查看: 6485|回復: 2
卡爾曼濾波算法程序,輸入隨機數(shù),Q和R自己選
ID:463943 發(fā)表于 2019-1-7 17:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
卡爾曼濾波算法,自己,輸入為隨機數(shù),Q和R要自己選
主函數(shù):
#include "kalman.h"
#include "stdio.h"
#include "stdlib.h"
void main(void)
        KalmanCountData k;
        //定義一個卡爾曼運算結(jié)構(gòu)體
        Kalman_Filter_Init(&k);
        //講運算變量初始化
        int n;
        int a;
        srand((unsigned)time(NULL)); // 初始化隨機種子,使rand()產(chǎn)生的隨機數(shù)每次不一樣
           for(a = 0;a<1000;a++)
        //測試1000次
                //m,n為1到100的隨機數(shù)
                n = 1+ rand() %100;
                //卡爾曼濾波,傳遞2個測量值以及運算結(jié)構(gòu)體
        Kalman_Filter(&k,n);
                //打印結(jié)果
                printf("第%d次迭代\n  輸入:%d, 輸出濾波值為:%f\r\n",a+1,n,k.Filter_Value);
kalman.h:
typedef struct                    //定義結(jié)構(gòu)體
        float                                Filter_Value;                 //K-1時刻的系濾波值
        float                                A;                           //系統(tǒng)參數(shù),一維模型中通常選為1
        float                                H;                          //系統(tǒng)測量參數(shù),一維模型選擇為1
        float                                Kg;                        //卡爾曼增益
        float                                Q;                           //過程噪聲偏差
        float                                 R;                          //測量噪聲偏差
        float                                 P;                      //估計誤差協(xié)方差
} KalmanCountData;
void Kalman_Filter_Init(KalmanCountData * Kalman_Struct)             //卡爾曼濾波器初始化
    Kalman_Struct->A = 1;
    Kalman_Struct->H = 1;
    Kalman_Struct->P = 3;                //后驗狀態(tài)估計值方差的初始值
    Kalman_Struct->Q = 0.1;               //過程噪聲偏差,實驗測的 ,要填的!
    Kalman_Struct->R = 10;                 //測量噪聲偏差,要填的!
    Kalman_Struct->Filter_Value = 0;                   //初始化設置k-1時刻的系統(tǒng)濾波后的值為0
double Kalman_Filter(KalmanCountData* Kalman_Struct, double Last_Measurement){
    double PredictValue = Kalman_Struct->Filter_Value*Kalman_Struct->A;     //先驗估計的預測值
    Kalman_Struct->P = Kalman_Struct->A*Kalman_Struct->P*Kalman_Struct->A+Kalman_Struct->Q; //求協(xié)方差
    double prevalve = Kalman_Struct->Filter_Value;  //記錄上一次(k-1)的值
    Kalman_Struct->Kg = Kalman_Struct->P*Kalman_Struct->H/(Kalman_Struct->H*Kalman_Struct->P*Kalman_Struct->H + Kalman_Struct->R);
        卡爾曼增益Kg = P(k|k-1) H’ / (H P(k|k-1) H’ + R)
    Kalman_Struct->Filter_Value = PredictValue + (Last_Measurement-PredictValue) * Kalman_Struct->Kg;
        修正結(jié)果,更新預測值;X(k|k) =  X(k|k-1) + (Z(k) - H* X(k|k-1)) * Kg
    Kalman_Struct->P = (1 - Kalman_Struct->Kg * Kalman_Struct->H) * Kalman_Struct->P;
    //更新后驗估計的協(xié)方差,P(k|k) = (1 - Kg * H) * P(k|k-1)
    return Kalman_Struct->Filter_Value;
Kalman.zip
89.46 KB, 下載次數(shù): 38, 下載積分: 黑幣 -5
參與人數(shù) 1黑幣 +50 收起 理由
ID:640288 發(fā)表于 2019-11-12 11:10 | 只看該作者
您好,這個程序中您說的過程測量噪聲是實驗測的,能給點測量方法嗎,最近在做卡爾曼濾波算法對系統(tǒng)誤差測量一籌莫展。
ID:640288 發(fā)表于 2019-11-12 11:15 | 只看該作者
您好,我想請問一下系統(tǒng)測量誤差實驗測得的可以分享一下實驗測量的步驟嗎?
