void RGB_to_HSL(/*[in]*/const COLOR_RGB* rgb, /*[out]*/COLOR_HSL* hsl);
void HSL_to_RGB(const COLOR_HSL* hsl, COLOR_RGB* rgb);
- #include "colorconvert.h"
- #define min3v(v1, v2, v3) ((v1)>(v2)? ((v2)>(v3)?(v3):(v2)):((v1)>(v3)?(v3):(v2)))
- #define max3v(v1, v2, v3) ((v1)<(v2)? ((v2)<(v3)?(v3):(v2)):((v1)<(v3)?(v3):(v1)))
- void RGB_to_HSL(const COLOR_RGB* rgb, /*[out]*/COLOR_HSL* hsl)
- float h=0,s=0,l=0;
- //int h=0;
- // normalizes red-green-blue values
- float r = rgb->red/255.f;
- float g = rgb->green/255.f;
- float b = rgb->blue/255.f;
- float maxVal = max3v(r, g, b);
- float minVal = min3v(r, g, b);
- // hue
- if(maxVal == minVal)
- h = 0; // undefined
- else if(maxVal==r && g>=b)
- h = 60.0f*(g-b)/(maxVal-minVal);
- else if(maxVal==r && g<b)
- h = 60.0f*(g-b)/(maxVal-minVal) + 360.0f;
- else if(maxVal==g)
- h = 60.0f*(b-r)/(maxVal-minVal) + 120.0f;
- else if(maxVal==b)
- h = 60.0f*(r-g)/(maxVal-minVal) + 240.0f;
- // luminance
- l = (maxVal+minVal)/2.0f;
- // saturation
- if(l == 0 || maxVal == minVal)
- s = 0;
- else if(0<l && l<=0.5f)
- s = (maxVal-minVal)/(maxVal+minVal);
- else if(l>0.5f)
- s = (maxVal-minVal)/(2 - (maxVal+minVal)); //(maxVal-minVal > 0)?
- hsl->hue = (h>360)? 360 : ((h<0)?0:h);
- hsl->saturation = ((s>1)? 1 : ((s<0)?0:s));
- hsl->luminance = ((l>1)? 1 : ((l<0)?0:l));
- void HSL_to_RGB(const COLOR_HSL *hsl, COLOR_RGB *rgb)
- int i;
- float h = hsl->hue; // h must be [0, 360]
- float s = hsl->saturation; // s must be [0, 1]
- float l = hsl->luminance; // l must be [0, 1]
- float R, G, B;
- if( hsl->saturation == 0)
- // achromatic color (gray scale)
- R = G = B = 1*255.f;
- else
- float q = (l<0.5f)?(l * (1.0f+s)):(l+s - (l*s));
- float p = (2.0f * l) - q;
- float Hk = h/360.0f;
- float T[3];
- T[0] = Hk + 0.3333333f; // Tr 0.3333333f=1.0/3.0
- T[1] = Hk; // Tb
- T[2] = Hk - 0.3333333f; // Tg
- for(i=0; i<3; i++)
- if(T[i] < 0) T[i] += 1.0f;
- if(T[i] > 1) T[i] -= 1.0f;
- if((T[i]*6) < 1)
- T[i] = p + ((q-p)*6.0f*T[i]);
- else if((T[i]*2.0f) < 1) //(1.0/6.0)<=T[i] && T[i]<0.5
- T[i] = q;
- else if((T[i]*3.0f) < 2) // 0.5<=T[i] && T[i]<(2.0/3.0)
- T[i] = p + (q-p) * ((2.0f/3.0f) - T[i]) * 6.0f;
- else T[i] = p;
- R = T[0]*255.0f;
- G = T[1]*255.0f;
- B = T[2]*255.0f;
- rgb->red = (uint8_t)((R>255)? 255 : ((R<0)?0 : R));
- rgb->green =(uint8_t)((G>255)? 255 : ((G<0)?0 : G));
- rgb->blue = (uint8_t)((B>255)? 255 : ((B<0)?0 : B));
color.zip
(1.73 KB, 下載次數: 32)
2019-1-30 10:30 上傳
