基于wifi的上位機(jī)模塊
2019-2-28 21:19 上傳
C#源程序如下:
- using System;
- using System.Collections.Generic;
- using System.ComponentModel;
- using System.Data;
- using System.Drawing;
- using System.Linq;
- using System.Text;
- using System.Threading.Tasks;
- using System.Windows.Forms;
- using System.Net;
- using System.Net.Sockets;
- namespace ServerApp
- public partial class Form1 : Form
- /// <summary>
- /// 服務(wù)器本地端口
- /// </summary>
- private const int LOCAL_PORT = 1500;
- TcpListener listener = null;
- public Form1()
- InitializeComponent();
- private void Form1_Load(object sender, EventArgs e)
- listener = new TcpListener(IPAddress.Any, LOCAL_PORT);
- // 開始監(jiān)聽
- listener.Start();
- AppendToTextBox("已開始監(jiān)聽連接。");
- // 開始接受連接
- listener.BeginAcceptTcpClient(new AsyncCallback(acceptCallback), listener);
- private void acceptCallback(IAsyncResult ar)
- TcpListener lstn = (TcpListener)ar.AsyncState;
- // 開始接收數(shù)據(jù)
- TcpClient client = lstn.EndAcceptTcpClient(ar);
- Task.Run(() =>
- // 獲取遠(yuǎn)程主機(jī)名
- string host = client.Client.RemoteEndPoint.ToString();
- // 獲取流對(duì)象
- NetworkStream stream = client.GetStream();
- string msg = null;
- while(true)
- // 讀取長(zhǎng)度
- byte[] buffer = new byte[4];
- stream.Read(buffer, 0, 4);
- int len = BitConverter.ToInt32(buffer, 0);
- // 讀取正文
- buffer = new byte[len];
- stream.Read(buffer, 0, len);
- string recMsg = Encoding.UTF8.GetString(buffer);
- if (recMsg == "$END$")
- string message = "客戶端" + host + "發(fā)送了退出指令。";
- txtRecMsgs.Invoke(new Action(() => AppendToTextBox(message)));
- break; //退出
- else
- txtRecMsgs.Invoke((Action)delegate()
- // 顯示收到的消息
- string message = string.Format("來自{0}的消息:{1}", host, recMsg);
- AppendToTextBox(message);
- client.Close();
- // 繼續(xù)接受連接
- lstn.BeginAcceptTcpClient(new AsyncCallback(acceptCallback), lstn);
- private void Form1_FormClosing(object sender, FormClosingEventArgs e)
- if (listener != null)
- listener.Stop(); //停止監(jiān)聽
- private void AppendToTextBox(string msg)
- txtRecMsgs.AppendText(msg + "\r\n");
wifi上位機(jī).rar
(393.83 KB, 下載次數(shù): 68)
2019-2-28 19:41 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
