查看: 2078|回復(fù): 1
簡易溫控器單片機程序 DS18B20 掉電儲存 藍牙無線讀取 長短鍵設(shè)置 LCD1602顯示
ID:481908 發(fā)表于 2019-2-28 11:32 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
簡易溫控器程序  簡易溫控器 DS18B20 掉電儲存 藍牙無線讀取 長短鍵設(shè)置 LCD1602顯示
  1.         //        業(yè)余愛好簡易無線溫控
  2. //DS18B20  LCD1602顯示  按鍵設(shè)置 增加 長短鍵 上限 下限 設(shè)置值掉電保存  無線APP讀取
  3. //函數(shù)文件
  4. //主函數(shù)  溫度讀取  LCD1602   按鍵 I2C
  5.                   #include <reg52.h>
  6.            #include <intrins.h>
  7.                                  #include<string.h>
  8.
  9.            sfr PLC = 0x97;
  10. bit flag1s = 0; //1s 定時標(biāo)志
  11. unsigned char T0RH = 0; //T0 重載值的高字節(jié)
  12. unsigned char T0RL = 0; //T0 重載值的低字節(jié)
  13. void ConfigTimer0(unsigned int ms);
  14.
  15.   unsigned char IntToString(unsigned char *str, int dat);
  16. extern bit Start18B20();
  17. extern bit Get18B20Temp(int *temp);
  18. extern void shumaguanb(signed char sed);
  19. extern void shumaguana(signed char sec);
  20. unsigned char shangcha ();
  21.   unsigned char xiacha()        ;
  22. extern  void saomiao();
  23. extern  tm1637(unsigned char C,S) ;
  24. extern void InitLcd1602();
  25. extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
  26. extern  void xianshi(unsigned char x,sec);
  27. extern        unsigned char shezhi();
  28.    extern void I2CStart();
  29. extern void I2CStop();
  30. extern unsigned char I2CReadNAK();
  31. extern bit I2CWrite(unsigned char dat);
  32. unsigned char E2ReadByte(unsigned char addr);
  33. void E2WriteByte(unsigned char addr, unsigned char dat);
  34.          bit cmdArrived = 0; //命令到達標(biāo)志,即接收到上位機下發(fā)的命令
  35. unsigned char cmdIndex ; //命令索引,即與上位機約定好的數(shù)組編號
  36. unsigned char cntTxd = 0; //串口發(fā)送計數(shù)器
  37. unsigned char *ptrTxd; //串口發(fā)送指針
  38. unsigned char array1[20] = "1-Hello!   \r\n";
  39.         void ConfigUART(unsigned int baud);
  40.
  41.         unsigned char        R[10]="C-Tmpe\r\n";
  42.                 unsigned char        T[10]="C-Scz\r\n";
  43.                 unsigned char        M[10]="C-Xcz\r\n";
  44.         unsigned char d[20];
  45.
  46.         unsigned char sc[10];
  47.                 unsigned char xc[10];
  48. sbit out=P2^5;//溫度輸出
  49.         sbit K=P1^4;
  50.
  51. void main()
  52. {
  53. static  unsigned char shangchazhi;
  54. static          unsigned char xiachazhi;
  55.   unsigned char c;
  56.
  57.
  58.
  59.
  60.                 bit res;
  61. int temp; //讀取到的當(dāng)前溫度值
  62. int intT, decT; //溫度值的整數(shù)和小數(shù)部分
  63. unsigned char len;
  64. unsigned char str[12];
  65. unsigned char S[12];
  66. unsigned char X[12];
  67.    shangchazhi=E2ReadByte(0x02);
  68.   xiachazhi=E2ReadByte(0x05);
  69. EA = 1; //開總中斷
  70. ConfigTimer0(10); //T0 定時 10ms
  71.      ConfigUART(9600); //配置波特率為 9600
  72. Start18B20(); //啟動 DS18B20
  73. InitLcd1602(); //初始化液晶
  74.
  75. while (1)
  76. {
  77.
  78.                          K=0;
  79.
  80.
  81.                           if (cmdArrived)
  82. {
  83. cmdArrived = 0;
  84.                               if( cmdIndex=='A')
  85.                           {
  86.                              strcpy(d,str);
  87.                  strcat(d,R);
  88.
  89. ptrTxd =d; //數(shù)組 1 的首地址賦值給發(fā)送指針
  90. cntTxd = sizeof(d); //數(shù)組 1 的長度賦值給發(fā)送計數(shù)器
  91. TI = 1; //手動方式啟動發(fā)送中斷,處理數(shù)據(jù)發(fā)送
  92.         }
  93.            else if (cmdIndex=='B')
  94.                   {
  95.                                 len = IntToString(sc, shangchazhi); //整數(shù)部分轉(zhuǎn)換為字符串
  96.                                                  sc[len] = '\0';
  97.
  98.                                                  strcpy(d,sc);
  99.                  strcat(d,T);
  100.                                            ptrTxd =d; //數(shù)組 1 的首地址賦值給發(fā)送指針
  101. cntTxd = sizeof(d); //數(shù)組 1 的長度賦值給發(fā)送計數(shù)器
  102.
  103.
  104. TI = 1; //手動方式啟動發(fā)送中斷,處理數(shù)據(jù)發(fā)送
  105.                          }
  106.                                    else if (cmdIndex=='C')
  107.                   {
  108.                                 len = IntToString(xc, xiachazhi); //整數(shù)部分轉(zhuǎn)換為字符串
  109.                                                  xc[len] = '\0';
  110.
  111.                                                  strcpy(d,xc);
  112.                  strcat(d,M);
  113.                                            ptrTxd =d; //數(shù)組 1 的首地址賦值給發(fā)送指針
  114. cntTxd = sizeof(d); //數(shù)組 1 的長度賦值給發(fā)送計數(shù)器
  115.
  116.
  117. TI = 1; //手動方式啟動發(fā)送中斷,處理數(shù)據(jù)發(fā)送
  118.                          }
  119.
  120.
  121.
  122.
  123.                                                  }
  124.
  125. if (flag1s) //每秒更新一次溫度
  126. {
  127. flag1s = 0;
  128. res = Get18B20Temp(&temp); //讀取當(dāng)前溫度
  129.                 if (res) //讀取成功時,刷新當(dāng)前溫度顯示
  130. {
  131. intT = temp >> 4; //分離出溫度值整數(shù)部分
  132. decT = temp & 0xF; //分離出溫度值小數(shù)部分
  133. len = IntToString(str, intT); //整數(shù)部分轉(zhuǎn)換為字符串
  134. str[len++] = '.'; //添加小數(shù)點
  135. decT = (decT*10) / 16; //二進制的小數(shù)部分轉(zhuǎn)換為 1 位十進制位
  136. str[len++] = decT + '0'; //十進制小數(shù)位再轉(zhuǎn)換為 ASCII 字符
  137. while (len < 6) //用空格補齊到 6 個字符長度
  138. {
  139. str[len++] = ' ';
  140. }
  141. str[len] = '\0'; //添加字符串結(jié)束符
  142.          LcdShowStr(0, 0, "Temp")  ;
  143. LcdShowStr(5, 0, str); //顯示到液晶屏上
  144.
  145. }
  146. else //讀取失敗時,提示錯誤信息
  147. {
  148. LcdShowStr(0, 0, "error!");
  149. }
  150.
  151.                          if (intT>=shangchazhi)
  152.                          {
  153.                            out=1;
  154.                                    LcdShowStr(11, 0, "OFF");
  155.
  156.                          }
  157.
  158.                         else if        (intT<=xiachazhi)
  159.                         {
  160.                                  LcdShowStr(11, 0, "ON");
  161.                           out=0;
  162.
  163.
  164.                         }
  165.
  166.
  167. Start18B20(); //重新啟動下一次轉(zhuǎn)換
  168. }
  169.
  170.                                     LcdShowStr(0, 1, "B-")  ;
  171. S[0] = (shangchazhi/100%10) + '0';
  172. S[1] = (shangchazhi/10%10) + '0';
  173. S[2] = (shangchazhi%10) + '0';
  174. S[3] = '\0';
  175. LcdShowStr(3, 1, S)  ;                  //上差顯示
  176.                                                            LcdShowStr(7, 1, "C-")  ;
  177. X[0] = (xiachazhi/100%10) + '0';
  178. X[1] = (xiachazhi/10%10) + '0';
  179. X[2] = (xiachazhi%10) + '0';
  180. X[3] = '\0';
  181. LcdShowStr(11, 1, X)  ;                  //上差顯示
  182.                      c=shezhi();
  183.
  184.                                    if (c==0)
  185.                 {                     c=shezhi();
  186.                                             LcdShowStr(15, 0,"A" ); //顯示到液晶屏上
  187.
  188.                            }
  189.                  if(c==1)
  190.                  {
  191.
  192.                 shangchazhi=  shangcha();
  193.                                      LcdShowStr(15, 0,"B" ); //顯示到液晶屏上
  194.                                           E2WriteByte(0x02, shangchazhi);
  195.
  196.
  197.                   }
  198.                  if (c==2)
  199.                  {
  200.
  201.                    xiachazhi=xiacha();
  202.                   LcdShowStr(15, 0,"C" ); //顯示到液晶屏上
  203.                                      E2WriteByte(0x05, xiachazhi);
  204.
  205.                                          }
  206.
  207.
  208.
  209.
  210. }
  211. }
  212. /* 整型數(shù)轉(zhuǎn)換為字符串, str-字符串指針, dat-待轉(zhuǎn)換數(shù),返回值-字符串長度 */
  213. unsigned char IntToString(unsigned char *str, int dat)
  214. {
  215. signed char i = 0;
  216. unsigned char len = 0;
  217. unsigned char buf[6];
  218. if (dat < 0) //如果為負數(shù),首先取絕對值,并在指針上添加負號
  219. {
  220. dat = -dat;
  221. *str++ = '-';
  222. len++;
  223. }
  224. do { //先轉(zhuǎn)換為低位在前的十進制數(shù)組
  225. buf[i++] = dat % 10;
  226. dat /= 10;
  227. } while (dat > 0);
  228. len += i; //i 最后的值就是有效字符的個數(shù)
  229. while (i-- > 0) //將數(shù)組值轉(zhuǎn)換為 ASCII 碼反向拷貝到接收指針上
  230. {
  231. *str++ = buf[i] + '0';
  232.           }
  233. *str = '\0'; //添加字符串結(jié)束符
  234. return len; //返回字符串長度
  235. }
  236. /* 配置并啟動 T0, ms-T0 定時時間 */
  237. void ConfigTimer0(unsigned int ms)
  238. {
  239. unsigned long tmp; //臨時變量
  240. tmp = 11059200 / 12; //定時器計數(shù)頻率
  241. tmp = (tmp * ms) / 1000; //計算所需的計數(shù)值
  242. tmp = 65536 - tmp; //計算定時器重載值
  243. tmp = tmp + 12; //補償中斷響應(yīng)延時造成的誤差
  244. T0RH = (unsigned char)(tmp>>8); //定時器重載值拆分為高低字節(jié)
  245. T0RL = (unsigned char)tmp;
  246. TMOD &= 0xF0; //清零 T0 的控制位
  247. TMOD |= 0x01; //配置 T0 為模式 1
  248. TH0 = T0RH; //加載 T0 重載值
  249. TL0 = T0RL;
  250. ET0 = 1; //使能 T0 中斷
  251. TR0 = 1; //啟動 T0
  252. }
  253. /* T0 中斷服務(wù)函數(shù),完成 1 秒定時 */
  254. void InterruptTimer0() interrupt 1
  255. {
  256. static unsigned char tmr1s = 0;
  257. TH0 = T0RH; //重新加載重載值
  258. TL0 = T0RL;
  259. tmr1s++;
  260. if (tmr1s >= 100) //定時 1s
  261. {
  262. tmr1s = 0;
  263. flag1s = 1;
  264. }
  265. }
  266.           /* 讀取 EEPROM 中的一個字節(jié), addr-字節(jié)地址 */
  267. unsigned char E2ReadByte(unsigned char addr)
  268.    {
  269. unsigned char dat;
  270. I2CStart();
  271. I2CWrite(0x50<<1); //尋址器件,后續(xù)為寫操作
  272. I2CWrite(addr); //寫入存儲地址
  273. I2CStart(); //發(fā)送重復(fù)啟動信號
  274. I2CWrite((0x50<<1)|0x01); //尋址器件,后續(xù)為讀操作
  275. dat = I2CReadNAK(); //讀取一個字節(jié)數(shù)據(jù)
  276. I2CStop();
  277. return dat;
  278. }
  279. /* 向 EEPROM 中寫入一個字節(jié), addr-字節(jié)地址 */
  280. void E2WriteByte(unsigned char addr, unsigned char dat)
  281. {
  282. I2CStart();
  283. I2CWrite(0x50<<1); //尋址器件,后續(xù)為寫操作
  284. I2CWrite(addr); //寫入存儲地址
  285. I2CWrite(dat); //寫入一個字節(jié)數(shù)據(jù)
  286. I2CStop();
  287. }
  288.    /* 串口配置函數(shù), baud-通信波特率 */
  289. void ConfigUART(unsigned int baud)
  290. {
  291. SCON = 0x50; //配置串口為模式 1
  292. TMOD &= 0x0F; //清零 T1 的控制位
  293. TMOD |= 0x20; //配置 T1 為模式 2
  294. TH1 = 256 - (11059200/12/32)/baud; //計算 T1 重載值
  295. TL1 = TH1; //初值等于重載值
  296. ET1 = 0; //禁止 T1 中斷
  297. ES = 1; //使能串口中斷
  298. TR1 = 1; //啟動 T1
  299. }
  300. /* UART 中斷服務(wù)函數(shù) */
  301. void InterruptUART() interrupt 4
  302. {
  303. if (RI) //接收到字節(jié)
  304. {
  305. ……………………
  306. …………限于本文篇幅 余下代碼請從51黑下載附件…………
藍牙溫控.rar (68.71 KB, 下載次數(shù): 30)
ID:1 發(fā)表于 2019-2-28 15:33 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
