電壓采集曲線擬合
2019-1-13 02:12 上傳
PID參數調整
2019-1-13 02:12 上傳
- #include "stm32f10x.h"
- #include "key.h"
- #include "timer.h"
- #include "Filter.h"
- #include "sys.h"
- #include "PWM_OUTPUT.h"
- #include "led.h"
- #include "12864.h"
- #include "adc.h"
- #include "delay.h"
- #include "SHOW.h"
- #include "PID.h"
- #define uchar unsigned char
- //全局宏定義說明
- #define ERROR 0
- #define TURE 1
- #define Medium_High 3840
- #define HIGHT_LIMIT 4320 //90%
- #define LOW_LIMIT 2640 //55%
- #define Init_Uset 3600 //初始目標值3600
- #define initial_value 60.0
- #define start 2
- #define end 0
- #define target_index 15
- //外部函數調用說明:
- void system_init(void);
- void Query_button(void); //鍵盤掃描函數
- extern __IO uint16_t ADC_ConvertedValue[BUF_SIZE];
- extern u32 Adc_Feedback(float *QUEUE, u8 chip);
- extern void PID_init(PID *pp, float Kp, float Ki, float Kd);
- extern PID Voltage_PID;
- extern void TIM2_In_Init(u16 arr,u16 psc); // 定時器TIM2
- extern void TIM4_In_Init(u16 arr,u16 psc); // 定時器TIM2
- extern void LCD_refresh(void); // 顯示刷新掃描函數
- void Set_mode(void); // 模式選擇
- void Increase_current(void); // 加電流
- void Current_reduction(void); // 減電流
- extern void EXIT_PB4_Config(void);
- //變量定義
- u8 Integral_judge; //積分分離式的標志
- u16 NUM_Fliter = 450; //濾波次數設置
- int U_Set = 300; //設定目標值
- float QUEUE[20] = {0,0};
- float ADC_add,filter_Value,filter_Value_End; // 采樣值,與濾波值
- u8 Step_into_target_marks=0; // 步進目標值標志位
- float fsc = initial_value,*Duty = &fsc;
- u16 CCR1_Val = 0;
- u16 CCR1_Val_init = 2520;
- SqQueue Q; // ADC采樣值序列
- int aim_value ;
- u8 Key_symbol1=0,Key_symbol2=0,Key_symbol3=0; // 按鍵標志 key1 key2 key3
- extern float Pv,Kp,Ki,Kd;
- u8 real_time_control_lcd=0;
- u8 PID_control_sign=end; // PID開啟標志位
- u8 Refresh_LCD1=0,Refresh_LCD2=0,Refresh_LCD3=0; // LCD1,LCD2,LCD3 三塊屏幕刷新標志
- int adjust_current[21]={1659,1735,1811,1889,1966,2045,2124,2203,
- 2283,2364,2445,2527,2609,2692,2775,2859,2944,3029,3115,3201,3289};//恒流數組
- int Point_target=0;
- u16 Ini_value_tim2=10-1,Divid_tim2_val=72-1; // 定時器2裝載初始值和分頻值 10us//PID調整量,PID設定值
- int main()
- U_Set = adjust_current[0] ; //設定初始目標值U_Set
- PWM_set(Duty); //PWM輸出
- system_init(); //系統參數初始化
- Get_Adc(); //獲取adc值
- Set_Up_QUEUE( &Q ); //建立一個空隊列
- // ADC_add=Update_QUEUE(20,1); //取得隊列
- ADC_add = Update_QUEUE_1(20,1); //取得隊列
- filter_Value = filter1(QUEUE,ADC_add,20); //濾波
- aim_value=Adc_Feedback(QUEUE,1); //顯示當前的采樣值
- PID__init(&Voltage_PID, &Kp, &Ki, &Kd);
- while (1)
- /* while(flag==1&&flag1==1)
- check(); //掃描按鍵
- if (rcvF == 1)
- rcvF=0;
- keyHandle(keyVal);
- PWM_set(Duty);
- flag=0;
- // aim_value = Adc_Feedback(QUEUE,1);
- // filter_Value_End = AA_Filter(&Q,QUEUE,1); //兩次濾波,顯示 實際值
- // string_display = conversion_of_number_systems(filter_Value_End, string_display) ;
- // Write_add(2,1);
- // displaychar(string_display);
- if( PID_control_sign == start ) //開PID
- while( U_Set-aim_value>=2 || U_Set-aim_value <= -2) //PID算法
- Pv=PID_Feedback(U_Set, aim_value);
- CCR1_Val=CCR1_Val + Pv/0.36; //0。36
- if( CCR1_Val >= Medium_High ) //80%
- CCR1_Val = Medium_High;
- else if( CCR1_Val <= LOW_LIMIT ) //40%
- CCR1_Val = LOW_LIMIT;
- TIM3->CCR2 = CCR1_Val;
- aim_value = Adc_Feedback(QUEUE,1);
- return 0;
- // string_display = conversion_of_number_systems(2, string_display) ;
- /*名稱:system_init()
- *輸入:無
- *輸出:無
- *說明:各個模塊初始化
- void system_init()
- NVIC_Configuration(); // 2位搶占優先級,8位響應優先級
- delay_init(); // 延時初始化
- Lcd_Init_IO(); // 12864初始化
- Lcd_Init();
- EXIT_PB4_Config(); // 開PB4中斷
- Key_IO_Init(); // 按鍵IO初始化
- ADC1_Init(); // ADC初始化
- TIM2_In_Init(Ini_value_tim2,Divid_tim2_val);
- TIM4_In_Init(Ini_value_tim2,Divid_tim2_val);
- * 函數介紹 : 按鍵掃描
- * 輸入參數 : 無
- * 輸出參數 : 無
- * 返回值 : 無
- void Query_button()
- if(Key_symbol1 == 1) // 按鍵0按下
- PID_control_sign=end; // 關PID
- Step_into_target_marks=1; // 開啟步進目標標志位
- Set_mode(); // 設定模式
- Key_symbol1 = 0; // 清標志位1
- Refresh_LCD1 =0; // 屏幕顯示關
- LCDclear(); // LCD清屏
- if(Key_symbol2 == 1) // 按鍵1按下
- Increase_current(); // 加電流
- Key_symbol2 = 0; // 清標志位2
- if(Key_symbol3 == 1) // 按鍵2按下
- Current_reduction(); // 減電流
- Key_symbol3 = 0; // 清標志位2
- * 函數介紹 : Increase_current() 電流加0.05A 以及步進調整電流2A
- * 輸入參數 : 無
- * 輸出參數 : 無
- * 返回值 : 無
- void Increase_current()
- if( Step_into_target_marks==1 ) //開啟步進目標值模式
- if(U_Set>HIGHT_LIMIT)
- Step_into_target_marks=0; //關閉步進目標值模式
- U_Set = Init_Uset; //目標值恢復初始值
- TIM3->CCR2 = U_Set; // 更新PWM值
- PID_control_sign=start; //開PID
- Point_target=0;
- else
- U_Set = U_Set+target_index; //步進目標值
- else //步進電流模式
- if(Point_target == 21) //達到兩A停止
- Point_target = 20;
- else
- U_Set = adjust_current[Point_target] ; //PID目標值調整
- Point_target++; //自加0.05A
- * 函數介紹 : Set_mode() 選擇模式充電,放電自動
- * 輸入參數 : 無
- * 輸出參數 : 無
- * 返回值 : 無
- void Set_mode()
- * 函數介紹 : LCD是否需要刷新判斷 并響應程序
- * 輸入參數 : 無
- * 輸出參數 : 無
- * 返回值 : 無
- void LCD_refresh()
- * 函數介紹 : Current_reduction() 電流減0.05A
- * 輸入參數 : 無
- * 輸出參數 : 無
- * 返回值 : 無
- void Current_reduction()
- if(Step_into_target_marks==1) //開啟步進目標值模式
- if(U_Set <LOW_LIMIT )
- Step_into_target_marks=0; // 清步進目標值模式
- U_Set = Init_Uset; // 目標值恢復初始值
- PID_control_sign =start; //開PID
- Point_target=0; // 準備步進調整電流
- else
- U_Set=U_Set-target_index;
- else //開啟步進電流模式
- if(Point_target == -1)
- Point_target = 0;
- else
- U_Set = adjust_current[Point_target] ; // PID目標值調整
- Point_target--; // 減0.05A
雙向DC-DC(old version).7z
(208.92 KB, 下載次數: 95)
2019-1-13 02:10 上傳
下載積分: 黑幣 -5
