查看: 2173|回復: 0
單片機藍牙小車pwm可調程序
ID:458796 發(fā)表于 2019-2-17 14:41 | 顯示全部樓層 |閱讀模式
藍牙小車pwm可調,手機用藍牙串口助手,百度,應用寶都可下載。
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. uint i;
  5. sbit zuo=P2^0;
  6. sbit int1=P1^1;
  7. sbit int2=P1^2;
  8. sbit you=P2^1;
  9. sbit int3=P1^4;
  10. sbit int4=P1^5;
  11. sbit bee=P2^5;
  12. sbit led=P1^3;
  13. uchar zuopower;
  14. uchar youpower;
  15. uchar receive_data;
  16. uchar num;
  17. void init()
  18. {
  19.         TMOD=0x21;
  20.         TH0=(65536-100)/256;
  21.         TL0=(65536-100)%256;
  22.         ET0=1;
  23.         TR0=1;
  24.         EA=1;
  25. }
  26. void time0() interrupt 1
  27. {
  28.         TH0=(65536-100)/256;
  29.         TL0=(65536-100)%256;
  30.         num++;
  31.         if(num<=youpower)
  32.         {
  33.           you=1;
  34.          }
  35.         else   if(num<=100)
  36.                     {you=0;}
  37.         if(num<=zuopower)
  38.         {
  39.                 zuo=1;
  40.         }
  41.         else  if(num<=100)
  42.                  {zuo=0;}
  43.
  44.         if(num>100)
  45.         {
  46.                 num=0;
  47.         }
  48. }
  49. void youzhuan(int v)//
  50. {
  51.                         int1=1;
  52.                         int2=0;
  53.                         int3=1;
  54.                         int4=0;
  55.                         zuopower=v;
  56.                         youpower=v;
  57.
  58. }
  59. void zuozhuan(int v)//
  60. {
  61.                         int1=0;
  62.                         int2=1;
  63.                         int3=0;
  64.                         int4=1;
  65.                         zuopower=v;
  66.                         youpower=v;
  67.
  68. }
  69. void fan(int v)
  70. {
  71.                         int1=1;
  72.                         int2=0;
  73.                         int3=0;
  74.                         int4=1;
  75.                         zuopower=v;
  76.                         youpower=v;
  77. }
  78. void zheng(int v)
  79. {
  80.                         int1=0;
  81.                         int2=1;
  82.                         int3=1;
  83.                         int4=0;
  84.                         zuopower=v;
  85.                         youpower=v;
  86.
  87. }
  88. void ting(int v)
  89. {
  90.                         int1=1;
  91.                         int2=1;
  92.                         int3=1;
  93.                         int4=1;
  94.                         zuopower=v;
  95.                         youpower=v;
  96.
  97. }
  98. void kong(int v)
  99. {
  100.                         int1=0;
  101.                         int2=0;
  102.                         int3=0;
  103.                         int4=0;
  104.                         zuopower=v;
  105.                         youpower=v;
  106.
  107. }
  108. void Com_Int(void) interrupt 4
  109. {
  110.
  111.   EA = 0;
  112.
  113.   if(RI == 1)
  114.         {
  115.                 RI = 0;
  116.                 receive_data = SBUF;
  117.         }
  118.
  119.                 EA = 1;
  120. }
  121. void UsartConfiguration()
  122. {
  123.         SCON=0X50;
  124.         TMOD=0X21;
  125.         PCON=0X00;
  126.         TH1=0XFd;
  127.         TL1=0XFd;
  128.         TR1=1;
  129.         ES = 1;
  130.   EA = 1;
  131. }
  132. void main()
  133. {
  134.         i=20;
  135.         init();
  136.         UsartConfiguration();
  137.         while(1)
  138.                 {
  139.                         switch(receive_data)
  140.                         {
  141.                                 case'1':led=0;bee=0;break;
  142.                                 case'8':led=1;bee=1;break;
  143.                                 case'0':kong(i);break;
  144.                                 case'2':youzhuan(i);break;                //右轉
  145.                                 case'3':zuozhuan(i);break;                        //左轉
  146.                                 case'4':fan(i);break;//后退
  147.                                 case'5':zheng(i);break;//前進
  148.                                 case'6':ting(i);break;
  149.                                 case'9':
  150.                                 {
  151.                                         i=i+10;
  152.                                         receive_data=8;
  153.                                         break;
  154.                                 }
  155.                                 case'7':
  156.                                 {
  157.                                         i=i-10;
  158.                                         receive_data=8;
  159.                                         break;
  160.                                 }
  161.
  162.                         }
  163.                 };
  164. }
藍牙小車.rar (27.28 KB, 下載次數(shù): 13)
