查看: 4070|回復: 5
單片機轉速測量程序與仿真
采用51單片機為主控電路,傳感器用光電管,電路設計含轉速采樣電路。數碼管采用4位一體共陰數碼管。下載地址: 單片機轉速測量程序與仿真.rar (153.78 KB, 下載次數: 78)
部分源程序:(完整程序請自己下載)
#include <REG52.H>
#define ulong unsigned long
#define LED_DAT P0
sbit LED_SEG0 = P2^7;
sbit LED_SEG1 = P2^6;
sbit LED_SEG2 = P2^5;
sbit LED_SEG3 = P2^4;
sbit pin_SpeedSenser = P3^5;         //光電傳感器信號接在T1上
#define TIME_CYLC 200                         //12M晶振,定時器5ms 中斷一次 我們1秒計算一次轉速 // 1000ms/5ms = 200
#define PLUS_PER 1                         //碼盤的齒數 ,這里假定碼盤上有10個齒,即傳感器檢測到10個脈沖,認為1圈
#define K         100.0                   //校準系數
unsigned char code  table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar data Disbuf[4];                        // 顯示緩沖區
uint Tcounter = 0,speed,PlusCounter;                           //時間計數器
bit Flag_Fresh = 0;                         // 刷新標志
bit Flag_clac = 0;                                 //計算轉速標志
bit Flag_Err = 0;                                 //超量程標志 //在數碼管上顯示一個四位數
void DisplayFresh();                           //計算轉速,并把結果放入數碼管緩沖區
void ClacSpeed();                                   //初始化定時器T0
void init_timer0();                                   //初始化定時器T1
void init_timer1();                                   //延時函數
void Delay(uint ms);
void it_timer0() interrupt 1
        TF0 = 0;                                       //d定時器 T0用于數碼管的動態刷新
        TH0 = 0xEC;
        TL0 = 0xA8;                            //78
        Tcounter++;
        if(Tcounter>TIME_CYLC)
                PlusCounter = TH1*256 + TL1;
            TH1=TL1 = 0x00;//脈沖計數清零
            Tcounter = 0;//周期定時 清零
                speed =60*PlusCounter/PLUS_PER;//
                 Flag_clac = 1;                        //周期到,該重新計算轉速了
        Flag_Fresh = 1;
void main(void)
        Disbuf[0] = 0; //開機時,初始化為0000
        Disbuf[1] = 0;
        Disbuf[2] = 0;
        Disbuf[3] = 0;
           init_timer0();
        init_timer1();
                if(Flag_Fresh)
                        Flag_Fresh = 0;
                    DisplayFresh();    // 定時刷新數碼管顯示
                   if(Flag_clac)
                        Flag_clac = 0;
                    ClacSpeed(); //計算轉速,并把結果放入數碼管緩沖區
                   if(speed>9999)        //超量程處理//數碼管顯示字母'EEEE'
                    Disbuf[0] = 0x9e; //開機時,初始化為0000
                    Disbuf[1] = 0x9e;
                    Disbuf[2] = 0x9e;
                    Disbuf[3] = 0x9e;
//在數碼管上顯示一個四位數
void DisplayFresh()
        LED_DAT =~table[Disbuf[0]];
        LED_SEG3 = 1;
        Delay(10);
        LED_SEG3 = 0;
        Delay(3);
        LED_DAT =~table[Disbuf[1]];
        LED_SEG2 = 1;
        Delay(10);
        LED_SEG2 = 0;
        Delay(3);
         LED_DAT =~table[Disbuf[2]];
        LED_SEG1 = 1;
        Delay(10);
        LED_SEG1 = 0;
         Delay(3);
        LED_DAT =~table[Disbuf[3]];
        LED_SEG0 = 1;
        Delay(10);
        LED_SEG0 = 0;
        Delay(3);
//計算轉速,并把結果放入數碼管緩沖區
void ClacSpeed()
        Disbuf[0] = (speed/1000)%10;
        Disbuf[1] = (speed/100)%10;
        Disbuf[2] = (speed/10)%10;
        Disbuf[3] = speed%10;
//初始化定時器T0
void init_timer0()
        TMOD &= 0xf0; //定時10毫秒
        TMOD |= 0x01;
        TH0 = 0xC0;
        TL0 = 0x00;
        ET0=1;
        EA=1;
        TR0=1;
收藏收藏3 分享淘帖 頂 踩
ID:722043 發表于 2020-4-4 02:52 | 只看該作者
這個還是不錯的
ID:724089 發表于 2020-4-9 16:11 | 只看該作者
想問一下這個程序可以測量風速吧,但我想加一個測量風向的,是不是要重新弄一個
ID:555420 發表于 2020-5-23 21:11 | 只看該作者
只有我一個人打不開嗎
ID:1154370 發表于 2025-6-17 17:31 | 只看該作者
如果加控制的話還可以用這個嗎
ID:540334 發表于 2025-6-20 23:59 來自觸屏版 | 只看該作者
這個很好,……。。。。。。。
