查看: 2737|回復: 1
STM32F103 HC-SR04模塊驅動C程序
ID:277039 發表于 2019-2-28 16:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
希望對大家有用。
  1. #include "stm32f10x.h"
  2. #include "hcsr04.h"
  3. #include "sys.h"
  4. #include "delay.h"
  5. #include "usart.h"
  6. #define Trig GPIO_Pin_4
  7. #define Echo GPIO_Pin_6
  8. float Distance;
  9. void HCSR_Init(void)
  10. {
  11.         GPIO_InitTypeDef  GPIO_InitSture;
  12.         EXTI_InitTypeDef  EXTI_InitSture;
  13.         NVIC_InitTypeDef  NVIC_InitSture;
  14.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOE,ENABLE);
  15.
  16.
  17.         //配置IO端口
  18.         GPIO_InitSture.GPIO_Mode=GPIO_Mode_Out_PP;
  19.         GPIO_InitSture.GPIO_Pin=Trig;                //將PE4于Trig相連
  20.         GPIO_InitSture.GPIO_Speed=GPIO_Speed_50MHz;
  21.         GPIO_Init(GPIOE,&GPIO_InitSture);
  22.
  23.         GPIO_InitSture.GPIO_Mode=GPIO_Mode_IPD;
  24.         GPIO_InitSture.GPIO_Pin=Echo;                //將PE6于Echo相連
  25.         GPIO_InitSture.GPIO_Speed=GPIO_Speed_50MHz;
  26.         GPIO_Init(GPIOE,&GPIO_InitSture);
  27.
  28.         //中斷和6端口映射一起
  29.         GPIO_EXTILineConfig(GPIO_PortSourceGPIOE,GPIO_PinSource6);
  30.
  31.         //外部中斷配置
  32.         EXTI_InitSture.EXTI_Line=EXTI_Line6;
  33.         EXTI_InitSture.EXTI_LineCmd=ENABLE;
  34.         EXTI_InitSture.EXTI_Mode=EXTI_Mode_Interrupt;
  35.         EXTI_InitSture.EXTI_Trigger=EXTI_Trigger_Rising;
  36.         EXTI_Init(&EXTI_InitSture);
  37.
  38.
  39.         //中斷優先級管理
  40.         NVIC_InitSture.NVIC_IRQChannel=EXTI9_5_IRQn;
  41.         NVIC_InitSture.NVIC_IRQChannelCmd=ENABLE;
  42.         NVIC_InitSture.NVIC_IRQChannelPreemptionPriority=2;
  43.         NVIC_InitSture.NVIC_IRQChannelSubPriority=2;
  44.         NVIC_Init(&NVIC_InitSture);
  45. }
  46. void EXTI9_5_IRQHandler(void)
  47. {
  48.         delay_us(10);
  49.
  50.
  51.         if(EXTI_GetITStatus(EXTI_Line6)!=RESET)
  52.         {
  53.                 TIM_SetCounter(TIM3,0);
  54.                 TIM_Cmd(TIM3,ENABLE);
  55.
  56.                 while(GPIO_ReadInputDataBit(GPIOE,Echo));  //等待低電平
  57.
  58.                 TIM_Cmd(TIM3,DISABLE);
  59.
  60.                 Distance=TIM_GetCounter(TIM3)*34/2000;
  61.
  62.                 if(Distance>0)
  63.                 {
  64.                         printf("Distance:%0.1f cm\r\n",Distance);
  65.                 }
  66.
  67.                 EXTI_ClearITPendingBit(EXTI_Line6);
  68.         }
  69. }
  70. void HCSR_Strat(void)
  71. {
  72.         GPIO_SetBits(GPIOE,Trig);   //將Trig設置為高電平
  73.         delay_us(20);               //持續大于10us觸發,觸發超聲波模塊工作
  74.         GPIO_ResetBits(GPIOE,Trig);
  75.
  76. }
  77. void TIM3_LJW_Init(void) //TIM3初始化
  78. {
  79.         NVIC_InitTypeDef NVIC_Struct;                          //定義NVIC結構體
  80.         TIM_TimeBaseInitTypeDef  TIM_Struct;                   //定義TIM結構體
  81.
  82.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3 ,ENABLE);   //初始化TIM3時鐘
  83.
  84.         TIM_Struct.TIM_ClockDivision=TIM_CKD_DIV1;             //這里用不到 隨便寫的
  85.         TIM_Struct.TIM_CounterMode=TIM_CounterMode_Up;         //向上計數
  86.         TIM_Struct.TIM_Period=65535;                            //重裝載值4999
  87.        // 72M/(7199+1)=10000->0.1ms * (4999+1) = 500ms
  88.        // (PSC+1)(ARR+1)/CK_PSC = 時間
  89.         TIM_Struct.TIM_Prescaler=71;                         //預分頻值7199
  90.         TIM_TimeBaseInit(TIM3,&TIM_Struct);                    //初始化TIM3
  91.
  92.   TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);               //使能TIM3的更新中斷
  93.
  94.         NVIC_Struct.NVIC_IRQChannel=TIM3_IRQn ;                //選擇TIM3通道
  95.         NVIC_Struct.NVIC_IRQChannelCmd=ENABLE;                 //使能通道
  96.         NVIC_Struct.NVIC_IRQChannelPreemptionPriority=1;       //搶占優先級
  97.         NVIC_Struct.NVIC_IRQChannelSubPriority=1;              //響應優先級
  98.         NVIC_Init(&NVIC_Struct);                               //初始化NVIC
  99.
  100.         //TIM_Cmd(TIM3,ENABLE);                                  //啟動定時器
  101. }
HC-SR04.7z (184.71 KB, 下載次數: 99)
ID:1 發表于 2019-2-28 18:59 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
