查看: 2684|回復: 0
單片機基于PCF8591智能信號發生器,只求一個仿真圖!
ID:463096 發表于 2019-1-7 14:25 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
200黑幣
如題,只求一個仿真圖就可以!
程序如下:
#include <reg52.h>
#include "i2c.h"
#define AddWr 0x90   //寫數據地址
#define AddRd 0x91   //讀數據地址
#include <reg52.h>
sbit duan=P2^6;
sbit wei=P2^7;
sbit P1_3=P1^3;
sbit P1_7=P1^7;
sbit P3_4=P3^4;
sbit beep=P2^3;
int a,b,c,d,e,f,frq,range,t,temp;
double range2;
uint zhouqi;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delay(uint x)
        int i,j;                                                //延時xms程序
        for(i=x;i>0;i--)
                for(j=112;j>0;j--);
void delay_us(uint time)         //延時xus程序
      while(time--);
extern bit ack;
bit WriteDAC(unsigned char dat);
uchar code sintab[64]={
135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
uchar code fangbotab[64]={
255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
uchar code juchitab[64]={
0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142,
146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255
uchar code sanjiaotab[64]={
0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
void display(int a,int b,int c,int d,int e,int f)
        duan=1;
        P0=table[a];
        duan=0;
        wei=1;
        P0=0xfe;
        wei=0;
        delay(1);
        duan=1;
        P0=table[b];
        duan=0;
        wei=1;
        P0=0xfd;
        wei=0;
        delay(1);
        duan=1;
        P0=table[c];
        duan=0;
        wei=1;
        P0=0xfb;
        wei=0;
        delay(1);
        duan=1;
        P0=table[d];
        duan=0;
        wei=1;
        P0=0xf7;
        wei=0;
        delay(1);
        duan=1;
        P0=table[e]+0x80;
        duan=0;
        wei=1;
        P0=0xbf;
        wei=0;
        delay(1);
        duan=1;
        P0=table[f];
        duan=0;
        wei=1;
        P0=0x7f;
        wei=0;
        delay(1);
void fangbo()
    int i;
                        P1_3=1;
                        delay_us(zhouqi);
                        P1_3=0;
                        delay_us(zhouqi);
                for(i=0;i<64;i++)
                        WriteDAC((fangbotab[i]/5)*range2);
                //        beep=1;
void sanjiaobo()
        int i;
                for(i=0;i<64;i++)
                        WriteDAC((sanjiaotab[i]/5)*range2);
void juchibo()
        int i;
                for(i=0;i<64;i++)
                        WriteDAC((juchitab[i]/5)*range2);
void zhengxianbo()
        int i;
                for(i=0;i<64;i++)
                        WriteDAC((sintab[i]/5)*range2);
void rjia1()
         range=range+10;
         if(range>=50)
                 range=50;
void rjian1()
         range=range-10;
         if(range<=0)
                 range=0;
void rjia2()
         range++;
         if(range>=50)
                 range=50;
void rjian2()
         range--;
         if(range<=0)
                 range=0;
int jianpan()
        P3=0x0f;
        if(P3!=0x0f)
                P3=0xfe;
                if(P3!=0xfe)
                        switch(P3)//第一行鍵盤,切換模式,分別對應1,2,3,4鍵
                                case 0xee:fangbo();break;
                                case 0xde:sanjiaobo();break;
                                case 0xbe:juchibo();break;
                                case 0x7e:zhengxianbo();break;
                P3=0xfd;
                if(P3!=0xfd)
                        P3=0xfd;
                        delay(10);
                        if(P3!=0xfd)
                                switch(P3)//第二行鍵盤,調頻率?
                                        case 0xed:frq=10;break;
                                        case 0xdd:frq=100;break;
                                        case 0xbd:frq=500;break;
                                        case 0x7d:frq=1000;break;
                P3=0xfb;
                if(P3!=0xfb)
                        P3=0xfb;
                        delay(10);
                        if(P3!=0xfb)
                                switch(P3)//第三行鍵盤,調峰峰值
                                        case 0xeb:rjia1();break;
                                        case 0xdb:rjian1();break;
                                        case 0xbb:rjia2();break;
                                        case 0x7b:rjian2();break;
                        while(P3!=0xfb);
        return frq;
        return range;
void init()
        frq=500;
        range=20;
void fuzhi()
                a=frq/1000;
                b=frq%1000/100;
                c=frq%100/10;
                d=frq%10;
                e=range/10;
…………限于本文篇幅 余下代碼請從51黑下載附件…………
基于PCF8591智能信號發生器.rar
419.64 KB, 下載次數: 14, 下載積分: 黑幣 -5
