只需一步,快速開(kāi)始
查看: 3550|回復(fù): 7
刨光機(jī)單片機(jī)源代碼
ID:471889 發(fā)表于 2019-1-23 03:07 | 顯示全部樓層 |閱讀模式
  1. #include<REG52.h>
  2. #define MAXSIZE 100
  3. using namespace std;
  4. typedef int ElemType;
  5. typedef struct Node
  6. {
  7.     ElemType data;
  8.     int cur;
  9. } StaticLinkList[MAXSIZE];
  10. bool InitList(StaticLinkList array)
  11. {
  12.     cout << "InitList..." << endl;
  13.     for (int i = 0; i < MAXSIZE - 2; i++)
  14.     {
  15.         array[i].cur = i + 1;
  16.     }
  17.     20;
  18.     array[MAXSIZE - 1].cur = 0;
  19.     return true;
  20. }
  21. int Malloc_SLL(StaticLinkList array)
  22. {
  23.     int k = array[0].cur;
  24.     if (k)
  25.         array[0].cur = array[k].cur;
  26.     return k;
  27. }
  28. void Free_SLL(StaticLinkList array, int pos)
  29. {
  30.     array[pos].cur = array[0].cur;
  31.     array[0].cur = pos;
  32. }
  33. int ListLength(StaticLinkList array)
  34. {
  35.     int i = array[MAXSIZE - 1].cur;
  36.     int j = 0;
  37.     while(i)
  38.     {
  39.         i = array[i].cur;
  40.         ++j;
  41.     }
  42.     return j;
  43. }
  44. bool ListInsert(StaticLinkList array, int pos, ElemType Elem)
  45. {
  46.     cout << "Insert List from pos: " << pos << " Item " << Elem << endl;
  47.     if (pos < 1 || pos > ListLength(array) + 1)
  48.         return false;
  49.     int k = MAXSIZE - 1;
  50.     int i = Malloc_SLL(array);
  51.     if (i)
  52.     {
  53.         array[i].data = Elem;
  54.         for (int l = 1; l <= pos - 1; l++)
  55.             k = array[k].cur;
  56.         array[i].cur = array[k].cur;
  57.         array[k].cur = i;
  58.         return true;
  59.     }
  60.     return false;
  61. }
  62. bool ListDelete(StaticLinkList array, int pos)
  63. {
  64.     cout << "Delete List from pos: " << pos << endl;
  65.     if (pos < 1 || pos > ListLength(array))
  66.         return false;
  67.     int k = MAXSIZE - 1;
  68.     for (int l = 1; l <= pos - 1; l++)
  69.         k = array[k].cur;
  70.     int j = array[k].cur;
  71.     array[j].cur = array[pos].cur;
  72.     Free_SLL(array, j);
  73.     return true;
  74. }
  75. bool ListTraverse(StaticLinkList array)
  76. {
  77.     cout << "List Traverse : " << endl;
  78.     int k = MAXSIZE - 1;
  79.     while (array[k].cur != 0)
  80.     {
  81.         k = array[k].cur;
  82.         cout << array[k].data << ' ';
  83.     }
  84.     cout << endl;
  85.     return true;
  86. }
由于是廠(chǎng)里機(jī)密,所以電路就不能分享出來(lái)了
評(píng)分
參與人數(shù) 3黑幣 +33 收起 理由
static + 10
zhengchong60 + 11
鉆牛尖滴劉尖尖 + 12
查看全部評(píng)分
ID:418295 發(fā)表于 2019-1-24 21:58 來(lái)自觸屏版 | 顯示全部樓層
干什么用的?
ID:471889 發(fā)表于 2019-1-31 19:30 | 顯示全部樓層
控制刨光機(jī)電機(jī)的代碼
評(píng)分
參與人數(shù) 5黑幣 +80 收起 理由
shuisheng60 + 35
鉆牛尖滴劉尖尖 + 12
#include51.h + 15
sheng7533967 + 8 贊一個(gè)!
zhengchong60 + 10 絕世好帖!
查看全部評(píng)分
ID:21069 發(fā)表于 2019-2-3 00:51 | 顯示全部樓層
先下下來(lái)學(xué)習(xí)一下
評(píng)分
參與人數(shù) 2黑幣 +70 收起 理由
shuisheng + 35 很給力!
areyouok + 35 很給力!
查看全部評(píng)分
ID:474677 發(fā)表于 2019-2-3 11:16 | 顯示全部樓層
請(qǐng)教啥是刨光機(jī)?
ID:473159 發(fā)表于 2019-2-8 13:27 | 顯示全部樓層
iofree 發(fā)表于 2019-2-3 11:16
請(qǐng)教啥是刨光機(jī)?
左一巴掌呼兒嘿,又一巴掌嘿兒呼!明白沒(méi),沒(méi)明白就再來(lái)一次
評(píng)分
參與人數(shù) 1黑幣 +8 收起 理由
還有誰(shuí)? + 8
查看全部評(píng)分
ID:418295 發(fā)表于 2019-2-19 22:37 | 顯示全部樓層
找人PK 發(fā)表于 2019-1-31 19:30
控制刨光機(jī)電機(jī)的代碼
什么行業(yè)用的?
ID:471889 發(fā)表于 2019-3-10 03:20 | 顯示全部樓層
本帖最后由 找人PK 于 2019-4-3 18:14 編輯
這個(gè)不奇怪,你想到的事物不一定是你見(jiàn)到過(guò)的
評(píng)分
參與人數(shù) 2黑幣 +20 收起 理由
刀刀見(jiàn)紅 + 10 贊一個(gè)!
shuisheng60 + 10 贊一個(gè)!
查看全部評(píng)分
