查看: 1555|回復(fù): 0
stc89c52的lcd1602文件
ID:471403 發(fā)表于 2019-1-21 20:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
sbit LCD1602_E=P2^7;
sbit LCD1602_RW=P2^5;
sbit LCD1602_RS=P2^6;
#ifndef _LCD_H_
#define _LCD_H_
#define LCD1602_4PINS
#include <reg51.h>
#ifndef uchar
        #endif
#ifndef uint
        #endif
#define LCD1602_DATAPINS P0
void L_D(uint c);//延時函數(shù)
void LWC(uchar com);//為讀入一個字符de命令
void LWD(uchar dat);//為寫入一個字符de數(shù)據(jù)
void LI();//初始化,在掃描錄入之前
#endif
#ifndef   LCD1602_4PINS
void LWC(uchar com){
        LCD1602_E=0;
        LCD1602_RS=0;
        LCD1602_RW=0;
        LCD1602_DATAPINS=com;
        L_D(1);
        LCD1602_E=1;
        L_D(5);
        LCD1602_E=0;
#else
        LCD1602_E=0;
        LCD1602_RS=0;
        LCD1602_RW=0;
        L_D(1);
        LCD1602_E=1;
        L_D(5);
        LCD1602_E=0;
        L_D(1);
        LCD1602_DATAPINS=com << 4;
        L_D(1);
        LCD1602_E=1;
        L_D(5);
        LCD1602_E=0;
#endif
void LWD(uchar dat){
        LCD1602_E=0;
        LCD1602_RS=1;
        LCD1602_RW=0;
        LCD1602_DATAPINS=dat;
        L_D(1);
        LCD1602_E=1;
        L_D(5);
        LCD1602_E=0;
#else
        LCD1602_E=0;
        LCD1602_RS=1;
        LCD1602_RW=0;
        LCD1602_DATAPINS= dat;
        L_D(1);
        LCD1602_E=1;
        L_D(5);
        LCD1602_E=0;
        LCD1602_DATAPINS=dat << 4;
        L_D(1);
        LCD1602_E=1;
        L_D(5);
        LCD1602_E=0;}
#endif
        void LI(){
                LWC(0x38);
                LWC(0x0c);
                LWC(0x06);
                LWC(0x01);
                LWC(0x80);
        #else
        void LI(){
                LWC(0x32);
                LWC(0x28);
                LWC(0x0c);
                LWC(0x06);
                LWC(0x01);
                LWC(0x80);
        #endif
//延時函數(shù)
void L_D(uint c){
        uchar a,b;
        for(;c>0;c--){
                for (b=199;b>0;b--){
                        for (a=1;a>0;a--);
