查看: 4610|回復: 3
DELPHI開發的甲醛測試儀上位機源碼 DART傳感器數據發串口
ID:441300 發表于 2019-1-17 22:32 | 顯示全部樓層 |閱讀模式
基于DELPHI開發的甲醛測試儀,上位機程序。配合常見的英國DART傳感器,協議長9字節。通過串口發送。
delphi程序源碼:
  1. unit Unit2;
  2. interface
  3. uses
  4.   Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
  5.   Dialogs, CPortCtl, CPort, StdCtrls;
  6. type
  7.   TForm2 = class(TForm)
  8.     GroupBox1: TGroupBox;
  9.     GroupBox2: TGroupBox;
  10.     GroupBox3: TGroupBox;
  11.     Label2: TLabel;
  12.     Label8: TLabel;
  13.     Button1: TButton;
  14.     Button2: TButton;
  15.     Memo1: TMemo;
  16.     ComPort1: TComPort;
  17.     ComLed1: TComLed;
  18.     ComLed2: TComLed;
  19.     Label13: TLabel;
  20.     Label14: TLabel;
  21.     ComDataPacket1: TComDataPacket;
  22.     procedure Button1Click(Sender: TObject);
  23.     procedure Button2Click(Sender: TObject);
  24.     procedure FormCreate(Sender: TObject);
  25.     procedure ComPort1AfterOpen(Sender: TObject);
  26.     procedure ComDataPacket1Packet(Sender: TObject; const Str: string);
  27.   private
  28.     { Private declarations }
  29.   public
  30.     { Public declarations }
  31.   end;
  32.     TAir = Record   //Start from 0
  33.             CH2O:Integer;//Byte6(High) Byte7(Low)
  34.     End;
  35. var
  36.   Form2: TForm2;
  37.   i:integer;
  38. implementation
  39. {$R *.dfm}
  40. procedure TForm2.Button1Click(Sender: TObject);
  41. begin
  42.     ComPort1.ShowSetupDialog;
  43. end;
  44. procedure TForm2.Button2Click(Sender: TObject);
  45. begin
  46.     ComPort1.Open;
  47. end;
  48. procedure TForm2.ComDataPacket1Packet(Sender: TObject; const Str: string);
  49. var
  50.   value:TAir;
  51.   s:string;
  52.   j:integer;
  53. begin
  54.   Value.CH2O:=ord(Str[5])shl 8+ ord(Str[6]);
  55.   //Label7.Caption:=IntToStr(Value.PM1CF);
  56.   Label8.Caption:=IntToStr(Value.CH2O);
  57. // Label9.Caption:=IntToStr(Value.PM10CF);
  58. // Memo1.Lines.Add('Received No. '+IntToStr(i)+' packages');
  59. // s:='';
  60.   //for j := 1 to 9 do //20- sizeof('FF')
  61.    // s:=s+'['+IntToStr(ord(Str[j]))+']';
  62.   //Memo1.Lines.Add(s);
  63.   //inc(i);
  64. end;
  65. procedure TForm2.ComPort1AfterOpen(Sender: TObject);
  66. begin
  67.   memo1.Lines.Add('opedn');
  68. end;
  69. procedure TForm2.FormCreate(Sender: TObject);
  70. begin
  71.    i:=0;
  72. end;
  73. end.
全部資料51hei下載地址:
甲醛測試儀 制作源程序.rar (410.09 KB, 下載次數: 21)
ID:277550 發表于 2019-1-18 09:40 | 顯示全部樓層
CPort 組件有包含?
ID:441300 發表于 2019-1-18 10:44 | 顯示全部樓層
附件不含。相關需要組件,安裝時DELPHI一般已經安裝了
ID:65369 發表于 2022-5-13 19:06 | 顯示全部樓層
剛好需要這個例子,多謝大神支持!
