藍(lán)牙舵機(jī)小車
關(guān)于這個(gè)程序有什么問題盡管提問
#include <reg51.h>
typedef unsigned int u16; //對數(shù)據(jù)類型進(jìn)行聲明定義
typedef unsigned char u8;
sbit IRIN=P3^2;
sbit IN1=P1^0;
sbit IN2=P1^1;
sbit ENA=P0^2;
sbit pwm=P2^1;//輸出PWM信號(hào)
sbit k1=P3^2;
u8 a,b,c;
void delay(int i)
while(i--);
void uart_init()
TMOD|=0x20;
PCON =0x00;
SCON = 0x50;
TH1 = 0xFd; //設(shè)置波特率 9600
TL1 = 0xFd;
TR1 = 1; //啟動(dòng)定時(shí)器1
ES = 1; //開串口中斷
EA = 1; //開總中斷
void uart() interrupt 4
if(RI==1)
RI=0;
a=SBUF;
void InitTimer()
TMOD|=0x01;//開定時(shí)器0,1
TH0=0xff;//定時(shí)1.5MS,這時(shí)舵機(jī)處于0度
TL0=0xf6;
EA=1;//開總斷
ET0=1;
TR0=0;
void timer0() interrupt 1//定時(shí)器0中斷函數(shù)
TL0=0xf6;
b++;
if(b==1) pwm=0;
else if(b==2) pwm=1;
else if(b==c) b=0;
TR0=0;
void Int0Init()
EX0=0;
IT0=0;
EA=1;
void Int0() interrupt 0
while(k1==0)
if(a==0x03)
c=26;
k1=1;
EX0=0;
else if(a==0x04)
c=37;
k1=1;
EX0=0;
else if(a==0x01)
c=31;
k1=1;
EX0=0;
InitTimer();
uart_init();
Int0Init();
TR0=0;
if(a==0x01)
IN1=0;
IN2=1;
EX0=1;
TR0=1;
k1=0;
} //左轉(zhuǎn) 28 2
else if(a==0x02)
EX0=1;
TR0=0;
IN1=1;
IN2=0;
//else if(a==0x00)
else if(a==0x03)
EX0=1;
TR0=1;
k1=0;
else if(a==0x04)
EX0=1;
TR0=1;
k1=0;
else if(a==0x05)
IN1=0;
IN2=0;
