查看: 614|回復: 0
誰在找大型點陣屏的,這邊有
ID:472242 發表于 2019-2-7 04:38 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
typedef  unsigned char uchar;
typedef  unsigned int uint;
sbit E1=P3^4;
sbit ST=P3^5;
sbit SS=P3^6;
unsigned char code oo[]= 大屏幕點陣滾動顯示.rar (24.12 KB, 下載次數: 0)
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x20,0x20,0x27,0x24,0x24,0x26,0x2D,0xF4,0x24,0x25,0x26,0x24,0x24,0x67,0x20,0x00,
0x00,0x00,0x00,0x7E,0x52,0x52,0x52,0x52,0x52,0x52,0x52,0x7E,0x00,0x00,0x00,0x00,
0x01,0x01,0x3F,0x69,0xA5,0x3F,0x00,0x10,0x17,0x94,0x54,0x17,0x10,0x10,0x00,0x00,
0x08,0x30,0x21,0x22,0x24,0x28,0xA0,0x60,0x20,0x28,0x24,0x22,0x21,0x28,0x30,0x00,
0x04,0x04,0x04,0x04,0x04,0x04,0x05,0xFE,0x05,0x04,0x04,0x04,0x04,0x04,0x04,0x00,
0x02,0x0C,0x08,0x48,0x3A,0x2A,0x0A,0x8A,0x7A,0x2B,0x0A,0x18,0xEA,0x4C,0x08,0x00,
0x00,0x00,0x00,0x1F,0x12,0x12,0x32,0xD2,0x52,0x12,0x12,0x12,0x1F,0x00,0x00,0x00,
0x04,0x24,0x24,0x27,0x24,0x24,0x24,0x04,0x08,0x08,0xFF,0x08,0x08,0x0F,0x00,0x00,
0x01,0x02,0x04,0x1F,0xE0,0x40,0x00,0x00,0xFF,0x03,0x06,0x0C,0x38,0x10,0x00,0x00,
0x7F,0x40,0x4C,0x52,0x61,0x30,0x24,0x24,0xA4,0x64,0x24,0x24,0x24,0x30,0x20,0x00,
0x00,0x01,0x06,0x78,0x08,0x08,0x08,0x08,0xFF,0x48,0x08,0x08,0x19,0x08,0x00,0x00,
0x02,0x3C,0x08,0xFF,0x08,0x0B,0x04,0x18,0xF3,0x1C,0x10,0x1F,0x10,0x1F,0x00,0x00,
0x00,0x7F,0x42,0x45,0x79,0x49,0x49,0x49,0x4F,0x49,0x49,0x49,0x4B,0x41,0x00,0x00,
0x00,0x00,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x40,0x40,0x40,0x40,0x00,0x00,
0x08,0x48,0x4B,0x7F,0x89,0x88,0x01,0xFD,0x85,0x85,0x85,0x85,0xFD,0x01,0x00,0x00,
0x00,0x00,0x40,0x44,0x4D,0x55,0x66,0x46,0x44,0x88,0xB2,0x81,0x80,0x80,0x00,0x00,
0x00,0x07,0x08,0x10,0x10,0x08,0x07,0x00,0x00,0x1F,0x10,0x11,0x11,0x10,0x10,0x00,
0x00,0x07,0x08,0x10,0x10,0x08,0x07,0x00,0x00,0x0E,0x11,0x10,0x10,0x11,0x0E,0x00,
0x00,0x00,0x03,0x04,0x08,0x1F,0x00,0x00,0x00,0x0E,0x10,0x10,0x10,0x11,0x0E,0x00,
0x42,0x42,0x7F,0x42,0x42,0x07,0x00,0xFF,0x00,0x42,0x42,0x7F,0x42,0x42,0x42,0x00,
0x20,0x2F,0x2A,0xFA,0x2A,0x2F,0x00,0x20,0x24,0x24,0xFF,0x24,0x24,0x24,0x20,0x00,
0x3F,0x20,0x20,0x3F,0x00,0x2A,0x2A,0x2A,0xFF,0x2A,0x2A,0x2A,0x3E,0x08,0x08,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x18,0x20,0x40,0x80,0x80,0x00,0x00,
0x00,0x0A,0xF2,0x52,0x12,0xFF,0x12,0x12,0x12,0x00,0x3F,0x00,0x00,0xFF,0x00,0x00,
0x01,0x02,0x04,0x1F,0xE0,0x44,0x18,0x30,0xDF,0x12,0x12,0x12,0x16,0x12,0x10,0x00,
0x00,0x80,0x80,0x40,0x20,0x18,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char code mo[]=
0x00,0x00,0xFE,0x20,0xA0,0xA0,0xA0,0xFE,0xA0,0xA0,0xA0,0xA4,0x22,0xFC,0x00,0x00,
0x00,0x00,0xFE,0xA4,0xA4,0xA4,0xA4,0xA4,0xA4,0xA4,0xA4,0xA4,0xFE,0x00,0x00,0x00,
0x01,0x06,0xF8,0x42,0x21,0xFE,0x01,0x06,0xF8,0x00,0x00,0xFC,0x02,0x02,0x0E,0x00,
0x00,0x02,0x02,0x82,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0x82,0x02,0x02,0x00,0x00,
0x00,0x01,0x02,0x04,0x08,0x30,0xC0,0x00,0x80,0x60,0x10,0x0C,0x06,0x03,0x02,0x00,
0x00,0x40,0x40,0x40,0x40,0x40,0x42,0x41,0xFE,0x40,0x40,0x40,0x40,0x40,0x40,0x00,
0x00,0x00,0x00,0xFF,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0xFF,0x00,0x00,0x00,
0x10,0x38,0xD0,0x10,0x30,0xA0,0x72,0x24,0x08,0x30,0xC0,0x04,0x02,0xFC,0x00,0x00,
0x00,0x00,0x00,0xFE,0x00,0x20,0x40,0x80,0xFC,0x02,0x02,0x02,0x02,0x1E,0x00,0x00,
0xFF,0x00,0x40,0x20,0xC1,0x82,0x8C,0xF0,0x80,0x80,0xFE,0x81,0x81,0x81,0x8F,0x00,
0x80,0x02,0x02,0x82,0x82,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0x82,0x86,0x02,0x00,
0x20,0x20,0x40,0xFE,0x80,0x22,0x44,0x88,0x10,0x20,0xC2,0x01,0x02,0xFC,0x00,0x00,
0x00,0xFE,0x02,0x02,0x0A,0x12,0x22,0xC2,0x02,0x82,0x42,0x3A,0x12,0x02,0x02,0x00,
0x04,0x04,0x04,0x04,0x04,0x04,0x04,0xFC,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00,
0x20,0xC0,0x00,0xFF,0x00,0x82,0x22,0x22,0x22,0xFE,0x22,0x22,0x22,0x22,0x02,0x00,
0x00,0x02,0x84,0xC8,0x90,0xA0,0x82,0x81,0xFE,0x80,0xA0,0x90,0xC8,0x46,0x00,0x00,
0x00,0xF0,0x08,0x04,0x04,0x08,0xF0,0x00,0x00,0x98,0x84,0x04,0x04,0x88,0x70,0x00,
0x00,0xF0,0x08,0x04,0x04,0x08,0xF0,0x00,0x00,0x38,0x44,0x84,0x84,0x44,0x38,0x00,
0x00,0xE0,0x20,0x24,0x24,0xFC,0x24,0x00,0x00,0x0C,0x14,0x24,0x44,0x84,0x0C,0x00,
0x08,0x08,0xF0,0x11,0x92,0x04,0x18,0xE0,0x04,0x04,0x04,0xFC,0x04,0x04,0x04,0x00,
0x20,0xA0,0xA0,0xFF,0xA0,0xA0,0x20,0x80,0x80,0x80,0xFF,0x80,0x88,0x84,0xF8,0x00,
0xE0,0x40,0x40,0xE0,0x06,0xF8,0x30,0x40,0xFE,0x80,0x70,0x20,0xFE,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x18,0x04,0x02,0x01,0x01,0x00,0x00,
0x00,0x00,0xFC,0x80,0x80,0xFF,0x84,0x86,0xFC,0x00,0xF0,0x02,0x01,0xFE,0x00,0x00,
0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0xFF,0x20,0x20,0x20,0x20,0x60,0x20,0x00,
0x00,0x01,0x01,0x02,0x04,0x18,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
void yiwei(int i)
SBUF=oo;
while(~TI){};
TI=0;
SBUF=mo;
while(~TI){};
TI=0;
void main() /*主函數*/
{        int i=0,j=0,k=0,n=0,u,d,m,o;
        SM0=0;
        SM1=0;
        ST=0;
        TI=0;
        n=0;
                  k=d;
                  o=0;
                  for(m=0;m<63;m++)
                  {i=k+o;
                   for(j=0;j<6;j++)
                     {yiwei(i);
                      i=i+16;
                    ST=1;
                   P2=o;
                   E1=0;
                   for(u=0;u<75;u++){};
                   o++;
                   if(o==16)
           o=0;
                   E1=1;
                   ST=0;
                   //for(u=0;u<1000;u++){};
                d++;
                if(d==610)
                d=0;
