查看: 2063|回復: 1
arduino超聲波傳感器代碼
ID:459381 發表于 2019-1-1 16:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
int trigger_pin = 2;
int echo_pin = 3;
int led_pin = 10;
int time;
int distance;
void setup ( ) {
        Serial.begin (9600);
        pinMode (trigger_pin, OUTPUT);
        pinMode (echo_pin, INPUT);
        pinMode (led_pin, OUTPUT);
void loop ( ) {
    digitalWrite (trigger_pin, HIGH);
    delayMicroseconds (10);
    digitalWrite (trigger_pin, LOW);
    time = pulseIn (echo_pin, HIGH);
    distance = (time * 0.034) / 2;
  if (distance <= 20)
        Serial.println (" Door Open ");
        Serial.print (" Distance= ");
        Serial.println (distance);
        digitalWrite (led_pin, HIGH);
        delay (500);
  else {
        Serial.println (" Door closed ");
        digitalWrite (led_pin, LOW);
        delay (500);
ID:1 發表于 2019-1-1 20:36 | 只看該作者
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
