2018-12-23 19:01 上傳
激光豎琴電路原理圖如下:
2018-12-23 19:01 上傳
| 名稱 | 數(shù)量 | | PCB板 | 1 | | 5V激光發(fā)射頭(多發(fā)3個(gè)) | 10 | | 22#導(dǎo)線20CM | 1 | | 5516光敏電阻 | 8 | | 4CM黑色熱縮管 20CM | 1 | | 10K電阻 | 10 | | 1K電阻 | 12 | | 3MM LED 白發(fā)藍(lán) | 12 | | DC005座 | 1 | | USB轉(zhuǎn)DC005線 | 1 | | 無源蜂鳴器 | 1 | | 8*8自鎖開關(guān) | 1 | | 自鎖開關(guān)帽 | 1 | | 8550三極管 | 1 | | 6*6*20按鍵 | 2 | | 40P IC座 | 1 | | STC89C52(燒寫好程序) | 1 | | 10UF電解電容 | 1 | | 12M晶振 | 1 | | 22P 瓷片電容 | 3 |
| | 外殼的清單: |
| | M3*10螺絲 | 12 | | M3螺母 | 7 | | M3*15雙通銅柱 | 5 | | 一片外殼或者2片2外殼 | 1 |
單片機(jī)源程序如下:
- //內(nèi)容:7個(gè)激光束控制7個(gè)音符7個(gè)LED顯示
- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar button,i,timeh,timel;
- sbit speaker=P3^4;
- sbit music=P3^3;
- sbit tone=P0^0;
- sbit LED_L = P3^7;
- sbit LED_M = P3^6;
- sbit LED_H = P3^5;
- uchar code cuzhi[]={0xfc,0x44,0xfc,0xad,0xfd,0x0a,0xfd,0x34,0xfd,0x83,0xfd,0xc8,0xfe,0x06};//do re mi 。。。si
- void delay1ms(uint z) //延時(shí)1ms
- {uint x,y;
- for(x=z;x>0;x--)
- for(y=120;y>0;y--);
- void timer0() interrupt 1 //定時(shí)器0溢出中斷子程序用于產(chǎn)生各種音調(diào)
- TH0=timeh;
- TL0=timel;
- speaker=~speaker; //產(chǎn)生方波
- void main()
- EA=1; //開總中斷
- ET0=1; //開定時(shí)器0
- TMOD=0x01; //定時(shí)器0工作在方式1
- while(1)
- {button=P2;
- switch (button)
- {case 0xfe:
- {TR0=1;
- timeh=cuzhi[0]; //取中音do的計(jì)數(shù)初值高4位值
- timel=cuzhi[1]; //取中音do的計(jì)數(shù)初值低4位值
- P1=0xfe;
- delay1ms(100);
- } break;
- case 0xfd:
- {TR0=1;
- timeh=cuzhi[2]; //取中音re的計(jì)數(shù)初值高4位值
- timel=cuzhi[3];
- P1=0xfd; //取中音re的計(jì)數(shù)初值低4位值
- delay1ms(100);
- }break;
- case 0xfb:
- {TR0=1;
- timeh=cuzhi[4]; //取中音mi的計(jì)數(shù)初值高4位值
- timel=cuzhi[5];
- P1=0xfb; //取中音mi的計(jì)數(shù)初值低4位值
- delay1ms(100);
- }break;
- case 0xf7:
- {TR0=1;
- timeh=cuzhi[6]; //取中音fa的計(jì)數(shù)初值高4位值
- timel=cuzhi[7];
- P1=0xf7; //取中音fa的計(jì)數(shù)初值低4位值
- delay1ms(100);
- }break;
- case 0xef:
- {TR0=1;
- timeh=cuzhi[8]; //取中音so的計(jì)數(shù)初值高4位值
- timel=cuzhi[9];
- P1=0xef; //取中音so的計(jì)數(shù)初值低4位值
- delay1ms(100);
- }break;
- case 0xdf:
- {TR0=1;
- timeh=cuzhi[10]; //取中音la的計(jì)數(shù)初值高4位值
- timel=cuzhi[11];
- P1=0xdf; //取中音la的計(jì)數(shù)初值低4位值
- delay1ms(100);
- }break;
- case 0xbf:
- {TR0=1;
- timeh=cuzhi[12]; //取中音si的計(jì)數(shù)初值高4位值
- timel=cuzhi[13];
- P1=0xbf; //取中音si的計(jì)數(shù)初值低4位值
- delay1ms(100);
- }break;
豎琴編程.zip
(104.42 KB, 下載次數(shù): 77)
2018-12-23 18:59 上傳
點(diǎn)擊文件名下載附件
激光豎琴 下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
