查看: 1022|回復: 1
5110顯示超聲波(部分函數 在庫里) 求幫助
ID:477447 發表于 2019-2-17 17:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "nokia_5110.h"
#include <stc12c5a60s2.h>
#include <intrins.h>
#include "delay.h"
#include "GPIO.h"
sbit Trig=P4^4;
sbit Echo=P4^5;
unsigned long time;
unsigned long distance;
void Display(void);
GPIO_init_pin(44,0);//雙向口
GPIO_init_pin(45,0);
LCD_init();
  LCD_clear();
EA=1;
TMOD=0x01;
TR0=0;
TH0=0;
TL0=0;
  Trig=1;
  exact_delay(1,2,12);
  Trig=0;
  while(Echo==1);
  TR0=1;
  while(Echo==0);
  TR0=0;
  time=TH0*256+TL0;
  distance=(time*340)/2;
  delay_X_ms(100);
  Dispaly();
void Display()
unsigned char unit,ten,hundred,thousand,shifenwei,baifenwei;
   unit=distance/ % 10;
    ten=distance/ 10 % 10;
    hundred = distance/ 100 % 10;
    thousand = distance / 1000 % 10;
   shifenwei= (distance*10)%10;
   baifenwei= (distance*100)%10;
  if(time>8000)
   LCD_write_english_string(3,2,"chao guo");
   LCD_set_XY(4,3);
   LCD_write_number(thousand);
  LCD_set_XY(5,3);
   LCD_write_number(hundred);
  LCD_set_XY(6,3);
   LCD_write_number(ten);
  LCD_set_XY(7,3);
   LCD_write_number(unit);
  LCD_set_XY(8,3);
   LCD_write_number();
  LCD_set_XY(9,3);
   LCD_write_number(shifenwei);
  LCD_set_XY(10,3);
   LCD_write_number(baifenwei);
ID:477447 發表于 2019-2-17 17:47 | 只看該作者
但是 顯示 不出來   程序 有問題嗎
