2019-1-24 16:01 上傳
- #include"reg51.h"
- #define uchar unsigned char
- #define uint unsigned int
- #include"intrins.h"
- sbit DQ=P3^7;
- sbit P20=P3^0;
- sbit P21=P3^1;
- sbit P22=P3^2;
- sbit P23=P3^3;
- sbit P24=P0^0;
- code uchar tab[]={0XC0,0XF9,0XA4,0XB0,0X99,0X92,0X82,0XF8,0X80,0X90};
- code uchar tab1[]={0X40,0X79,0X24,0X30,0X19,0X12,0X02,0X78,0X00,0X10};
- uchar a,b,t,h;
- uchar bai,shi,ge,xiao;
- void delay(unsigned int i)
- while(i--);
- //初始化函數
- bit int_DS18B20(void)
- unsigned char x=0;
- DQ=1;
- delay(8);
- DQ=0;
- delay(80);
- DQ=1;
- delay(14);
- x=DQ;
- delay(30);
- return x;
- //讀一個字節
- read(void)
- unsigned char i=0;
- unsigned char dat=0;
- for(i=8;i>0;i--)
- DQ=0;
- dat>>=1;
- DQ=1;
- if(DQ)
- dat|=0x80;
- delay(4);
- return(dat);
- //寫一個字節
- write(unsigned char dat)
- for(i=8;i>0;i--)
- DQ=0;
- DQ=dat&0x01;
- delay(5);
- DQ=1;
- dat>>=1;
- delay(4);
- //啟動轉換
- void int_(void)
- while(int_DS18B20());
- write(0xCC);
- write(0x44);
- void main(void)
- uint count=0;
- P3=0X00;
- int_();
- delay(2200);
- for(count=0;count<1000;count++)
- P20=1;
- P1=tab[0];
- delay(30);
- P20=0;
- P21=1;
- P1=tab[0];
- delay(30);
- P21=0;
- P22=1;
- P1=tab1[0];
- delay(30);
- P22=0;
- P23=1;
- P1=0xc6;
- delay(30);
- P23=0;
- while(1)
- delay(120);
- write(0xcc);
- write(0xbe);
- a=read();
- b=read();
- if(b>127)
- a=~a;
- b=~b;
- a>>=4;
- t=b<<4;
- t=t|a;
- t+=1;
- shi=t/10;
- ge=t-shi*10;
- for(count=0;count<123;count++)
- if(t>=10)
- P20=1;
- P1=0xbf;
- delay(30);
- P20=0;
- P21=1;
- P1=tab[shi];
- delay(50);
- P21=0;
- P22=1;
- P1=tab1[ge];
- delay(30);
- P22=0;
- P23=1;
- P1=0xc6;
- delay(30);
- P23=0;
- else
- P20=0;
- P21=1;
- P1=0xbf;
- delay(30);
- P21=0;
- P22=1;
- P1=tab1[ge];
- delay(30);
- P22=0;
- P23=1;
- P1=0xc6;
- delay(30);
- P23=0;
- else
- count=0;
- a=a>>4;
- t=b<<4;
- t=t|a;
- if(t>36)
- {P24=0;}
- else P24=1;
- bai=t/100;
- shi=(t-bai*100)/10;
- ge=t-(bai*100+shi*10);
- if(bai)
- P20=1;
- P1=tab[bai];
- delay(30);
- P20=0;
- P20=0;
- P21=1;
- P1=tab[shi];
- delay(30);
- P21=0;
- P22=1;
- P1=tab1[ge];
- delay(30);
- P22=0;
- P23=1;
- P1=0xc6;
- delay(30);
- P23=0;
- int_();
