2019-1-13 03:29 上傳
功能:用LCD1602顯示輸出8位可連續(xù)進(jìn)行簡(jiǎn)單的加減乘除運(yùn)算
說(shuō)明:無(wú)論與0相乘還是相除輸出結(jié)果是隨機(jī)的,錯(cuò)誤的;
除法輸出是帶小數(shù)點(diǎn)的8位數(shù)字顯示輸出,還沒(méi)有繼續(xù)小數(shù)點(diǎn)轉(zhuǎn)換
#include <reg52.h>
sbit rs=P2^2;
sbit rw=P2^1;
sbit e=P2^0;
void write_dat(uchar dat);
void write_com(uchar com);
void process(void);
void keyscan();
/*按鍵功能*/
uchar code table1[]=
1,2,3,0x2b-0x30, // 1, 2, 3, +
4,5,6,0x2d-0x30, // 4, 5, 6, -
7,8,9,0x2a-0x30, // 7, 8, 9, x
0,0x3d-0x30,0x01-0x30,0x2f-0x30 // 0, =, 清零, /
uchar k=0,flag=0,num,fuhao[6],i,temp1=0,flag1=0;
long a,b,c,d;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
/********按鍵處理***********/
void keyscan()
uchar temp;
P3=0xfe;
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P3;
switch(temp)
case 0xee:num=0;
break;
case 0xde:num=1;
break;
case 0xbe:num=2;
break;
case 0x7e:num=3;
break;
while(temp!=0xf0) // 松手檢測(cè)
{ temp=P3;
temp=temp&0xf0;
if(num==0||num==1||num==2)
if(flag==0)
a=a*10+table1[num]; //如果沒(méi)有按符號(hào)鍵,符號(hào)前的數(shù)值為a
else if(flag==1)
b=b*10+table1[num]; //如果按了符號(hào)鍵,符號(hào)后的數(shù)值為b
else if(temp1>=2&&flag1==1)
flag=1;
flag1=0;
process();
a=c;
b=table1[num];
if(k==1)
k=0;
write_com(0x01);
else if(num==3)
flag++;
flag1=1;
temp1++;
fuhao[temp1-1]=1;
i=table1[num]; //顯示按下的鍵
write_dat(0x30+i);
P3=0xfd;
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P3;
switch(temp)
case 0xed:num=4;
break;
case 0xdd:num=5;
break;
case 0xbd:num=6;
break;
case 0x7d:num=7;
break;
while(temp!=0xf0)
{ temp=P3;
temp=temp&0xf0;
if(num==4||num==5||num==6)
if(k==1)
k=0;
write_com(0x01);
if(flag==0)
a=a*10+table1[num];
else if(flag==1)
b=b*10+table1[num];
flag=1;
flag1=0;
process();
a=c;
b=table1[num];
else if(num==7)
flag++;
temp1++;
flag1=1;
fuhao[temp1-1]=2;
i=table1[num];
write_dat(0x30+i);
P3=0xfb;
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P3;
switch(temp)
case 0xeb:num=8;
break;
case 0xdb:num=9;
break;
case 0xbb:num=10;
break;
case 0x7b:num=11;
break;
while(temp!=0xf0)
{ temp=P3;
temp=temp&0xf0;
if(num==8||num==9||num==10)
if(k==1)
k=0;
write_com(0x01);
if(flag==0)
a=a*10+table1[num];
else if(flag==1)
b=b*10+table1[num];
flag=1;
flag1=0;
process();
a=c;
b=table1[num];
else if(num==11)
flag++;
temp1++;
flag1=1;
fuhao[temp1-1]=3;
i=table1[num];
write_dat(0x30+i);
P3=0xf7;
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
delay(5);
temp=P3;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P3;
switch(temp)
case 0xe7:num=12; // 0鍵
break;
case 0xd7:num=13; // '='
break;
case 0xb7:num=14; //清零鍵
break;
case 0x77:num=15; //除號(hào)鍵
break;
while(temp!=0xf0)
{ temp=P3;
temp=temp&0xf0;
switch(num)
case 12:
if(k==1)
k=0;
write_com(0x01);
if(flag==0)
a=a*10;
else if(flag==1)
b=b*10;
flag=1;
flag1=0;
process();
a=c;
b=table1[num];
write_dat(0x30);
break;
case 13:
k=1;
if(temp1>=2)
fuhao[0]=fuhao[temp1-1];
if(fuhao[0]==1)
write_com(0x80+0x4f);
write_com(0x04);
c=a+b;
d=c;
while(c!=0)
write_dat(0x30+c%10);
c=c/10;
write_dat(0x3d);
fuhao[0]=0;fuhao[1]=0;fuhao[2]=0;
fuhao[3]=0;fuhao[4]=0;fuhao[5]=0;
a=0;b=0;flag=0;flag1=0;temp1=0;
if(fuhao[0]==2)
write_com(0x04);
if(a>=b)
c=a-b;
d=c;
while(c!=0)
c=c/10;
else if(a<b)
c=b-a;
d=c;
while(c!=0)
c=c/10;
write_dat(0x2d);
write_dat(0x3d);
if(fuhao[0]==3)
write_com(0x04);
c=a*b;
d=c;
while(c!=0)
c=c/10;
write_dat(0x3d);
if(fuhao[0]==4)
i=0;
write_com(0x04);
c=(long)(((float)a/b)*1000000);
d=c;
while(c!=0)
c=c/10;
i++;
if(i==6)
write_dat(0x2e);
if(a/b<=0)
write_dat(0x30);
write_dat(0x3d);
break;
case 14:
{ write_com(0x01);
a=0;b=0;flag=0;temp1=0;flag1=0;
break;
case 15:
flag++;
temp1++;
flag1=1;
fuhao[temp1-1]=4;
write_dat(0x30+table1[num]);
break;
/*******led1602顯示*******/
rs=0;
rw=0;
P0=com;
e=1;
delay(5);
e=0;
rs=1;
rw=0;
P0=dat;
e=1;
delay(5);
e=0;
void process(void)
if(fuhao[temp1-2]==1) //如果符號(hào)鍵是+,執(zhí)行加法運(yùn)算
c=a+b;
b=0;
} // 如果符號(hào)鍵是-,執(zhí)行減法運(yùn)算
if(fuhao[temp1-2]==2)
c=a-b;
b=0;
if(fuhao[temp1-2]==3) //如果符號(hào)鍵是*執(zhí)行乘法運(yùn)算
c=a*b;
b=0;
if(fuhao[temp1-2]==4) //如果符號(hào)鍵是/ 執(zhí)行除法運(yùn)算
c=(long)((float)a/b);
b=0;
/*液晶的初始化*/
void init() //初始化
delay(15);
write_com(0x38);
delay(6);
write_com(0x38);
delay(6);
write_com(0x38);
write_com(0x38);
write_com(0x0c); //開(kāi)顯示,關(guān)光標(biāo)
write_com(0x06); //光標(biāo)移動(dòng)
write_com(0x01); //清屏
init();
keyscan();
計(jì)算器.zip
2019-1-7 14:20 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
86.09 KB, 下載次數(shù): 33, 下載積分: 黑幣 -5
源碼
評(píng)分
查看全部評(píng)分
