查看: 891|回復: 1
單片機小白求助 有關數碼管的動態顯示
ID:479317 發表于 2019-2-22 14:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
剛開始學習51單片機..一步一步照著書上來..
按照書上的程序寫的 按書上的應該是秒表計時的效果...可我的為什么是流水燈效果...
希望各位能幫我看看~ 萬分感激~
#include<reg52.h>
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
unsigned char code LedChar[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                                        0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char LedBuff[6] = {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
        unsigned char i = 0;
        unsigned int cnt = 0; //記錄T0中斷次數
        unsigned char flag1s = 0; // 1s定時標志
        unsigned long sec = 0;
        EA = 1;
        TMOD = 0x01;
        TH0 = 0xFC;
        TL0 = 0x67;
        ET0 = 1;
        TR0 = 1;
                if(flag1s == 1) // 判斷1s定時標志
                        flag1s = 0;
                        sec++;
                        LedBuff[0] = LedChar[sec%10];
                        LedBuff[1] = LedChar[sec/10%10];
                        LedBuff[2] = LedChar[sec/100%10];
                        LedBuff[3] = LedChar[sec/1000%10];
                        LedBuff[4] = LedChar[sec/10000%10];
                        LedBuff[5] = LedChar[sec/100000%10];
void InterruptTimer0() interrupt 1
        if(TF0 == 1)
                TF0 = 0;
                TH0 = 0xFC;
                TL0 = 0x67;
                cnt++;
        if(cnt>=1000)
                cnt = 0;
                flag1s = 1;
        P0 = 0xFF;
        switch(i)
                                case 0:LSA = 0;LSB = 0;LSC = 0;i++;P0 = LedBuff[0];break;/*Y0*/
                                case 1:LSA = 1;LSB = 0;LSC = 0;i++;P0 = LedBuff[1];break;/*Y1*/
                                case 2:LSA = 0;LSB = 1;LSC = 0;i++;P0 = LedBuff[2];break;/*Y2*/
                                case 3:LSA = 1;LSB = 1;LSC = 0;i++;P0 = LedBuff[3];break;/*Y3*/
                                case 4:LSA = 0;LSB = 0;LSC = 1;i++;P0 = LedBuff[4];break;/*Y4*/
                                case 5:LSA = 1;LSB = 0;LSC = 1;i=0;P0 = LedBuff[5];break;/*Y5*/
                                default:break;
ID:479317 發表于 2019-2-22 15:13 | 只看該作者
已經解決了 中斷函數那里弄錯了 謝謝大家
參與人數 1黑幣 +90 收起 理由
admin + 90 回帖助人的獎勵!
