查看: 12278|回復: 32
單片機紅外對管尋跡小車設計
#include <red52.h>
sbit hongwai1=P1^0;   //定義紅外對管引腳  4個
sbit hongwai2=P1^1;
sbit hongwai3=P1^2;
sbit hongwai4=P1^3;
sbit ENA=P0^0;//電機驅動
sbit M1A=P0^1;
sbit M1B=P0^2;
sbit M2A=P0^3;
sbit M2B=P0^4;
sbit ENB=P0^5;
void tingzhi()         //停止
   M1A=0;
   M1B=0;
   M2A=0;
   M2B=0;
void qianjin()         //前進
   M1A=1;
   M1B=0;
   M2A=1;
   M2B=0;
void houtui()    //后退
   M1A=0;
   M1B=1;
   M2A=0;
   M2B=1;
void zuozhuan()          //左轉
   M1A=1;
   M1B=0;
   M2A=0;
   M2B=1;
void weizuozhuan() //左微轉
   M1A=1;
   M1B=0;
   M2A=0;
   M2B=0;
void youzhuan()           //右轉
   M1A=0;
   M1B=1;
   M2A=1;
   M2B=0;
void weiyouzhuan()        //右微轉
   M1A=0;
   M1B=0;
   M2A=1;
   M2B=0;
void delay_nus(unsigned int i)  //延時函數
  i=i/10;
  while(--i);
void delay_nms(unsigned int n) //延時函數
  n=n+1;
  while(--n)
  delay_nus(900);
void ControlCar(unsigned char xunji)
  tingzhi();       //首先是停止
switch(xunji)     //根據swith里面的值來驅動車
  case 1:
    qianjin();
    break;
  case 2:
    houtui();
    break;
  case 3:
    zuozhuan();
        break;
  case 4:
    youzhuan();
        break;
  case 5:
    weiyouzhuan();
        break;
   case 6:
    weizuozhuan();
        break;
  case 7:
    tingzhi();
        break;
void main()          //主函數
   delay_nms (30);//延時
  ControlCar(7);//停止
  ControlCar(1);//前進
   delay_nms (10);
          Start:          //行號
    ENA=1;//電機使能
        ENB=1;
   if(hongwai1==0&&hongwai2 == 0 && hongwai3 == 0&&hongwai4==0)   //尋跡模塊的情況判定,4個尋跡模塊,可以組合為16種情況
   {                                                            //根據需要選擇
      ControlCar(7);
      delay_nms (3);
          goto NextRun;
    if(hongwai1==0&&hongwai2 == 0 && hongwai3 == 0&&hongwai4==1)
      ControlCar(6);
      delay_nms (3);
          goto NextRun;
    if(hongwai1==0&&hongwai2 == 0 && hongwai3 == 1&&hongwai4==1)
      ControlCar(6);
      delay_nms (3);
          goto NextRun;
    if(hongwai1==0&&hongwai2 == 0 && hongwai3 == 1&&hongwai4==0)
     ControlCar(6);
      delay_nms (3);
          goto NextRun;
   if(hongwai1==1&&hongwai2 == 0 && hongwai3 == 0&&hongwai4==0)
      ControlCar(5);
      delay_nms (3);
          goto NextRun;
    if(hongwai1==1&&hongwai2 == 1 && hongwai3 == 0&&hongwai4==0)
      ControlCar(5);
      delay_nms (3);
          goto NextRun;
    if(hongwai1==0&&hongwai2 == 1 && hongwai3 == 0&&hongwai4==0)
      ControlCar(5);
      delay_nms (3);
          goto NextRun;
         if(hongwai1==1&&hongwai2 == 1 && hongwai3 == 1&&hongwai4==1)
      ControlCar(7);
      delay_nms (3);
          goto NextRun;
      ControlCar(7);
      delay_nms (3);
          goto NextRun;
   if(hongwai1==0&&hongwai2 == 1 && hongwai3 == 1&&hongwai4==1)
      ControlCar(3);
      delay_nms (3);
          goto NextRun;
   if(hongwai1==1&&hongwai2 == 1 && hongwai3 == 1&&hongwai4==0)
      ControlCar(4);
      delay_nms (3);
          break;
          goto NextRun;
   goto Start;          //相當于返回  start行
   NextRun:
   ControlCar(1);
收藏收藏17 分享淘帖 頂2 踩
ID:487204 發表于 2019-3-13 19:43 來自觸屏版 | 只看該作者
四輪的用一個驅動模塊行嗎
ID:402350 發表于 2019-4-5 17:04 | 只看該作者
123qs 發表于 2019-3-13 19:43
四輪的用一個驅動模塊行嗎
可以的
ID:506440 發表于 2019-4-7 19:30 | 只看該作者
請問是stc12c5a60s2的嗎
ID:502460 發表于 2019-4-10 09:53 來自觸屏版 | 只看該作者
四輪的用一個驅動模塊行嗎
可以,左側兩個輪子接一個輸出口,右側輪子接一個輸出口。
ID:369974 發表于 2019-4-10 16:28 | 只看該作者
請問這個速度怎么控制
ID:402350 發表于 2019-4-10 19:57 | 只看該作者
stc51
ID:402350 發表于 2019-4-10 19:58 | 只看該作者
zpj159 發表于 2019-4-10 16:28
請問這個速度怎么控制
pwm調速,定時器調脈沖寬度
ID:517628 發表于 2019-4-21 10:54 | 只看該作者
請問能把您做的c51循跡小車的電路圖發給我嗎??還有配件清單
ID:402350 發表于 2019-4-25 08:42 | 只看該作者
dats333 發表于 2019-4-21 10:54
L298N電機驅動模塊,紅外對管,最小系統,電源,
ID:514746 發表于 2019-5-8 13:06 來自觸屏版 | 只看該作者
請問樓主可以發工程嗎?
ID:514746 發表于 2019-5-14 10:26 來自觸屏版 | 只看該作者
請問這是用一個l298nma
ID:402350 發表于 2019-5-14 12:40 | 只看該作者
Rainson 發表于 2019-5-14 10:26
請問這是用一個l298nma
嗯,我使用了一個,兩個也可以
ID:498152 發表于 2019-5-14 20:24 來自觸屏版 | 只看該作者
這個可以用嗎?
ID:402350 發表于 2019-5-16 20:58 | 只看該作者
可以
ID:564037 發表于 2019-6-16 23:36 | 只看該作者
我的電機驅動模塊用的是L1109S,但我覺得原理都一樣,不過我實現不了循跡,就像一個斷了線的風箏一樣,走的是唯心派,可以幫我解決一下嗎,我可以把代碼發給你
ID:402350 發表于 2019-6-17 10:28 | 只看該作者
電信172 發表于 2019-6-16 23:36
我的電機驅動模塊用的是L1109S,但我覺得原理都一樣,不過我實現不了循跡,就像一個斷了線的風箏一樣,走的 ...
嗯吶,可以發過來一起學習。
ID:539167 發表于 2019-6-18 16:16 來自觸屏版 | 只看該作者
能循黑線走不?
ID:402350 發表于 2019-6-19 09:50 | 只看該作者
可以尋黑線
ID:539167 發表于 2019-6-19 14:12 來自觸屏版 | 只看該作者
止于心 發表于 2019-6-19 09:50
可以尋黑線
為啥我檢測到黑線就走不動
ID:402350 發表于 2019-6-19 16:07 | 只看該作者
來日可期1 發表于 2019-6-19 14:12
為啥我檢測到黑線就走不動
你可以調整一下紅外對管之間的距離
ID:526830 發表于 2019-8-5 20:20 | 只看該作者
你好,這樣不需要用到晶振嗎
ID:611926 發表于 2019-9-19 09:20 來自觸屏版 | 只看該作者
請問這個紅外模塊的電路是怎樣的?
ID:402350 發表于 2019-9-20 21:03 | 只看該作者
厚樸 發表于 2019-8-5 20:20
你好,這樣不需要用到晶振嗎
需要,最小系統里面有
ID:402350 發表于 2019-9-20 21:05 | 只看該作者
qq19990601 發表于 2019-9-19 09:20
請問這個紅外模塊的電路是怎樣的?
紅外對管一共有三個接口,一個接vcc一個接gnd還有一個接單片機的IO口,具體的可以上網查一下手冊。
ID:434283 發表于 2020-2-24 11:17 | 只看該作者
有沒有PCB、原理圖
ID:808225 發表于 2020-8-7 22:38 | 只看該作者
樓主,請問,在轉彎處,在檢測到黑線后,電機沒來得及反應,小車就沖出黑線了,應該怎么調?
ID:692524 發表于 2020-8-9 18:20 | 只看該作者
樓主,頭文件寫錯了嗎?應該是#include<reg51.h>??
ID:402350 發表于 2020-11-13 15:37 | 只看該作者
漠城 發表于 2020-8-7 22:38
可以用pwm調速
ID:402350 發表于 2020-11-13 15:38 | 只看該作者
三旬 發表于 2020-8-9 18:20
樓主,頭文件寫錯了嗎?應該是#include??
我用的是52系列的單片機
ID:848452 發表于 2020-11-26 19:55 | 只看該作者
四輪的用一個驅動模塊行嗎
可以的。。。
ID:926637 發表于 2021-5-27 14:32 | 只看該作者
紅外對管怎么接上去
ID:402350 發表于 2021-6-19 21:33 | 只看該作者
自傳zz 發表于 2021-5-27 14:32
紅外對管怎么接上去
看程序定義的端口
