51PWM精確輸出按鍵可調輸出周期占空比,誤差可以達到零點幾以內。1602顯示當前輸出PWM周期占空比。
- #include <reg51.h>
- #include <intrins.h>
- #include "lcd.h"
- unsigned char code ASCII[10] = {'0','1','2','3','4','5','6','7','8','9'};
- unsigned char period[]="Period:";
- unsigned char high[]="Duty:";
- unsigned char disbuff[10];
- unsigned int peri =1000;
- unsigned int value=600; //初始占空比為60% 周期為1ms
- sbit PWM=P2^1; //PWM輸出口
- sbit K1=P1^0; //占空比增加鍵
- sbit K2=P1^1; //占空比減小鍵
- sbit K3=P1^2; //周期增加鍵
- sbit K4=P1^3; //周期減小鍵
- void TimerInit()
- TMOD=0X11;
- TH0 = (unsigned int)(65536-peri)/256;
- TL0 = (unsigned int)(65536-peri)%256; //1ms周期
- TH1 = (unsigned int)(65536-value)/256;
- TL1 = (unsigned int)(65536-value)%256; //600us高電平時間
- ET0=1;//打開定時器0中斷允許
- ET1=1;
- TR0=1;//打開定時器
- TR1=0;//打開定時器
- EA=1;//打開總中斷
- void delay(unsigned int i)
- while(i--);
- void Key_Scan()
- if(K1==0)
- delay(1000);
- if(K1==0)
- value+=20; //占空比增加
- if(value>=peri)
- value=peri;
- while(!K1);
- if(K2==0)
- delay(1000);
- if(K2==0)
- value-=20; //占空比減小
- if(value<=0)
- value=0;
- while(!K2);
- if(K3==0)
- delay(1000);
- if(K3==0)
- peri+=100;//周期增加100us
- while(!K3);
- if(K4==0)
- delay(1000);
- if(K4==0)
- peri-=100; //周期減小100us
- while(!K4);
- void main(void)
- InitLcd1602();
- TimerInit();
- while(1)
- int zhanbi;
- Key_Scan();
- LcdShowStr(0,0,period); //顯示周期
- LcdShowStr(0,1,high); //顯示占空比
- disbuff[0]=peri/10000;
- disbuff[1]=peri%10000/1000;
- disbuff[2]=peri%1000/100;
- disbuff[3]=peri%100/10;
- disbuff[4]=peri%10;
- DisplayOneChar(7,0,ASCII[disbuff[0]]);
- DisplayOneChar(8,0,ASCII[disbuff[1]]);
- DisplayOneChar(9,0,ASCII[disbuff[2]]);
- DisplayOneChar(10,0,ASCII[disbuff[3]]);
- DisplayOneChar(11,0,ASCII[disbuff[4]]);
- DisplayOneChar(12,0,'u');
- DisplayOneChar(13,0,'s');
- zhanbi=(value/10*100)/(peri/10);
- disbuff[0]=zhanbi/10;
- disbuff[1]=zhanbi%10;
- DisplayOneChar(7,1,ASCII[disbuff[0]]);
- DisplayOneChar(8,1,ASCII[disbuff[1]]);
- DisplayOneChar(9,1,'%');
- void Time0(void) interrupt 1
- TH0 = (unsigned int)(65536-peri+30)/256; //加30彌補中斷事件,具體可通過調節數值達到彌補效果
- TL0 = (unsigned int)(65536-peri+30)%256; //通過改變peri改變周期大小
- PWM=1;
- TR1=1;
- void Time1(void) interrupt 3
- TH1 = (unsigned int)(65536-value+20)/256; //加20彌補中斷事件,具體可通過調節數值達到彌補效果
- TL1 = (unsigned int)(65536-value+20)%256; //通過改變value改變占空比
- PWM=0;
- TR1=0;
- //經示波器測定占空比誤差百分之一左右通過自己調節彌補值大小可以達到誤差百分之零點五以下
PWM輸出修改版.zip
(55.03 KB, 下載次數: 195)
2018-12-26 23:57 上傳
下載積分: 黑幣 -5
