查看: 1781|回復(fù): 0
利用單片機(jī)和8155設(shè)計(jì)時(shí)鐘,有誰會(huì)么,求仿真圖
ID:460237 發(fā)表于 2019-1-2 17:15 | 顯示全部樓層 |閱讀模式
利用單片機(jī)和8155設(shè)計(jì)時(shí)鐘,有誰會(huì)么,程序?qū)γ矗浚浚浚吭趺串嫹抡鎴D
#include <reg51.h>
#define char unsigned char
char code dis_7[12]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0xb2,0xf8,0x80,0x90,0xff,0xbf};
char code scan_con[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
char data dis[8]={0x00,0x00,0x0b,0x00,0x00,0x0b,0x00,0x00};
char data timedata[3]={0x00,0x00,0x00};
char data ms50=0x00,con=0x00,con1=0x00,con2=0x00;
sbit key0=P1^0;
sbit key1=P1^1;
sbit key2=P1^2;
//1ms延時(shí)函數(shù)
delay1ms(int t)
int i,j;
for (i=0;i<t;i++)
for(j=0;j<120;j++)
//按鍵處理函數(shù)
keyscan()
EA=0;
if (key0==0)
delay1ms(10);
while (key0==0);
con++;TR0=0;ET0=0;
if (con>=3)
{con=0;TR0=1;ET0=1;}
if (con!=0)
if (key1==0)
delay1ms(10);
while (key1==0);
timedata[con]++;
if (con==2) con2=24;else con1=60;
if (timedata[con]>=con1)
{timedata[con]=0;}
if (con!=0)
if (key2==0)
delay1ms(10);
while (key2==0);
timedata[con]--;
if (con==2) con2=23;else con1=59;
if (timedata[con]<=0)
{timedata[con]=con2;}
EA=1;
//數(shù)碼管顯示函數(shù)
scan()
char k;
dis [0]=timedata[0]%10;dis[1]=timedata[0]/10;
dis [3]=timedata[1]%10;dis[4]=timedata[1]/10;
dis [6]=timedata[2]%10;dis[7]=timedata[2]/10;
for (k=0;k<8;k++)
P0=dis_7[dis[k]];P2=scan_con[k];delay1ms(1);P2=0xff;
//主函數(shù)
main()
TH0=0x3c;TL0=0xb0;
TMOD=0x01;ET0=1;TR0=1;EA=1;
while (1)
scan();
keyscan();
//定時(shí)器/計(jì)數(shù)器T0中斷服務(wù)函數(shù)
void time_intt0(void) interrupt 1
ET0=0;TR0=0;TH0=0x3c;TL0=0xb0;TR0=1;
ms50++;
if (ms50==20)
ms50=0x00;timedata[0]++;
if (timedata[0]==60)
timedata[0]=0;timedata[1]++;
if (timedata[1]==60)
timedata[1]=0;timedata[2]++;
if (timedata[2]==24)
timedata[2]=0;
ET0=1;
