- 此文件中將來自O(shè)LED_Fuction.c中的顯示函數(shù)按程序狀態(tài)封裝,調(diào)用時更新特定顯示
- #include"OLED_Fuction.c"
- #include"RFID_Fuction.c"
- #include"BMP180_Fuction.c"
- extern unsigned char display_hour[];
- extern unsigned char display_minute[];
- extern unsigned char display_month[];
- extern unsigned char display_day[];
- extern unsigned char display_year[];
- extern unsigned char display_second[];
- extern unsigned char display_week;
- extern unsigned char Space_State[4];
- extern long BMP180_Temperature;
- extern long BMP180_Pressure;
- extern unsigned char choose;
- extern unsigned char first_num;
- extern bit User_Locker;
- extern bit Admin_Info;
- extern bit En_Fire_Sensor;
- extern bit En_RFID;
- void OLED_Admin_RFID_Manage(void);
- void delay2(unsigned int cnt)//調(diào)用該函數(shù)進行一段時間的延時
- while(cnt--);
- /*####################################################用戶狀態(tài)函數(shù)##############################################*/
- void OLED_Display_Standby()//待機狀態(tài),顯示定時器0獲取的時間或通知已鎖信息
- unsigned char i;
- OLED_Show_CHinese(0,CCTitle1,1);//顯示標題:當前已鎖
- for(i=0;i<16;i++)
- OLED_Show_sChar(i*8,2,sChar3,1);//顯示橫線
- OLED_Show_Number(8,4,display_year,4,1);
- OLED_Show_cChar(40,4,cChar1,1);//年
- OLED_Show_Number(56,4,display_month,2,1);
- OLED_Show_cChar(72,4,cChar2,1);//月
- OLED_Show_Number(88,4,display_day,2,1);
- OLED_Show_cChar(104,4,cChar3,1);//日
- OLED_Show_Number(32,6,display_hour,2,1);
- OLED_Show_sChar(48,6,sChar2,1);//:
- OLED_Show_Number(56,6,display_minute,2,1);
- OLED_Show_sChar(72,6,sChar2,1);//:
- OLED_Show_Number(80,6,display_second,2,1);
- void OLED_Display_Put_In_Password()//用戶模式下輸入密碼的靜態(tài)顯示
- unsigned char i;
- for(i=0;i<16;i++)
- OLED_Show_sChar(i*8,2,sChar4,1);//顯示橫線
- OLED_Show_CHinese(4,CCInfo1,1);//顯示說明文字:請輸入密碼:
- void OLED_Display_Right_Password()//用戶模式下輸入密碼正確的靜態(tài)提示信息
- unsigned char i;
- OLED_Show_CHinese(0,CCTitle3,1);//顯示標題:密碼正確
- for(i=0;i<16;i++)
- OLED_Show_CHinese(6,CCInfo6,1);//顯示說明文字:繼電器已啟用
- void OLED_User_Mode()//用戶模式菜單動態(tài)顯示,因為容量小于等于3個,一屏可以放得下,所以不加滾屏功能,僅在兩個選項中跳動
- OLED_Show_CHinese(0,CCTitle4,0);//顯示標題:用戶模式
- switch(choose)
- case 1:OLED_Show_CHinese(2,CCList_user_1,0);OLED_Show_CHinese(4,CCList_user_2,1);break;
- case 2:OLED_Show_CHinese(2,CCList_user_1,1);OLED_Show_CHinese(4,CCList_user_2,0);break;
- if(KEY3==0)//上調(diào)按鍵
- delay2(5000);
- if(KEY3==0)
- choose--;
- if(choose==0)choose=1;//選項最少不能小于1
- while(!KEY3);
- if(KEY4==0)//下調(diào)按鍵
- delay2(5000);
- if(KEY4==0)
- choose++;
- if(choose==3)choose=2;//選項最大不能大于2
- while(!KEY4);
- /*######################################################管理員狀態(tài)函數(shù)############################################*/
- void OLED_Display_Administrator_Onload()//管理員登入靜態(tài)顯示
- unsigned char i;
- OLED_Show_CHinese(0,CCTitle5,1);//顯示標題:管理模式
- for(i=0;i<16;i++)
- OLED_Show_sChar(i*8,2,sChar5,1);//顯示橫線
- OLED_Show_CHinese(4,CCInfo3,1);//顯示說明文字:請輸入口令:
- void OLED_Display_Menu(unsigned char menu_num,unsigned char choose)
- {//定制的菜單顯示接口函數(shù),用于將菜單變量名和調(diào)用它的變量值連接起來,需要知道顯示的起始菜單號和當前選中的菜單
- switch(menu_num)
- case 1:
- OLED_Show_CHinese(2,CCList_admin_1,!(choose==1));
- OLED_Show_CHinese(4,CCList_admin_2,!(choose==2));
- OLED_Show_CHinese(6,CCList_admin_3,!(choose==3));
- break;
- case 2:
- OLED_Show_CHinese(2,CCList_admin_2,!(choose==2));
- OLED_Show_CHinese(4,CCList_admin_3,!(choose==3));
- OLED_Show_CHinese(6,CCList_admin_4,!(choose==4));
- break;
- case 3:
- OLED_Show_CHinese(2,CCList_admin_3,!(choose==3));
- OLED_Show_CHinese(4,CCList_admin_4,!(choose==4));
- OLED_Show_CHinese(6,CCList_admin_5,!(choose==5));
- break;
- case 4:
- OLED_Show_CHinese(2,CCList_admin_4,!(choose==4));
- OLED_Show_CHinese(4,CCList_admin_5,!(choose==5));
- OLED_Show_CHinese(6,CCList_admin_6,!(choose==6));
- break;
- case 5:
- OLED_Show_CHinese(2,CCList_admin_5,!(choose==5));
- OLED_Show_CHinese(4,CCList_admin_6,!(choose==6));
- OLED_Show_CHinese(6,CCList_admin_7,!(choose==7));
- break;
- case 6:
- OLED_Show_CHinese(2,CCList_admin_6,!(choose==6));
- OLED_Show_CHinese(4,CCList_admin_7,!(choose==7));
- OLED_Show_CHinese(6,CCList_admin_8,!(choose==8));
- break;
- case 7:
- OLED_Show_CHinese(2,CCList_admin_7,!(choose==7));
- OLED_Show_CHinese(4,CCList_admin_8,!(choose==8));
- OLED_Show_CHinese(6,CCList_admin_9,!(choose==9));
- break;
- void OLED_Admin_Mode()//管理模式菜單動態(tài)顯示
- //static unsigned char first_num=1;//第一項菜單標號
- OLED_Show_CHinese(0,CCTitle5,0);//顯示標題:管理模式
- OLED_Display_Menu(first_num,choose);//根據(jù)first_num和choose的動態(tài)刷新顯示函數(shù)
- delay2(5000);
- if(KEY3==0)
- choose--;
- if(choose<first_num)first_num--;
- while(!KEY3);
- delay2(5000);
- if(KEY4==0)
- choose++;
- if(choose==10)choose=9;//選項最大不能大于9
- if(choose>first_num+2)first_num++;
- while(!KEY4);
- void OLED_Admin_onoff_Mode()//常開常關(guān)選項,因為容量小于等于3個,一屏可以放得下,所以不加滾屏功能,僅在兩個選項中跳動
- unsigned char choose_possition;//用于存放進入此級菜單時上一級choose的值
- choose_possition=choose;
- OLED_Clear();
- OLED_Show_CHinese(0,CCTitle9,0);//顯示標題:開關(guān)選項
- while(!KEY1);//等待按鍵松開
- choose=1;
- while(1)
- switch(choose)
- case 1:OLED_Show_CHinese(2,CCList_onoff_1,0);OLED_Show_CHinese(4,CCList_onoff_2,1);break;
- case 2:OLED_Show_CHinese(2,CCList_onoff_1,1);OLED_Show_CHinese(4,CCList_onoff_2,0);break;
- if(KEY1==0)//確定按鍵
- delay2(5000);
- if(KEY1==0)
- switch(choose)
- case 1:
- JDQ=0;//開啟繼電器,由于繼電器所在接口的位定義不再此文件中,故直接使用單片機頭文件中的IO口定義
- User_Locker=1;//用戶鎖定
- Admin_Info=1;//管理員開鎖通知開,該提示信息在用戶代碼處修改
- break;
- case 2:
- JDQ=1;//開啟繼電器,由于繼電器所在接口的位定義不再此文件中,故直接使用單片機頭文件中的IO口定義
- User_Locker=0;//用戶解鎖
- Admin_Info=0;//管理員開鎖通知關(guān),該提示信息在用戶代碼處修改
- break;
- while(!KEY1);
- OLED_Clear();
- goto OUT2;
- if(KEY2==0)//取消按鍵
- delay2(5000);
- if(KEY2==0)
- choose=1;//重置菜單選擇位
- while(!KEY2);
- OLED_Clear();
- goto OUT2;
- delay2(5000);
- if(KEY3==0)
- choose--;
- while(!KEY3);
- delay2(5000);
- if(KEY4==0)
- choose++;
- while(!KEY4);
- OUT2:choose=choose_possition;//將之前存儲的值還給choose以保證上級菜單不出現(xiàn)錯亂
- void OLED_Admin_firesensor_Mode()//火焰探測器開關(guān)選項,因為容量小于等于3個,一屏可以放得下,所以不加滾屏功能,僅在兩個選項中跳動
- OLED_Clear();
- OLED_Show_CHinese(0,CCTitle11,0);//顯示標題:火焰探測
- choose=1;
- while(1)
- switch(choose)
- case 1:OLED_Show_CHinese(2,CCList_firesensor_1,0);OLED_Show_CHinese(4,CCList_firesensor_2,1);break;
- case 2:OLED_Show_CHinese(2,CCList_firesensor_1,1);OLED_Show_CHinese(4,CCList_firesensor_2,0);break;
- if(KEY1==0)//確定按鍵
- delay2(5000);
- if(KEY1==0)
- switch(choose)
- case 1:
- En_Fire_Sensor=0;//關(guān)閉火焰探測器使能位
- break;
- case 2:
- En_Fire_Sensor=1;//使能火焰探測器
- break;
- while(!KEY1);
- OLED_Clear();
- goto FSMENUQUIT;
- if(KEY2==0)//取消按鍵
- delay2(5000);
- if(KEY2==0)
- while(!KEY2);
- OLED_Clear();
- goto FSMENUQUIT;
- delay2(5000);
- if(KEY3==0)
- choose--;
- while(!KEY3);
- delay2(5000);
- if(KEY4==0)
- choose++;
- while(!KEY4);
- FSMENUQUIT:choose=choose_possition;//將之前存儲的值還給choose以保證上級菜單不出現(xiàn)錯亂
- void OLED_Admin_RFID_Mode()//RFID選項,因為容量小于等于3個,一屏可以放得下,所以不加滾屏功能,僅在3個選項中跳動
- OLED_Clear();
- OLED_Show_CHinese(0,CCTitle14,0);//顯示標題:RFID
- choose=1;
- while(1)
- switch(choose)
- case 1:OLED_Show_CHinese(2,CCList_RFID_1,0);OLED_Show_CHinese(4,CCList_RFID_2,1);OLED_Show_CHinese(6,CCList_RFID_3,1);break;
- case 2:OLED_Show_CHinese(2,CCList_RFID_1,1);OLED_Show_CHinese(4,CCList_RFID_2,0);OLED_Show_CHinese(6,CCList_RFID_3,1);break;
- case 3:OLED_Show_CHinese(2,CCList_RFID_1,1);OLED_Show_CHinese(4,CCList_RFID_2,1);OLED_Show_CHinese(6,CCList_RFID_3,0);break;
- if(KEY1==0)//確定按鍵
- delay2(5000);
- if(KEY1==0)
- switch(choose)
- case 1:
- En_RFID=0;//關(guān)閉射頻卡模塊使能位
- break;
- case 2:
- En_RFID=1;//使能射頻卡模塊
- break;
- case 3:
- OLED_Admin_RFID_Manage();
- break;
- while(!KEY1);
- if(choose!=3)
- goto RFIDQUIT;
- else
- OLED_Clear();
- if(KEY2==0)//取消按鍵
- delay2(5000);
- if(KEY2==0)
- while(!KEY2);
- OLED_Clear();
- goto RFIDQUIT;
- delay2(5000);
- if(KEY3==0)
- choose--;
- while(!KEY3);
- delay2(5000);
- if(KEY4==0)
- choose++;
- if(choose==4)choose=3;//選項最大不能大于3
- while(!KEY4);
- RFIDQUIT:choose=choose_possition;//將之前存儲的值還給choose以保證上級菜單不出現(xiàn)錯亂
- void OLED_Admin_RFID_Manage()//射頻管理選項,因為容量小于等于3個,一屏可以放得下,所以不加滾屏功能,僅在3個選項中跳動
- unsigned char choose_manage;//新建一個臨時選項變量,與上兩層目錄無關(guān)
- OLED_Clear();
- OLED_Show_CHinese(0,CCTitle15,0);//顯示標題:管理RFID
- choose_manage=1;
- while(1)
- switch(choose_manage)
- case 1:
- OLED_Show_CHinese(2,CCList_admin_RFID_1,0);
- OLED_Show_CHinese(4,CCList_admin_RFID_2,1);
- OLED_Show_CHinese(6,CCList_admin_RFID_3,1);break;
- case 2:
- OLED_Show_CHinese(2,CCList_admin_RFID_1,1);
- OLED_Show_CHinese(4,CCList_admin_RFID_2,0);
- case 3:
- OLED_Show_CHinese(6,CCList_admin_RFID_3,0);break;
- if(KEY1==0)//確定按鍵
- delay2(5000);
- if(KEY1==0)
- case 1:
- /*添加卡函數(shù)*/
- Card_Add();
- break;
- case 2:
- /*刪除卡函數(shù)*/
- Card_Delete();
- break;
- case 3:
- /*對比卡函數(shù)*/
- Card_Compare();
- break;
- while(!KEY1);
- OLED_Clear();
- if(KEY2==0)//取消按鍵
- delay2(5000);
- if(KEY2==0)
- choose_manage=1;//重置菜單選擇位
- while(!KEY2);
- OLED_Clear();
- goto RFIDMQUIT;
- delay2(5000);
- if(KEY3==0)
- choose_manage--;
- if(choose_manage==0)choose_manage=1;//選項最少不能小于1
- while(!KEY3);
- delay2(5000);
- if(KEY4==0)
- choose_manage++;
- if(choose_manage==4)choose_manage=3;//選項最大不能大于3
- while(!KEY4);
- RFIDMQUIT: _nop_();
- void OLED_Display_System_Information()//顯示BMP180傳回的溫度氣壓信息
- unsigned char i;
- OLED_Clear();
- OLED_Show_CHinese(0,CCTitle10,1);//顯示標題:狀態(tài)信息
- for(i=0;i<16;i++)
- /*在此添加存儲容量檢測*/
- Storage_Check();
- OLED_Show_cChar(0,4,cChar10,1);//卡
- OLED_Show_cChar(16,4,cChar11,1);//存
- OLED_Show_cChar(32,4,cChar12,1);//儲
- OLED_Show_cChar(48,4,cChar8,1);//:
- OLED_Show_sChar(96,4,sChar13,1);///
- OLED_Show_One_Number(80,4,Space_State[0],1);
- OLED_Show_One_Number(88,4,Space_State[1],1);
- OLED_Show_One_Number(104,4,Space_State[2],1);
- OLED_Show_One_Number(112,4,Space_State[3],1);
- while(1)
- /*在此添加溫度氣壓掃描顯示函數(shù)*/
- BMP180_Calculate();
- OLED_Show_sChar(0,6,sChar9,1);//T
- OLED_Show_sChar(8,6,sChar8,1);//P
- OLED_Show_sChar(16,6,sChar2,1);//:
- OLED_Show_sChar(40,6,sChar11,1);//.
- OLED_Show_sChar(56,6,sChar12,1);//°
- OLED_Show_sChar(64,6,sChar10,1);//C
- OLED_Show_sChar(96,6,sChar11,1);//.
- OLED_Show_sChar(112,6,sChar6,1);//K
- OLED_Show_sChar(120,6,sChar7,1);//p
- OLED_Show_One_Number(24,6,BMP180_Temperature/100,1);
- OLED_Show_One_Number(32,6,BMP180_Temperature%100/10,1);
- OLED_Show_One_Number(48,6,BMP180_Temperature%10,1);
- if((BMP180_Pressure/100000)!=0)
- OLED_Show_One_Number(72,6,BMP180_Pressure/100000,1);
- OLED_Show_One_Number(80,6,BMP180_Pressure%100000/10000,1);
- OLED_Show_One_Number(88,6,BMP180_Pressure%10000/1000,1);
- OLED_Show_One_Number(104,6,BMP180_Pressure%1000/100,1);
- if(KEY1==0)//確定按鍵
- delay2(5000);
- if(KEY1==0)
- _nop_();
- while(!KEY1);//由于按鍵只起到返回的作用,此處也可以將第二次if判斷去掉,僅使用while判斷,但為了整體規(guī)范性,就不在意那幾個時鐘了
- OLED_Clear();
- goto OUT3;
- if(KEY2==0)//取消按鍵
- delay2(5000);
- if(KEY2==0)
- _nop_();
- while(!KEY2);//由于按鍵只起到返回的作用,此處也可以將第二次if判斷去掉,僅使用while判斷,但為了整體規(guī)范性,就不在意那幾個時鐘了
- OLED_Clear();
- goto OUT3;
- OUT3:_nop_();
- void Time_Set()//時間修改函數(shù)
- bit en_data=1;//數(shù)據(jù)合法標志位,表示數(shù)據(jù)檢查時的合法:1/不合法:0判斷結(jié)果
- unsigned char i,choose=1,year_temp;
- unsigned char set_clock[6];
- unsigned char set_date[8];
- set_date[0]=display_year[0];
- set_date[1]=display_year[1];
- set_date[2]=display_year[2];
- set_date[3]=display_year[3];
- set_date[4]=display_month[0];
- set_date[5]=display_month[1];
- set_date[6]=display_day[0];
- set_date[7]=display_day[1];
- set_clock[0]=display_hour[0];
- set_clock[1]=display_hour[1];
- set_clock[2]=display_minute[0];
- set_clock[3]=display_minute[1];
- set_clock[4]=display_second[0];
- set_clock[5]=display_second[1];//復(fù)制運行數(shù)組,取待顯示每一位
- /*第一部分,日期設(shè)置*/
- OLED_Clear();
- OLED_Show_CHinese(0,CCTitle13,1);//顯示標題:時間修改
- for(i=0;i<16;i++)
- OLED_Show_CHinese(4,CCInfo7,1);//顯示說明文字:請輸入年月日:
- while(!KEY1);//確認進入該函數(shù)時的按鍵已經(jīng)松開
- while(1)
- OLED_DateSet_Display(set_date,choose);//刷新顯示時間設(shè)置數(shù)組,該數(shù)組保存設(shè)置的時間(按位)
- if(KeyScan()<10)//如果在此時有鍵盤按鍵按下則更改當前位的值
- delay2(5000);
- if(KeyScan()<10)
- set_date[choose-1]=KeyScan();
- while(KeyScan()!=16);//等待按鍵松開
- choose++;
- if(choose==9)choose=8;//選項最大不能大于8
- if(KEY1==0)//確定按鍵
- delay2(5000);
- if(KEY1==0)
- _nop_();
- while(!KEY1);
- goto TSB;//跳出當前循環(huán),進入下一循環(huán)時間設(shè)置
- if(KEY2==0)//取消按鍵,直接退出時間設(shè)置函數(shù)
- delay2(5000);
- if(KEY2==0)
- _nop_();
- while(!KEY2);
- OLED_Clear();
- goto TIMESETOUT;
- delay2(5000);
- if(KEY3==0)
- choose--;
- while(!KEY3);
- delay2(5000);
- if(KEY4==0)
- choose++;
- while(!KEY4);
- /*第二部分,時間設(shè)置*/
- TSB: choose=1;//重置顯示位標志
- OLED_Clear();
- for(i=0;i<16;i++)
- OLED_Show_CHinese(4,CCInfo8,1);//顯示說明文字:請輸入時鐘:
- while(1)
- OLED_TimeSet_Display(set_clock,choose);//刷新顯示時間設(shè)置數(shù)組,該數(shù)組保存設(shè)置的時間(按位)
- delay2(5000);
- if(KeyScan()<10)
- set_clock[choose-1]=KeyScan();
- choose++;
- if(choose==7)choose=6;//選項最大不能大于6
- if(KEY1==0)//確定按鍵
- delay2(5000);
- if(KEY1==0)
- _nop_();
- while(!KEY1);
- goto TSC;//跳出當前循環(huán),進入第三部分
- delay2(5000);
- if(KEY2==0)
- _nop_();
- while(!KEY2);
- OLED_Clear();
- goto TIMESETOUT;
- delay2(5000);
- if(KEY3==0)
- choose--;
- while(!KEY3);
- delay2(5000);
- if(KEY4==0)
- choose++;
- while(!KEY4);
- /*第三部分,拼接判斷和寫入*/
- TSC:if((set_clock[0]*10+set_clock[1])>24||set_clock[0]>2)//對小時的判斷
- en_data=0;
- else
- if(set_clock[0]==2&&set_clock[1]>4)
- en_data=0;
- if((set_clock[2]*10+set_clock[3])>60||set_clock[2]>5)//對分鐘的判斷
- en_data=0;
- if((set_clock[4]*10+set_clock[5])>60||set_clock[4]>5)//對秒的判斷
- en_data=0;
- if((set_date[4]*10+set_date[5])>12||set_date[4]>1)//對月份的判斷
- en_data=0;
- else
- if(set_date[4]==1&&set_date[5]>2)
- en_data=0;
- if(set_date[4]==0&&set_date[5]==0)
- en_data=0;
- if((set_date[6]*10+set_date[7])>31||set_date[6]>3)//對日子的判斷。注意,由于閏年的存在,若出現(xiàn)閏年輸入2.29這樣的情況會在輸入完年份后判斷退出
- en_data=0;
- if(set_date[0]!=2||set_date[1]!=0)
- en_data=0;
- year_temp=set_date[0]*1000+set_date[1]*100+set_date[2]*10+set_date[3];
- if(!Leap(year_temp))//如果不是閏年
- if(set_date[4]==0&&set_date[5]==2&&set_date[6]==2&&set_date[7]==9)//對2.29作出判斷
- en_data=0;
- if(en_data)
- /*拼接寫入數(shù)組*/
- time_transmission(set_date,set_clock);
- /*寫入新時間*/
- TimeReset();
- /*提示成功信息*/
- OLED_Clear();
- for(i=0;i<16;i++)
- OLED_Show_CHinese(4,CCInfo15,1);//顯示說明文字:修改成功
- /*按鍵循環(huán)*/
- while(1)
- if(KEY1==0)//確定按鍵
- delay2(5000);
- if(KEY1==0)
- _nop_();
- while(!KEY1);
- OLED_Clear();
- goto TIMESETOUT;
- if(KEY2==0)//取消按鍵
- delay2(5000);
- if(KEY2==0)
- _nop_();
- while(!KEY2);
- OLED_Clear();
- goto TIMESETOUT;
- else
- /*提示失敗信息*/
- OLED_Clear();
- for(i=0;i<16;i++)
- OLED_Show_CHinese(4,CCInfo16,1);//顯示說明文字:輸入不合規(guī)則
- /*按鍵循環(huán)*/
- while(1)
- if(KEY1==0)//確定按鍵
- delay2(5000);
- if(KEY1==0)
- _nop_();
- while(!KEY1);
- OLED_Clear();
- goto TIMESETOUT;
- if(KEY2==0)//取消按鍵
- delay2(5000);
- if(KEY2==0)
- _nop_();
- while(!KEY2);
- OLED_Clear();
- goto TIMESETOUT;
- TIMESETOUT: _nop_();
