stm32F1 平衡車源代碼,采用亞博智能小車拓展板,采用MPU6050 INT腳中斷,本代碼只有直立環(huán),后續(xù)代碼稍后上傳
單片機(jī)源程序如下:
- #include "mpu6050.h"
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- //初始化MPU6050
- //返回值:0,成功
- // 其他,錯(cuò)誤代碼
- u8 MPU_Init(void)
- u8 res;
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//使能AFIO時(shí)鐘
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//先使能外設(shè)IO PORTA時(shí)鐘
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15; // 端口配置
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度為50MHz
- GPIO_Init(GPIOA, &GPIO_InitStructure); //根據(jù)設(shè)定參數(shù)初始化GPIOA
- GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//禁止JTAG,從而PA15可以做普通IO使用,否則PA15不能做普通IO!!!
- MPU_AD0_CTRL=0; //控制MPU6050的AD0腳為低電平,從機(jī)地址為:0X68
- MPU_IIC_Init(); //初始化IIC總線
- MPU_Write_Byte(MPU_PWR_MGMT1_REG,0X80); //復(fù)位MPU6050
- delay_ms(100);
- MPU_Write_Byte(MPU_PWR_MGMT1_REG,0X00); //喚醒MPU6050
- MPU_Set_Gyro_Fsr(3); //陀螺儀傳感器,±2000dps
- MPU_Set_Accel_Fsr(0); //加速度傳感器,±2g
- MPU_Set_Rate(200); //設(shè)置采樣率50Hz
- MPU_Write_Byte(MPU_INT_EN_REG,0X00); //關(guān)閉所有中斷
- MPU_Write_Byte(MPU_USER_CTRL_REG,0X00); //I2C主模式關(guān)閉
- MPU_Write_Byte(MPU_FIFO_EN_REG,0X00); //關(guān)閉FIFO
- MPU_Write_Byte(MPU_INTBP_CFG_REG,0X80);//INT引腳低電平有效
- res=MPU_Read_Byte(MPU_DEVICE_ID_REG);
- if(res==MPU_ADDR)//器件ID正確
- MPU_Write_Byte(MPU_PWR_MGMT1_REG,0X01); //設(shè)置CLKSEL,PLL X軸為參考
- MPU_Write_Byte(MPU_PWR_MGMT2_REG,0X00); //加速度與陀螺儀都工作
- MPU_Set_Rate(200); //設(shè)置采樣率為50Hz
- }else return 1;
- return 0;
- //設(shè)置MPU6050陀螺儀傳感器滿量程范圍
- //fsr:0,±250dps;1,±500dps;2,±1000dps;3,±2000dps
- //返回值:0,設(shè)置成功
- // 其他,設(shè)置失敗
- u8 MPU_Set_Gyro_Fsr(u8 fsr)
- return MPU_Write_Byte(MPU_GYRO_CFG_REG,fsr<<3);//設(shè)置陀螺儀滿量程范圍
- //設(shè)置MPU6050加速度傳感器滿量程范圍
- //fsr:0,±2g;1,±4g;2,±8g;3,±16g
- //返回值:0,設(shè)置成功
- // 其他,設(shè)置失敗
- u8 MPU_Set_Accel_Fsr(u8 fsr)
- return MPU_Write_Byte(MPU_ACCEL_CFG_REG,fsr<<3);//設(shè)置加速度傳感器滿量程范圍
- //設(shè)置MPU6050的數(shù)字低通濾波器
- //lpf:數(shù)字低通濾波頻率(Hz)
- //返回值:0,設(shè)置成功
- // 其他,設(shè)置失敗
- u8 MPU_Set_LPF(u16 lpf)
- u8 data=0;
- if(lpf>=188)data=1;
- else if(lpf>=98)data=2;
- else if(lpf>=42)data=3;
- else if(lpf>=20)data=4;
- else if(lpf>=10)data=5;
- else data=6;
- return MPU_Write_Byte(MPU_CFG_REG,data);//設(shè)置數(shù)字低通濾波器
- //設(shè)置MPU6050的采樣率(假定Fs=1KHz)
- //rate:4~1000(Hz)
- //返回值:0,設(shè)置成功
- // 其他,設(shè)置失敗
- u8 MPU_Set_Rate(u16 rate)
- u8 data;
- if(rate>1000)rate=1000;
- if(rate<4)rate=4;
- data=1000/rate-1;
- data=MPU_Write_Byte(MPU_SAMPLE_RATE_REG,data); //設(shè)置數(shù)字低通濾波器
- return MPU_Set_LPF(rate/2); //自動(dòng)設(shè)置LPF為采樣率的一半
- //得到溫度值
- //返回值:溫度值(擴(kuò)大了100倍)
- short MPU_Get_Temperature(void)
- u8 buf[2];
- short raw;
- float temp;
- MPU_Read_Len(MPU_ADDR,MPU_TEMP_OUTH_REG,2,buf);
- raw=((u16)buf[0]<<8)|buf[1];
- temp=36.53+((double)raw)/340;
- return temp*100;;
- //得到陀螺儀值(原始值)
- //gx,gy,gz:陀螺儀x,y,z軸的原始讀數(shù)(帶符號(hào))
- //返回值:0,成功
- // 其他,錯(cuò)誤代碼
- u8 MPU_Get_Gyroscope(short *gx,short *gy,short *gz)
- u8 buf[6],res;
- res=MPU_Read_Len(MPU_ADDR,MPU_GYRO_XOUTH_REG,6,buf);
- if(res==0)
- *gx=((u16)buf[0]<<8)|buf[1];
- *gy=((u16)buf[2]<<8)|buf[3];
- *gz=((u16)buf[4]<<8)|buf[5];
- return res;;
- //得到加速度值(原始值)
- //返回值:0,成功
- // 其他,錯(cuò)誤代碼
- u8 MPU_Get_Accelerometer(short *ax,short *ay,short *az)
- u8 buf[6],res;
- res=MPU_Read_Len(MPU_ADDR,MPU_ACCEL_XOUTH_REG,6,buf);
- if(res==0)
- *ax=((u16)buf[0]<<8)|buf[1];
- *ay=((u16)buf[2]<<8)|buf[3];
- *az=((u16)buf[4]<<8)|buf[5];
- return res;;
- //IIC連續(xù)寫
- //addr:器件地址
- //reg:寄存器地址
- //len:寫入長(zhǎng)度
- //buf:數(shù)據(jù)區(qū)
- //返回值:0,正常
- // 其他,錯(cuò)誤代碼
- u8 MPU_Write_Len(u8 addr,u8 reg,u8 len,u8 *buf)
- u8 i;
- MPU_IIC_Start();
- MPU_IIC_Send_Byte((addr<<1)|0);//發(fā)送器件地址+寫命令
- if(MPU_IIC_Wait_Ack()) //等待應(yīng)答
- MPU_IIC_Stop();
- return 1;
- MPU_IIC_Send_Byte(reg); //寫寄存器地址
- MPU_IIC_Wait_Ack(); //等待應(yīng)答
- for(i=0;i<len;i++)
- MPU_IIC_Send_Byte(buf[i]); //發(fā)送數(shù)據(jù)
- if(MPU_IIC_Wait_Ack()) //等待ACK
- MPU_IIC_Stop();
- return 1;
- MPU_IIC_Stop();
- return 0;
- //IIC連續(xù)讀
- //addr:器件地址
- //reg:要讀取的寄存器地址
- //len:要讀取的長(zhǎng)度
- //buf:讀取到的數(shù)據(jù)存儲(chǔ)區(qū)
- //返回值:0,正常
- // 其他,錯(cuò)誤代碼
- u8 MPU_Read_Len(u8 addr,u8 reg,u8 len,u8 *buf)
- MPU_IIC_Start();
- MPU_IIC_Stop();
- return 1;
- MPU_IIC_Start();
- MPU_IIC_Send_Byte((addr<<1)|1);//發(fā)送器件地址+讀命令
- while(len)
- if(len==1)*buf=MPU_IIC_Read_Byte(0);//讀數(shù)據(jù),發(fā)送nACK
- else *buf=MPU_IIC_Read_Byte(1); //讀數(shù)據(jù),發(fā)送ACK
- len--;
- buf++;
- MPU_IIC_Stop(); //產(chǎn)生一個(gè)停止條件
- return 0;
- //IIC寫一個(gè)字節(jié)
- //reg:寄存器地址
- //data:數(shù)據(jù)
- //返回值:0,正常
- // 其他,錯(cuò)誤代碼
- u8 MPU_Write_Byte(u8 reg,u8 data)
- MPU_IIC_Start();
- MPU_IIC_Send_Byte((MPU_ADDR<<1)|0);//發(fā)送器件地址+寫命令
- MPU_IIC_Stop();
- return 1;
- MPU_IIC_Send_Byte(data);//發(fā)送數(shù)據(jù)
- MPU_IIC_Stop();
- return 1;
- MPU_IIC_Stop();
- return 0;
- //IIC讀一個(gè)字節(jié)
- //reg:寄存器地址
- //返回值:讀到的數(shù)據(jù)
- u8 MPU_Read_Byte(u8 reg)
- u8 res;
- MPU_IIC_Start();
- MPU_IIC_Start();
- MPU_IIC_Send_Byte((MPU_ADDR<<1)|1);//發(fā)送器件地址+讀命令
- res=MPU_IIC_Read_Byte(0);//讀取數(shù)據(jù),發(fā)送nACK
- return res;
復(fù)制代碼- #include "sys.h"
- #include "led.h"
- #include "Motor.h"
- #include "timer.h"
- #include "pid.h"
- #include "oled.h"
- #include "usmart.h"
- #include "inv_mpu.h"
- #include "inv_mpu_dmp_motion_driver.h"
- //串口1發(fā)送1個(gè)字符
- //c:要發(fā)送的字符
- u8 a = 0;
- u16 Kms;
- float pitch;
- float roll,yaw; //歐拉角
- short gyrox,gyroy,gyroz; //陀螺儀原始數(shù)據(jù)
- short aacx,aacy,aacz; //加速度傳感器原始數(shù)據(jù)
- void usart1_send_char(u8 c)
- while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==RESET); //循環(huán)發(fā)送,直到發(fā)送完畢
- USART_SendData(USART1,c);
- //傳送數(shù)據(jù)給匿名四軸上位機(jī)軟件(V2.6版本)
- //fun:功能字. 0XA0~0XAF
- //data:數(shù)據(jù)緩存區(qū),最多28字節(jié)!!
- //len:data區(qū)有效數(shù)據(jù)個(gè)數(shù)
- void usart1_niming_report(u8 fun,u8*data,u8 len)
- u8 send_buf[32];
- u8 i;
- if(len>28)return; //最多28字節(jié)數(shù)據(jù)
- send_buf[len+3]=0; //校驗(yàn)數(shù)置零
- send_buf[0]=0X88; //幀頭
- send_buf[1]=fun; //功能字
- send_buf[2]=len; //數(shù)據(jù)長(zhǎng)度
- for(i=0;i<len;i++)send_buf[3+i]=data[i]; //復(fù)制數(shù)據(jù)
- for(i=0;i<len+3;i++)send_buf[len+3]+=send_buf[i]; //計(jì)算校驗(yàn)和
- for(i=0;i<len+4;i++)usart1_send_char(send_buf[i]); //發(fā)送數(shù)據(jù)到串口1
- //發(fā)送加速度傳感器數(shù)據(jù)和陀螺儀數(shù)據(jù)
- //aacx,aacy,aacz:x,y,z三個(gè)方向上面的加速度值
- //gyrox,gyroy,gyroz:x,y,z三個(gè)方向上面的陀螺儀值
- void mpu6050_send_data(short aacx,short aacy,short aacz,short gyrox,short gyroy,short gyroz)
- u8 tbuf[12];
- tbuf[0]=(aacx>>8)&0XFF;
- tbuf[1]=aacx&0XFF;
- tbuf[2]=(aacy>>8)&0XFF;
- tbuf[3]=aacy&0XFF;
- tbuf[4]=(aacz>>8)&0XFF;
- tbuf[5]=aacz&0XFF;
- tbuf[6]=(gyrox>>8)&0XFF;
- tbuf[7]=gyrox&0XFF;
- tbuf[8]=(gyroy>>8)&0XFF;
- tbuf[9]=gyroy&0XFF;
- tbuf[10]=(gyroz>>8)&0XFF;
- tbuf[11]=gyroz&0XFF;
- usart1_niming_report(0XA1,tbuf,12);//自定義幀,0XA1
- //通過串口1上報(bào)結(jié)算后的姿態(tài)數(shù)據(jù)給電腦
- //roll:橫滾角.單位0.01度。 -18000 -> 18000 對(duì)應(yīng) -180.00 -> 180.00度
- //pitch:俯仰角.單位 0.01度。-9000 - 9000 對(duì)應(yīng) -90.00 -> 90.00 度
- //yaw:航向角.單位為0.1度 0 -> 3600 對(duì)應(yīng) 0 -> 360.0度
- void usart1_report_imu(short aacx,short aacy,short aacz,short gyrox,short gyroy,short gyroz,short roll,short pitch,short yaw)
- u8 tbuf[28];
- u8 i;
- for(i=0;i<28;i++)tbuf[i]=0;//清0
- tbuf[18]=(roll>>8)&0XFF;
- tbuf[19]=roll&0XFF;
- tbuf[20]=(pitch>>8)&0XFF;
- tbuf[21]=pitch&0XFF;
- tbuf[22]=(yaw>>8)&0XFF;
- tbuf[23]=yaw&0XFF;
- usart1_niming_report(0XAF,tbuf,28);//飛控顯示幀,0XAF
- int main(void)
- u8 i,report=1;
- delay_init(); //延時(shí)函數(shù)初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
- uart_init(115200); //串口初始化為115200
- delay_ms(100);
- MPU_Init(); //初始化MPU6050
- Motor_Init();
- TIM2_PWM_Init(7199,0); //不分頻。PWM頻率=72000000/900=80Khz
- PID_Init();
- LED_Init();//LED端口初始化
- mpu_dmp_init();
- MPU6050_EXTI_Init();//外部中斷初始化
- while(1)
平衡版.7z
(277.58 KB, 下載次數(shù): 89)
2019-1-25 15:22 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
BST STM32智能平衡小車.pdf
(40 KB, 下載次數(shù): 63)
2019-1-25 16:46 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
