矩陣鍵盤控制16 個led燈。
仿真圖
- #include<reg52.h>
- sbit LED1 = P1^0;
- sbit LED2 = P1^1;
- sbit LED3 = P1^2;
- sbit LED4 = P1^3;
- sbit LED5 = P1^4;
- sbit LED6 = P1^5;
- sbit LED7 = P1^6;
- sbit LED8 = P1^7;
- sbit LED9 = P3^0;
- sbit LED10 = P3^1;
- sbit LED11 = P3^2;
- sbit LED12 = P3^3;
- sbit LED13 = P3^4;
- sbit LED14 = P3^5;
- sbit LED15 = P3^6;
- sbit LED16 = P3^7;
- sbit P24 = P2^4;
- sbit P25 = P2^5;
- sbit P26 = P2^6;
- sbit P27 = P2^7;
- void delay_ms(unsigned int);
- void main(void)
- while(1)
- P2 = 0xfe;
- if(P24 == 0){LED1 = !LED1;delay_ms(500);}
- else if(P25 == 0){LED2 = !LED2;delay_ms(500);}
- else if(P26 == 0){LED3 = !LED3;delay_ms(500);}
- else if(P27 == 0){LED4 = !LED4;delay_ms(500);}
- P2 = 0xfd;
- if(P24 == 0){LED5 = !LED5;delay_ms(500);}
- else if(P25 == 0){LED6 = !LED6;delay_ms(500);}
- else if(P26 == 0){LED7 = !LED7;delay_ms(500);}
- else if(P27 == 0){LED8 = !LED8;delay_ms(500);}
- P2 = 0xfb;
- if(P24 == 0){LED9 = !LED9;delay_ms(500);}
- else if(P25 == 0){LED10 = !LED10;delay_ms(500);}
- else if(P26 == 0){LED11 = !LED11;delay_ms(500);}
- else if(P27 == 0){LED12 = !LED12;delay_ms(500);}
- P2 = 0xf7;
- if(P24 == 0){LED13 = !LED13;delay_ms(500);}
- else if(P25 == 0){LED14 = !LED14;delay_ms(500);}
- else if(P26 == 0){LED15 = !LED15;delay_ms(500);}
- else if(P27 == 0){LED16 = !LED16;delay_ms(500);}
- void delay_ms(unsigned int dt)
- register unsigned char bt,ct;
- for (;dt;dt--)
- for(ct=2;ct;ct--)
- for(bt=250;--bt;);
矩陣鍵盤控制led燈.rar
(36.5 KB, 下載次數: 106)
2018-12-22 19:35 上傳
