查看: 4740|回復(fù): 2
單片機(jī)24C02存儲(chǔ)多種花樣流水燈仿真電路+程序
ID:469417 發(fā)表于 2019-1-22 00:15 | 顯示全部樓層 |閱讀模式
/***************標(biāo)準(zhǔn)源碼***************/
#include<reg51.h>
#include <intrins.h>
#define uchar   unsigned char
#define uint     unsigned int
sbit sda = P2 ^ 1; //數(shù)據(jù)口定義
sbit scl = P2 ^ 0;
char code music[] = {//生日快樂譜
        0x11,0x05,0x11,0x05,0x12,0x0a,0x11,0x0a,0x14,0x0a,0x13,0x14,
    0x11,0x05,0x11,0x05,0x12,0x0a,0x11,0x0a,0x15,0x0a,0x14,0x14,
        0x11,0x05,0x11,0x05,0x21,0x0a,0x16,0x0a,0x14,0x0a,0x13,0x0a,
        0x22,0x0a,0x17,0x05,0x17,0x05,0x16,0x0a,0x14,0x0a,0x15,0x0a,
        0x14,0x14,0x00,0x00
uchar data buffer[100];
void  delay(uint m) ;
void  nop();
void  delay1(uint m);
void  IIc_init();
void  start();
void  stop();
void  writebyte(uchar jad);
uchar readbyte();
void  ACK();
uchar read24c02(uchar spress) ;
void  write24c02(uchar spress, uchar info);
        uchar sp, i, j, m;
        IIc_init();
        P1 = 0X55;
        while (sp != sizeof(music))
                write24c02(0x00 + sp, music[sp]);
                sp++;
                if (sp % 4 == 0)
                        P1 = ~P1;
        P1 = 0X00;
void delay(uint m)
        uint n, p;
        for (n = m; n>0; n--)
                for (p = 125; p>0; p--);
void nop()
        _nop_();
        _nop_();
void delay1(uint m)
        uint n;
        for (n = 0; n<m; n++);
void IIc_init()
        scl = 1;
        nop();
        sda = 1;
        nop();
void start()
        sda = 1;
        nop();
        scl = 1;
        nop();
        sda = 0;
        nop();
        scl = 0;
        nop();
void stop() //停止I2C 總線
        sda = 0;
        nop();
        scl = 1;
        nop();
        sda = 1;
        nop();
void writebyte(uchar jad) //寫一個(gè)字節(jié)
        uchar i;
        scl = 0;
        for (i = 0; i<8; i++)
                if(jad & 0x80)
                        sda = 1;
                else sda = 0;
                jad <<= 1;
                nop();
                scl = 1; //待sda 線上的數(shù)據(jù)穩(wěn)定后 將scl 拉高
                nop();
                scl = 0; //待sda 線上的數(shù)據(jù)穩(wěn)定后 將scl 拉高
                nop();
        sda = 1;
        nop();
uchar readbyte() //讀一個(gè)字節(jié)
        uchar i, j, k ;
        scl = 0;
        nop();
        sda = 1;
                nop();
                scl = 1;
                nop();
                if (sda == 1)
                        j = 1;
                        j = 0;
                k = (k << 1) | j;
                scl = 0;
        nop();
        return k;
void ACK() //應(yīng)答函數(shù)
        uchar i = 0;
        scl = 1;
        nop();
        while ((sda == 1) && (i<255))
                i++;
        scl = 0;
        nop();
        uchar i;
        start();
        writebyte(0xa0);
        ACK();
        writebyte(spress);
        ACK();
        start();
        writebyte(0xa1);
        ACK();
        i = readbyte();
        stop();
        delay1(100);
        return(i);
        start();
        writebyte(0xa0);
        ACK(); writebyte(spress);
        ACK();
        writebyte(info);
        ACK();
        stop();
        delay1(5000);
24c04音樂讀取與存儲(chǔ).rar (8.64 KB, 下載次數(shù): 34)
評(píng)分
參與人數(shù) 10黑幣 +119 收起 理由
701 + 2 贊一個(gè)!
hitblda + 10
azi197417 + 10 共享資料的黑幣獎(jiǎng)勵(lì)!
shuisheng60 + 10
Sawardeakar + 15 贊一個(gè)!
shuisheng + 5 很給力!
areyouok + 12 回帖助人的獎(jiǎng)勵(lì)!
jinsheng7533967 + 35
#include51.h + 10 贊一個(gè)!
Trump1438 + 10 贊一個(gè)!
查看全部評(píng)分
ID:472242 發(fā)表于 2019-2-7 01:30 | 顯示全部樓層
不錯(cuò),真的很不錯(cuò)!很有創(chuàng)造精神!支持你!
評(píng)分
參與人數(shù) 7黑幣 +185 收起 理由
站著說話不腰疼 + 15
sheng7533967 + 15
yoxi + 35
Sawardeakar + 35
zhengchong60 + 15
shuisheng + 35
Trump1438 + 35
查看全部評(píng)分
ID:452731 發(fā)表于 2019-2-7 22:15 | 顯示全部樓層
很有創(chuàng)意!值得學(xué)習(xí)
