只需一步,快速開(kāi)始
查看: 17676|回復(fù): 30
51單片機(jī)WS2812B RGB LED驅(qū)動(dòng)程序 可以控制200個(gè)RGB
ID:481908 發(fā)表于 2019-2-28 11:25 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
51單片機(jī)WS2812BRGB
可以控制200個(gè)RGB
單片機(jī)源程序如下:
  1.           #include<reg52.h>
  2. #include<intrins.h>
  3.                 //單片機(jī)為15系列  晶振內(nèi)部27M  分頻為0X02
  4.                 //可以控制1024 個(gè)RGB
  5.         #define uchar unsigned char
  6.          sfr PLC=0X97;
  7.          sbit Send_Dat=P3^5;
  8.          unsigned char RGB_BUF[24];
  9.                  void delay();
  10.                  void RGBA(); //流動(dòng)效果
  11.                   void RGBB(        unsigned int w);//靜態(tài)顯示全彩
  12.                   void RGBC ();          //全體變色效果
  13.                          uchar  n;
  14.                         uchar r;
  15.                           unsigned char *p;
  16.
  17.                  uchar a []={ 0xff,0x00,0x00} ;         //綠
  18.                  uchar b []={ 0x00,0xff,0x00} ;         //紅
  19.                  uchar c []={ 0x00,0x00,0xff} ;         //藍(lán)
  20.                  uchar d []={ 0xff,0xff,0x00} ;         //黃
  21.                  uchar e []={ 0xff,0x00,0xff} ;         //青
  22.                  uchar f []={ 0x00,0xff,0xff} ;         //紫
  23.                  uchar g []={ 0xff,0xff,0xff} ;         //白
  24.                  uchar h []={ 0x00,0x00,0x00} ;
  25.
  26.                          uchar shuzud [8] [3]={
  27.             { 0xff,0x00,0x00},           //綠
  28.                 { 0x00,0xff,0x00} ,           //紅
  29.                 { 0x00,0x00,0xff} ,           //藍(lán)
  30.                 { 0xff,0xff,0x00} ,           //黃
  31.                 { 0xff,0x00,0xff} ,           //青
  32.                 { 0x00,0xff,0xff} ,           //紫
  33.                 { 0xff,0xff,0xff} ,           //白
  34.                 { 0x00,0x00,0x00} ,
  35.                                                 };
  36.                    sfr P3M1 = 0xb1;
  37. sfr P3M0 = 0xb2;
  38.
  39. struct shuzu
  40.                    {
  41.                           uchar a [3];
  42.                           uchar b[3] ;
  43.
  44.         };
  45.                         struct        shuzu;
  46. void delays(uchar t);
  47.
  48.                 void Send_A_bit(uchar v)
  49. {
  50. //
  51.        if (v==1)
  52.        {
  53.
  54.               Send_Dat=1;
  55.               _nop_();
  56.
  57.               Send_Dat=0;
  58.
  59.        }
  60.        else
  61.        {
  62.               Send_Dat=1;
  63.
  64.               Send_Dat=0;
  65.               _nop_();
  66.
  67.        }
  68.
  69. }
  70.                  void Send_192bits( uchar *p1,uchar z)
  71. {
  72.        unsigned int i=0;        uchar s; uchar x; unsigned char k;
  73.
  74.                                          s=8;
  75.                          x=0;
  76.          //    1
  77.
  78.
  79.
  80.
  81.
  82.            for   (i=x;i<s;i++)
  83.        {
  84.               RGB_BUF[i]=p1[0]>>(i-x)&0x01;                          //轉(zhuǎn)化R_VAL
  85.        }
  86.                                            s=s+8;
  87.                                            x=x+8;
  88.
  89.               for   (i=x;i<s;i++)
  90.        {
  91.               RGB_BUF[i]=p1[1]>>(i-x)&0x01;               //轉(zhuǎn)化G_VAL
  92.        }
  93.
  94.                                        s=s+8;
  95.                                            x=x+8;
  96.
  97.                                            for   (i=x;i<s;i++)
  98.        {
  99.               RGB_BUF[i]=p1[2]>>(i-x)&0x01;
  100.
  101.                                                     //轉(zhuǎn)化R_VAL
  102.        }
  103.
  104.
  105.
  106.                                                     s=s+8;
  107.                                            x=x+8;
  108.
  109.
  110.
  111.
  112.
  113.
  114.
  115.                                         for (k=0;k<z;k++)          //循環(huán)RGB數(shù)量
  116.                                   {
  117.
  118.
  119.
  120.
  121.
  122.                          for (i=0;i<24;i++)
  123.       {
  124.               Send_A_bit(RGB_BUF[i]);
  125.        }
  126.
  127.
  128.
  129.
  130.
  131.                                   }
  132.
  133.
  134.
  135.
  136.
  137.                                           }
  138.
  139.
  140.
  141.                 void main()
  142.                 {
  143.                                  P3M0 = 0x00;
  144.     P3M1 = 0x00;
  145.                                 PLC=0X02;
  146.                         while(1)
  147.                            {
  148.
  149.
  150.
  151.                                 RGBB(65000);  //全體靜態(tài)顯示全彩效果
  152.
  153.                                  delays(10 );
  154.                                 RGBA();//全體流動(dòng)效果
  155.                                                  delays(5);
  156.                                 RGBC();//全體變色效果
  157.                                                     delays(5);
  158.
  159.                            }
  160. }
  161.
  162.
  163.           void RGBA()                         // 流動(dòng)效果
  164.           {
  165.
  166.                                          Send_192bits(shuzud[0],9);
  167.                                     delays(1);
  168.
  169.                                                 for (n=0;n<10;n++)
  170.                                              {
  171.
  172.                                              Send_192bits(shuzud[1],n);
  173.                                     delays(1);
  174.
  175.                             }
  176.        for (n=0;n<10;n++)
  177.                                              {
  178.
  179.                                              Send_192bits(shuzud[2],n);
  180.                                     delays(1);
  181.                                           }
  182.                                            }
  183.                         void          RGBB(         unsigned int w         )          //全體靜態(tài)顯示全彩效果
  184.           {
  185.        unsigned int t;
  186.        for (t=0;t<        w;t++);
  187.
  188.                                                    Send_192bits(shuzud[2],9);
  189.        for (t=0;t<        w;w++);
  190.
  191.        Send_192bits(shuzud[1],8);
  192.        for (t=0;t<        w;t++);
  193.        Send_192bits(shuzud[0],7);
  194.
  195.        for (t=0;t<        w;t++);
  196.        Send_192bits(shuzud[5],6);
  197.
  198.        for (t=0;t<        w;t++);
  199.        Send_192bits(shuzud[4],5);
  200.
  201.        for (t=0;t<        w;t++);
  202.
  203.        Send_192bits(shuzud[3],4);
  204.
  205.        for (t=0;t<        w;t++);
  206.        Send_192bits(shuzud[2],3);
  207.
  208.        for (t=0;t<        w;t++);
  209.        Send_192bits(shuzud[1],2);
  210.
  211.        for (t=0;t<        w;t++);
  212.
  213.        Send_192bits(shuzud[0],1);
  214.
  215.        for (t=0;t<        w;t++);
  216.
  217.                          }
  218.       void RGBC()           //全體變色效果
  219.           {
  220.                                  Send_192bits(shuzud[0],9);
  221.                                     delays(5);
  222.                                    Send_192bits(shuzud[1],9);
  223.                                     delays(5);
  224.                                   Send_192bits(shuzud[2],9);
  225.                                     delays(5);
  226.                                    Send_192bits(shuzud[3],9);
  227.                                     delays(5);
  228.                                    Send_192bits(shuzud[4],9);
  229.                                     delays(5);
  230.                                    Send_192bits(shuzud[5],9);
  231.                                     delays(5);
  232.                                   }
  233.
  234.         void delay()
  235. {
  236. unsigned int i,j;
  237.        for (i=0;i<250;i++)
  238.        {
  239.               for (j=0;j<200;j++);
  240.        }
  241. }
  242. /*大延時(shí)函數(shù)*/
  243. /*十幾秒*/
  244. void delays(uchar t)
  245. {
  246.                    uchar p;
  247.          for (p=0; p<t;p++)
  248.            {
  249.        delay();
  250.
  251.                                         }
  252.
  253. }
優(yōu)化RGB.rar (25.16 KB, 下載次數(shù): 583)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
收藏收藏29 分享淘帖 頂2 踩
ID:60656 發(fā)表于 2019-3-7 22:14 | 只看該作者
好資料收藏學(xué)習(xí),謝謝
ID:473186 發(fā)表于 2019-3-8 16:49 | 只看該作者
52單片機(jī)應(yīng)該跟不上,這玩意最少要24M的,宏晶其他型號(hào)可以
ID:243748 發(fā)表于 2019-3-9 21:12 來(lái)自觸屏版 | 只看該作者
有電路圖嗎
ID:265485 發(fā)表于 2019-3-17 20:54 | 只看該作者
這程序不行試了沒(méi)有效果
ID:67356 發(fā)表于 2019-3-18 06:58 來(lái)自觸屏版 | 只看該作者
好,。謝,回來(lái)看看
ID:243748 發(fā)表于 2019-8-2 20:46 來(lái)自觸屏版 | 只看該作者
明天試一下
ID:299054 發(fā)表于 2019-9-5 17:04 | 只看該作者
謝謝分享!
ID:358797 發(fā)表于 2019-12-4 13:56 | 只看該作者
穩(wěn)定嗎
ID:652686 發(fā)表于 2020-1-1 15:57 | 只看該作者
正好想用WS2812B做一個(gè)燈,好資料收藏學(xué)習(xí),謝謝
ID:690219 發(fā)表于 2020-3-5 17:22 | 只看該作者
有電路圖共參考嗎?
51單片機(jī)真的可以實(shí)現(xiàn)嗎?
ID:686314 發(fā)表于 2020-3-18 17:10 | 只看該作者
謝謝樓主
無(wú)效樓層,該帖已經(jīng)被刪除
14#
15#
16#
ID:791100 發(fā)表于 2020-11-6 20:21 | 只看該作者
樓主資料非常好,值得收藏,謝謝!
ID:791100 發(fā)表于 2020-11-7 20:11 | 只看該作者
樓主資料非常好,值得收藏,謝謝!
ID:89286 發(fā)表于 2020-11-8 17:48 | 只看該作者
thanks for sharing
20#
ID:845476 發(fā)表于 2022-1-9 18:32 | 只看該作者
請(qǐng)問(wèn)樓主,為什么我的第一顆燈是白色的特別亮
ID:1003871 發(fā)表于 2022-2-12 22:47 | 只看該作者
200個(gè)。。。。出錯(cuò)了是不是就都不好使了
ID:977804 發(fā)表于 2022-2-21 11:25 來(lái)自觸屏版 | 只看該作者
xo520 發(fā)表于 2022-1-9 18:32
白光,說(shuō)明頻率不夠。要增大主頻
24#
ID:583681 發(fā)表于 2022-8-25 08:40 | 只看該作者
我微改了一下程序,11.0592M的單片機(jī)都可以適應(yīng)。
ID:1013588 發(fā)表于 2022-8-28 10:22 | 只看該作者
謝謝分享,以后有機(jī)會(huì)試試
ID:1062369 發(fā)表于 2023-4-26 00:24 來(lái)自觸屏版 | 只看該作者
gzpylyf 發(fā)表于 2022-8-25 08:40
請(qǐng)問(wèn)是怎么做到的
ID:1053359 發(fā)表于 2023-4-28 09:19 | 只看該作者
不知道行不行,先下載研究,,感謝樓主分享
29#
30#
ID:1096871 發(fā)表于 2023-10-22 15:04 | 只看該作者
試過(guò)了,的確可以點(diǎn)亮,謝謝樓主
ID:1096871 發(fā)表于 2023-10-22 15:05 | 只看該作者
謝謝樓主,試過(guò)了,的確可以點(diǎn)亮,現(xiàn)在在樓主的程序上做動(dòng)態(tài)變化,謝謝樓主
ID:398094 發(fā)表于 2023-11-22 09:21 | 只看該作者
好資料收藏學(xué)習(xí),謝謝
ID:1068132 發(fā)表于 2023-12-3 20:38 | 只看該作者
為什么我移植到STC8G2K32S4燈亮不了
ID:433219 發(fā)表于 2023-12-4 09:05 | 只看該作者
具體要說(shuō)下,哪個(gè)型號(hào)和IRC頻率
ID:31514 發(fā)表于 2024-1-5 17:25 | 只看該作者
感謝分享,主要學(xué)習(xí)漸變色算法
ID:72224 發(fā)表于 2024-2-2 10:27 | 只看該作者
STC輕松驅(qū)動(dòng)1000個(gè)WS2812
38#
ID:807361 發(fā)表于 2024-4-28 22:05 | 只看該作者
ID:1069621 發(fā)表于 2025-5-12 15:29 | 只看該作者
你是咋做的,有源代碼提供參考嗎?
