電路圖如下:
#include <reg51.h>
#define output P1
#define input P1
//方便移植在其他電路板上,我的電路使用P1口做鍵盤輸入接口
//定義16個按鍵
enum KEY{key0,key1,key2,key3,key4,key5,key6,key7,key8,key9,key10,key11,key12,key13,key14,key15};
uchar code table[]={ //數(shù)組定義,顯示數(shù)碼管
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
unsigned int code Freqtab[] = { //定時半周期的初始值
64021,64103,64260,64400, //低音3 4 5 6
64524,64580,64684,64777, //低音7,中音1 2 3
64820,64898,64968,65030, //中音4 5 6 7
65058,65110,65157,65178}; //高音1 2 3 4
uint FreqTemp;
//蜂鳴器聲音不怎么樣,我們使用揚聲器,接P3.7口
sbit SPEAK = P3^7;
void delay1ms(uint n) //誤差 0us ,延時n毫秒
uint a,b,c;
for(c=n;c>0;c--)
for(b=199;b>0;b--)
for(a=1;a>0;a--);
uint key_input(void)
uchar temp1,temp2; //臨時保存讀取的行或者列
uchar num = 16; //返回按鍵的值
output = 0x0f;
temp1 = input; //先讀取行
if(0x0f != temp1) //按鍵按下
delay1ms(5); //延時,消除抖動
temp1 = input; //再次讀取行
if(0x0f != temp1) //說明按鍵確實按下
temp1 = temp1 & 0x0f; //保留低4位
output = 0xf0; //準備讀取列
delay1ms(1); //延時一下,防止下一句讀不到
temp2 = input; //直接讀取列
temp2 = temp2 & 0xf0; //保留高4位
temp1 = temp1 | temp2; //將temp1和temp2的值合并
switch(temp1)
case 0xee:num=0;break;
case 0xde:num=1;break;
case 0xbe:num=2;break;
case 0x7e:num=3;break;
case 0xed:num=4;break;
case 0xdd:num=5;break;
case 0xbd:num=6;break;
case 0x7d:num=7;break;
case 0xeb:num=8;break;
case 0xdb:num=9;break;
case 0xbb:num=10;break;
case 0x7b:num=11;break;
case 0xe7:num=12;break;
case 0xd7:num=13;break;
case 0xb7:num=14;break;
case 0x77:num=15;break;
default:break;
return num;
void T0_INT(void) interrupt 1
TL0 = FreqTemp; //載入定時半周期的初始值
TH0 = FreqTemp >> 8;
SPEAK = ~SPEAK; //發(fā)音
int main()
TMOD = 0X01; //定時器T0設(shè)置為方式1
EA = 1;
ET0 = 1;
TR0 = 0;
uint num,temp;
num = key_input();
temp = num;
P0 = table[num];
if(16 != num)
FreqTemp = Freqtab[num];
TR0 = 1;
while(0xf0 != output); //檢測按鍵松開
TR0 = 0;
SPEAK = 1;
return 0;
