為什么lcd沒有顯示,數(shù)碼管也是亂碼
- #include<reg52.h>
- #include "keyboard.h"
- #include "delay1.h"
- #include "1602.h"
- #include "ds1302.h"
- #include "ds18b20.h"
- #include "temp.h"
- #define uchar unsigned char
- #define uint unsigned int
- #define led P2
- sbit beep=P1^5;
- sbit LSA=P2^2;
- sbit LSB=P2^3;
- sbit LSC=P2^4;
- char num=0;
- uchar DisplayData[8];
- uchar code smgduan[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- uchar DisplayData1[9];
- uchar code smgduan1[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- uchar password[4]={1,0,0,0};
- uchar userpassword[4];
- void datapros1(int temp)
- float tp;
- if(temp< 0) //當(dāng)溫度值為負(fù)數(shù)
- DisplayData1[0] = 0x40; // -
- //因?yàn)樽x取的溫度是實(shí)際溫度的補(bǔ)碼,所以減1,再取反求出原碼
- temp=temp-1;
- temp=~temp;
- tp=temp;
- temp=tp*0.0625*100+0.5;
- //留兩個(gè)小數(shù)點(diǎn)就*100,+0.5是四舍五入,因?yàn)镃語言浮點(diǎn)數(shù)轉(zhuǎn)換為整型的時(shí)候把小數(shù)點(diǎn)
- //后面的數(shù)自動去掉,不管是否大于0.5,而+0.5之后大于0.5的就是進(jìn)1了,小于0.5的就
- //算加上0.5,還是在小數(shù)點(diǎn)后面。
- else
- DisplayData1[0] = 0x00;
- tp=temp;//因?yàn)閿?shù)據(jù)處理有小數(shù)點(diǎn)所以將溫度賦給一個(gè)浮點(diǎn)型變量
- //如果溫度是正的那么,那么正數(shù)的原碼就是補(bǔ)碼它本身
- DisplayData1[1] = smgduan1[temp / 10000];
- DisplayData1[2] = smgduan1[temp % 10000 / 1000];
- DisplayData1[3] = 0x2e;
- DisplayData1[4] = smgduan1[temp % 100 / 10];
- DisplayData1[5] = smgduan1[temp % 10];
- void datapros()
- Ds1302ReadTime();
- DisplayData[0] = smgduan[TIME[2]/16]; //時(shí)
- DisplayData[1] = smgduan[TIME[2]&0x0f];
- DisplayData[2] = 0x40;
- DisplayData[3] = smgduan[TIME[1]/16]; //分
- DisplayData[4] = smgduan[TIME[1]&0x0f];
- DisplayData[5] = 0x40;
- DisplayData[6] = smgduan[TIME[0]/16]; //秒
- DisplayData[7] = smgduan[TIME[0]&0x0f];
- void delay(uint i)
- while(i--);
- void DigDisplay()
- uchar i;
- for(i=0;i<8;i++)
- switch(i) //位選,選擇點(diǎn)亮的數(shù)碼管,
- case(0):
- LSA=0;LSB=0;LSC=0; break;//顯示第0位
- case(1):
- LSA=1;LSB=0;LSC=0; break;//顯示第1位
- case(2):
- LSA=0;LSB=1;LSC=0; break;//顯示第2位
- case(3):
- LSA=1;LSB=1;LSC=0; break;//顯示第3位
- case(4):
- LSA=0;LSB=0;LSC=1; break;//顯示第4位
- case(5):
- LSA=1;LSB=0;LSC=1; break;//顯示第5位
- case(6):
- LSA=0;LSB=1;LSC=1; break;//顯示第6位
- case(7):
- LSA=1;LSB=1;LSC=1; break;//顯示第7位
- P0=DisplayData[7-i];//發(fā)送數(shù)據(jù)
- delay(100); //間隔一段時(shí)間掃描
- P0=0x00;//消隱
- void buzzer()
- beep=0;
- Delayms(100);
- beep=1;
- void lw()
- uint i;
- led=0xfe;
- delay(50000);
- for(i=0;i<7;i++) //將led左移一位
- led=_crol_(led,1);
- delay(50000); //大約延時(shí)450ms
- for(i=0;i<7;i++) //將led右移一位
- led=_cror_(led,1);
- void user_password()
- uint i,n=0,key=0;
- for(i=0;i<4;i++)
- if(KeyPro()!=0xff)
- Delayms(5);
- userpassword[i]=KeyPro();
- while(KeyPro()!=0xff);
- for(i=0;i<4;i++)
- if(userpassword[i]==password[i])
- Delayms(5);
- key++;
- if(key==4)
- buzzer();
- n++;
- else
- lw();
- n=0;
- void admin_password()
- uint i,j,t=0;
- for(i=0;i<4;)
- if(userpassword[i]=='/')
- Delayms(10);
- t++;
- if(t==4)
- for(j=0;j<4;j++)
- password[j]=KeyPro();
- void main()
- uint num;
- Ds1302Init();
- LCD_Init();
- while(1)
- user_password();
- admin_password();
- datapros(); //數(shù)據(jù)處理函數(shù)
- DigDisplay();
- datapros1(Ds18b20ReadTemp()); //數(shù)據(jù)處理函數(shù)
- LCD_Write_Com(0x80);
- for(num=0;num<9;num++)
- LCD_Write_Data(DisplayData1[num]);
- Delayms(5);
