查看: 6127|回復(fù): 1
51單片機(jī)入門之不同按鍵實(shí)現(xiàn)數(shù)碼管顯示0到20程序
可以通過不同按鍵實(shí)現(xiàn)數(shù)碼管顯示0到20這些數(shù),兩個(gè)數(shù)碼管一個(gè)代表各位,一個(gè)代表十位
#include <reg51.h>
sbit K1=P2^0;
sbit K2=P2^1;
sbit K3=P2^2;
sbit K4=P2^3;
uchar code F[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x3F,0x06,0x5B,0x4F,0x66,0x6D};
uchar code S[]={0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x06,0x06,0x06,0x06,0x06,0x06};
  uchar b,fir,sec,third,forth;
  fir=K1;
  sec=K2;
  third=K3;
  forth=K4;
  b=fir*8+sec*4+third*2+forth*1;
  P0=F[15-b];
  P1=S[15-b];
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
收藏收藏1 分享淘帖 頂1 踩
ID:357520 發(fā)表于 2019-3-3 23:01 | 只看該作者
這個(gè)顯示的是0-19
