有大哥幫幫忙嗎,看看那里有問題,51單片機做一個藍牙小車程序,pwm中斷和串口中斷沖突,幫忙看看那里有問題, 感謝感謝。
#include <reg52.h>
sbit EN1 = P2^0; //為1 右電機使能
sbit EN2 = P2^1; //為1 左電機使能
sbit IN1 = P2^2; //為1 右電機反轉
sbit IN2 = P2^3; //為1 右電機正轉
sbit IN3 = P2^4; //為1 左電機正轉
sbit IN4 = P2^5; //為1 左電機反轉
#define left_motor_en EN1 = 1 //左電機使能
#define left_motor_stops EN1 = 0 //左電機停止
#define right_motor_en EN2 = 1 //右電機使能
#define right_motor_stops EN2 = 0 //右電機停止
#define left_motor_go IN1 = 0, IN2 = 1 //左電機正傳
#define left_motor_back IN1 = 1, IN2 = 0 //左電機反轉
#define right_motor_go IN3 = 1, IN4 = 0 //右電機正傳
#define right_motor_back IN3 = 0, IN4 = 1 //右電機反轉
double count = 0;//定義占空比,并初始占空比為26%
unsigned char time;
unsigned char pwm_left_val = 0;//左電機占空比值 取值范圍0-170,0最快
unsigned char pwm_right_val = 0;//右電機占空比值取值范圍0-170 ,0最快
unsigned char pwm_t; //周期
void UART_INIT(); //藍牙接收初始化
void Che_init(); //小車輸出端口定時器初始化
void forward(); //小車前進
void back(); //小車后退
void right(); //小車左轉
void left(); //小車右轉
void stop(); //小車停止
void delay(unsigned int z); //延時函數
while(1);
void UART_INIT() //藍牙接收初始化
SCON = 0X50;
TMOD = 0x20; //8位自動重裝模式
TH1 = 0xfd;
TL1 = 0xfd; //9600波特率
TR1 = 1; //啟動定時器1
ES = 1; //開串口中斷
EA = 1; //開總中斷
void Che_init() //小車使能輸出端口定時器初始化
TMOD|= 0x02; //8位自動重裝模塊
TH0=(65536-10)/256;
TL0=(65536-10)%256;
TR0=1;
ET0=1;
EA=1;
TH0 = 220;
TL0 = 220; //11.0592M晶振下占空比最大比值是256,輸出100HZ
TR0 = 1; //啟動定時器0
ET0 = 1; //允許定時器0中斷
EA = 1; //總中斷允許
void forward() //小車前進
ET0 = 1;
TR0 = 1;
left_motor_go; //左電機前進
right_motor_go; //右電機前進
count += 0.1;
void back() //小車后退
ET0 = 1;
TR0 = 1;
left_motor_back; //左電機反轉
right_motor_back; //右電機反轉
void right() //小車左轉
ET0 = 1;
TR0 = 1;
left_motor_go; //左電機正傳
void left() //小車右轉
ET0 = 1;
TR0 = 1;
right_motor_go; //右電機正傳
void stop() //小車停止
ET0 = 0;
TR0 = 0;
count = 0;
left_motor_stops; //左電機停止
right_motor_stops; //右電機停止
void timer0() interrupt 1 //定時器0中斷
TR0 = 0; //設置定時器初值期間,關閉定時器
TH0=(65536-10)/256;
TL0=(65536-10)%256;
//TR0=1;
time++;
//count += 0.1;
if(time<count)
EN1 = 1; //輸出高電平
EN2 = 1; //輸出高電平
EN1 = 0; //輸出低電平
EN2 = 0; //輸出低電平
if(time>=1000)
time=0;
pwm_t++;
if(pwm_t == 255)
EN1 = 0;
EN2 = 0;
pwm_t = 0;
if(pwm_left_val == pwm_t)
EN1 = 1;
if(pwm_right_val == pwm_t)
EN2 = 1;*/
void UART_SER() interrupt 4 //串口中斷
if(RI)
RI = 0;//清除接收標志
switch(SBUF)
case 'a': //前進
forward();
break;
case 'b': //后退
back();
break;
case 'l': //左轉
right();
break;
case 'r': //右轉
left();
break;
case 's': //停止
stop();
break;
default: //否則全部停止
stop();
break;
unsigned int x,y;
for(x = z; x > 0; x--)
for(y = 114; y > 0 ; y--);
