//while(1)
     {led1=0;delay1ms(500);
     led2=0;delay1ms(500);
     led3=0;delay1ms(500);
     led4=0;delay1ms(500);
     led5=0;delay1ms(500);
     led6=0;delay1ms(500);
     led7=0;delay1ms(500);
     led8=0;delay1ms(500);
     led9=0;delay1ms(500);
     flag=9;
      }while(key3==0);
{while(1){keyscan();}
下面是proteus仿真時的情形:
附件有程序的proteus設計文件。 askc1.zip (27.09 KB, 下載次數: 7)
參與人數 1黑幣 +80 收起 理由
admin + 80
ID:404797 發表于 2019-3-6 19:37 | 只看該作者
不好意思,上面的仿真截圖弄錯啦,把別的問題的截圖混到本題啦,本題的仿真截圖是下面的圖:
所幸附件里的程序和proteus設計是正確的。讀者可放心參考。
